Question about Toshiba Satellite M35X-S109 Notebook
Screen black but it powers on
Screen black on my satellite m35x-s109
  • dobhran May 22, 2009
    Toshiba Satellite P205-S7806 laptop. Screen went black while playing a downloaded vido game. Used a flashlight and could make out some icons. Managed to change the screen background color to light orange and gave the cursor a tail to make it easier to find. Rebooted. F6 & F7 still have no effect. Ran virus scan and computer is clean. Checked and updated drivers. Hooked up to another monitor and computer is fine. Lack of LCD backlighting seems to be the problem. Though some backlighting appears for a few seconds when rebooting or other programs are loading.
    Novelist:
  • 118 Answers
The black screen can be a result of several factors, I will try to explore some of the more common ones:
All laptops are equipped with a "fn" key on the keyboard. With this key, many of the keys on the keyboard will actually do something completely different. One of the keys (F9 on my Toshiba) will tell the computer to switch between a regular desktop monitor and the lcd screen attached to the laptop. This is the first place to look for the screen to light up.
The fn key also controls the brightness of the lcd screen. This is the second thing to adjust on your laptop. On my Toshiba, F6 makes it go dim and F7 makes it go brighter. Try these.
Lastly, it may be a hardware problem. All laptops use something called a power inverter chip to control the amount of power used by the lcd screen. It is not uncommon for this chip to need replacing. However, it may be a little tricky to install it. Usually the chip will be under the plastic trim piece around the edge of the lcd plastic bezel. This part can be found online for anywhere from 6 dollars to 60 dollars.
The other peice of hardware that may have gone bad is the lcd backlight. This component is pretty much exactly what its name implies. It lights up the back of the lcd screen. This part does not go out very often, the power inverter is more common. This part is usually more costly than the inverter as well, both in actual cost of the part and installation.
Good luck.
tony
Posted on May 19, 2009
  • 184 Answers
There are few things that could have caused your screen to go blank.
1. your screen may have gone bad. to verify this, connect your laptop to an external monitor using the RGB monitor port at the back of the laptop. if it shows, then you have a problem with your monitor else, go to number 2.
2. The memories or one of the memory cards must have gone bad. to confirm this, turn the your laptop to reveal the bottom, follow the instruction manual that came with your laptop on replacing memory (If they are not on-board), and take one memory card out and restart with the one (if you have two of them). do the same with the second one. if nothing happens, get another memory card and try it. if nothing happens, move to the next step.
3. the hard drive may have crashed or the operating system. insert your windows cd and set your bios to boot from cd. if it works, then try to run a fresh installation and see if it can detect your hard drive and the operating system installed on it. if you don't get any information about your hard drive, get another one and try to install with it. let me know what your findings are. cheers!
2 Suggested Answers
  • 519 Answers
SOURCE: processor upgrade in a toshiba satellite m35x-s109
A Pentium M 1.7 (SL7EP) works great and runs cooler.
Posted on Jan 31, 2011
I accidentally deleted the installer of my toshiba satellite m35x - s109 touchpad...now the touchpad is no longer working and the 2 buttons below it...please help
hi flyrech,
You can just your touchpad needs a driver for it to work fine again. Here's the link:
http://www.driversforfree.com/omn_ofm_omd/toshiba/satellite/m35x-s109/drivers.aspx
Just download and install the "Toshiba Alps touchpad driver".
Hope this helps, inform me this is solution effective or not. Thanks.
May 12, 2011 | Toshiba Satellite M35X-S109 Notebook
Processor upgrade in a toshiba satellite m35x-s109
May 01, 2010 | Toshiba Satellite M35X-S109 Notebook
I have a Toshiba M35X-S109 and it won't boot. The power light will come one, I can hear something (like a fan) for 1-2 sec and then nothing. Any ideas?
do a hard reset, it might work.
take out the charger and the battery, press and hold the power button for about 20-30 secs. put back everything inside. and now see if it works.
Apr 29, 2010 | Toshiba Satellite M35X-S109 Notebook
I have a Toshiba Satellite M35X-S109 PC Notebook that had the 1-3-3-1 beep error code on boot up for about a week. After about 10-12 restarts it would finally boot up. When I tried to boot up today the...
This still sounds like a memory issues to me. Take out one of the memory sticks, reboot, and see what happens. If this solves the problem, then remove the memory stick and out the other one in. If the problem returns, you may have bad memory. basicallym what you should be checking is each stikc in each slot - to try to determine if the memory is good - if the slot is good - and if the memory is seated properly.
Mar 28, 2010 | Toshiba Satellite M35X-S109 Notebook
I need drivers for toshiba satellite m35x-s109
hello, you can get them at
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=882437&rpn=PSA72U&modelFilter=M35X-S111&selCategory=3&selFamily=1073768663
Sep 24, 2009 | Toshiba Satellite M35X-S109 Notebook
Toshiba Satellite M35X-S109 wireless problem... will not see wireless.. says turn on ... how do i turn on wireless it worked yesterday
You can press the Fn key + F2 to enable the wireless card.
The other way to do the same , would be through wireless switch located either on the left of right of the laptop.
You can also try restarting the computer, sometimes the driver for the wireless card can casue the conflict.
Thanks for using fixya
proton
Aug 15, 2009 | Toshiba Satellite M35X-S109 Notebook
M35X-S109 NO Power
Maybe the power led has the problem. Try to check it. ^_^
Feb 08, 2008 | Toshiba Satellite M35X-S109 Notebook
Toshiba M35X-S109 Doesnt Start
you may have a faulty motherboard connection, but try connecting the power adapter in without the battery and see if it runs, then replace the battery back in the compartment.
Oct 15, 2007 | Toshiba Satellite M35X-S109 Notebook
Toshiba Satellite M35X-S109 Notebook Logo
241 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
