Question about Husqvarna Garden
How do you replace the throttle control lever on the 371xp
Throttle control lever won't Stay put
tighten up the screw that is the throttle lever pivot
May 07, 2016 | Garden
How do i remove the governar and replace it and how do i set it up afterwards , the motor runs away presently refs up very high no ref control and governar lever has very little movement
start the engine and physically hold the governor lever or control the throttle that it connects to
if by lowering the rpms with the throttle lever and the governor lever moves forward , the governor will be ok
the problem will be a missing spring/rod for the governor lever and throttle lever If that doesn't work then you have no option but to go into the engine to fix what is broken
Jun 14, 2015 | Refrigerators
I REPLACED THE THROTTLE CONTROL ON MY PRIDE V10 SCOOTER AND RIDING IN GRASS IT STOPS AND BEEP 6 TIMES
6 beeps =
Throttle lever (pot) is not in center position. Return throttle lever
to center position, then turn scooter OFF then ON.
Mar 07, 2015 | Pride Victory 10 3-Wheel
Light is blinking a 7 fault code, what does this fault code mean.
According to the owner's manual for this scooter, flash code 7 indicates a speed control lever fault. This is the lever that you push to go forward and reverse. The lever is attached to a throttle potentiometer to control the speed of the scooter. The lever has to be in the middle or neutral position when the scooter is turned on, if not, you will get a 7 flash code. If the throttle potentiometer is damaged you will also get a flash code 7.
You can try to adjust the throttle pot or try manipulating the neutral position and turning the scooter on and off until the computer sees neutral. This is a potential work around and will cause the scooter to creep forward when running with hands off the throttle lever because there is no zero setting. I usually just replace the throttle potentiometer and this solves the problem. I hope this helps.
Oct 23, 2014 | Drive Medical Spitfire Travel 4-Wheel...
When I want to get scooter to go, it just beeps.
2 beeps=too low battery voltage
3 beeps=battery voltage too high
5 beeps=solenoid brake trip or free wheel mode
remove key then push then push the manual release lever in completely
6 beeps=throttle trip
throttle control lever may have been depressed while
inserting key so release control lever completely
7 beeps=throttle trip
throttle potentiometer fault or speed potentiometer fault
Oct 01, 2014 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
How to install throttle control spring on Honda GVARA lawnmower engine
There should be an empty hole in the throttle lever that one end of the spring goes into. The other end is attached to a stationary post directly in line with the throttle lever. Hook the spring in the throttle lever first and look for something to hook the other end on, probably in the direction away from the engine.
Aug 23, 2014 | Garden
Rascal scooter
Could be the Throttle Pot or Speed Pot. The levers will change the resistance of the throttle pot. The speed pot feeds the throttle pot.
Move the speed pot while pushing the lever forward. If it works could be the speed pot has a dead spot on it. Also check wires loose and a mechanical issue with the throttle pot and the springs.
Apr 04, 2014 | Health & Beauty
I have brigs 14hp ohv mod 287707 crossed the solenoid and jumped the starter to the battery it starts both ways but I have no throttle controll after it starts? Is this the solenoid needing to be replaced?...
The spring or linkage may have come off between the the control plate bolted to the side of the engine (where the throttle cable bolts to) and the throttle shaft lever. Or the throttle shaft lever is distorted and stuck.
The starting solenoid is only going to make or break the circuit to the starting motor, so unless the solenoid cannot close the circuit by power application to the small stud, it is fine.
Jul 07, 2012 | Craftsman Garden
When i turn on heater or fan engine revs over 3000 rpm
Idle Air Control Valve Pintle may be bad If you disconnect the IAC and the problem ceases it can point to this being the problem.: Removal & Installation 3.5L Engine To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove the fuel injector sight shield.
  3. Drain the cooling system.
  4. Remove or disconnect the following:
    • The air cleaner intake duct. Figure of IAC and TPS electrical connectors disconnected. aurora_g1.gif
    • The idle air control (IAC) valve and throttle position (TP) sensor electrical connectors. Figure of cruise control and throttle control cables removed from throttle lever. aurora_g2.gif
    • The cruise control cable and throttle control cable from the throttle body lever.
    • The fuel pressure regulator vacuum hose, positive crankcase ventilation (PCV) hose and the throttle body vacuum port hose.
    • The throttle body coolant hoses.
    • The throttle control cable bracket, leaving the throttle and cruise cables connected.
    • The upper nut holding the throttle body to the intake manifold.
    • The throttle body assembly.
  5. Clean the gasket mating surfaces.
To Install:
  1. Install a new gasket and new studs if necessary.
  2. Install or connect the following:
    • Start the top nut by hand.
    • Position the throttle control cable bracket and hand start the retaining nuts and bolt.
    • Torque the three throttle body retaining nuts to 89 in.lbs. (10 Nm). And the bracket retaining bolt to 115 in.lbs. (13 Nm).
    • The throttle body vacuum port hose, PCV valve hose and the fuel pressure regulator hose.
    • The throttle control and cruise control cables to the throttle body lever.
    • The IAC valve and TP sensor electrical connectors.
    • The air intake duct.
  3. Refill the cooling system.
  4. Install the fuel injector sight shield.
4.0L Engine To Remove:
  2. Relieve the fuel system pressure.
  3. Remove or disconnect the following:
    • Negative battery cable.
    • The Mass Air Flow (MAF) sensor electrical connector.
    • The PCV valve fresh air tube. Figure of cruise control cable removed from throttle cable bracket. aurora_g3.gif
    • The cruise control cable and throttle control cable from the bracket.
    • The cruise control cable and throttle control cable from throttle body lever. Figure of IAC valve and TPS connectors removed. aurora_g4.gif
    • The idle air control (IAC) valve and throttle position (TP) sensor electrical connectors. Figure of fuel lines removed from retainer on throttle cable bracket. aurora_g5.gif
    • The fuel feed and return lines from the retainer on the throttle control cable bracket.
    • The transaxle shift cable clip from the throttle control cable bracket. Figure of throttle body removed from water crossover. aurora_g6.gif
    • The throttle body from the water crossover.
To Install:
NOTE: The Mass Air Flow (MAF) sensor inlet and the outlet of the air cleaner assembly must line up when installed. Misalignment may cause MIL illumination or driveability concerns.
  1. Install or connect the following.
    • The throttle body to the water crossover. Torque the bolts to 106 in.lbs. (12 Nm).
    • The throttle and cruise control cables to the throttle body lever.
    • The throttle and cruise control cables to the throttle control cable bracket. The transaxle shift cable clip to the throttle control cable bracket.
    • The fuel feed and return line retainer to the throttle control cable bracket.
    • The MAF sensor electrical connector.
    • The air cleaner intake duct clamp. Torque the clamp to 27 in.lbs. (3Nm).
    • The fuel injector sight shield. Torque the nuts to 20 in.lbs. (2.3 Nm).
  2. Install the negative battery cable.
  3. Pressurize the fuel system and verify no leaks.
Oct 07, 2010 | 2001 Oldsmobile Alero
Garden Logo
24 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
