Question about Saws
Handle switch Need a new handle switch for Performax 90206
ginko
  • 19396 Answers
SOURCE: Handle on Lid is Broken.
Try one of the following sellers:
To contact the manufacturer, try calling 800 #. 1-800-323-9519 (US number) for replacement parts or try www.crockpot.com
Rival Crock Pot Replacement Parts from MarBeck.com
Crock Pot Replacement Parts | Slow Cooker ...
Posted on Nov 09, 2008
SOURCE: need a handle for the hot water on a YLR-5-87H3 WATER DISPENSER
My water cooler was made for Sunbeam by Prestige Home Comfort of Canada. 1-877-383-6399 Mon thru Fri 8:30 am - 5:30 PM ET to order parts or service@limagehomeproducts.com to contact
Posted on May 30, 2009
sawdust46694
  • 398 Answers
SOURCE: handle just snapped
Donvier Parts - Browne USA - 1-302-326-4802
Posted on Jul 25, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: need to replace handle on dacor microwave model: pmor30s. I have
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
Posted on Aug 04, 2009
asnowman
  • 788 Answers
SOURCE: Our handle broke on our GE Microwave convection
Here is a link to PartSelect.com, I have used them for my microwave repairs in the past and they usually ship the items fast.
I have put in your Model number, but the closest that I could find was JVM1190BY003. You can look at the picture and determine if the parts look the same and the picture will show you that you will have to take the entire door apart, (You may already know that).
http://www.partselect.com/ModelFrames.aspx?ModelID=386757&ModelNum=JVM1190BY003&mfgModelNum=&ManufactureID=2&Selected=00110600i01&Position=1&mfg=GE&Type=&Mark=1
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Posted on Oct 26, 2009
Faulty switch
Your 8650 is an old vacuum. The switch is in the part of the vacuum where the handle goes down into. When you push the lever on the handle it activates the switch. To get to the switch take off the dust cover, remove the three Screws on the small cover where the handle goes in to see the switch. On older Riccar vacuums like yours sometimes the screw holding the handle in is loose which can cause the switch to not Always engage properly. To test this turn the vacuum on and wiggle the handle. If the vacuum vacuum cuts out you may only need to tighten the handle screw.
Jan 31, 2013 | Riccar 8650/8625 s Vacuum
Encore Premier 36 walk behind- safety switch connection problem
you can adjust the handle not the switch try and swapping the switch with the other side and see if the problem follows the switch
May 12, 2012 | Garden
My new Hoover Wind Tunnel Upright UH50000 will not turn off unless I unplug it.
First I would be sure the handle was properly installed. Remove the two screws holding the upper handle in place and tap it bacwards to remove it. Set the switch inside to the OFF position. Next set both buttons on the handle to the OFF position and re-install the upper handle. If the switch still does not turn the vacuum on and off, the switch will need replacement.
Apr 01, 2011 | Hoover U6630-900 WindTunnel Bagless...
Need to install a door handle for 1998 hyundai
yes remove the panel, unhook the linkage one for the lock and one for the latch remove linkage from the handle not the latch, then remove blots holding handle then remove handle from outside the door, you will have to swap the lock to the new handle and then install new handle.
Nov 29, 2009 | Hyundai Motor 1998 Accent
I have a Maytag MDB6600AWW that is giving me a fit. It only works when it wants and the door is hard to operate as the handle isn't connected correctly anymore.
It could be your lid switch.
If the door handle is brocken the lid switch is not making contact properly.
Ash
Oct 21, 2009 | Dishwashers
Broken locks on the handle
You can call perego at 1800-671-1701 they will help you.
Oct 01, 2009 | Baby Gear
Maytag MDBH950AWB handle/latch failed.
Replaced handle/latch unit. Killed power to the unit. Removed the inside door panel then unplugged the two switches on the latch. Removed old latch with broken handle (removing inside panel frees latch/handle). Installed new latch with handle reconnected the two switches, reinstalled inside door panel. Very simple. Note: Latches can be purchased with or without the handle. Less expensive to buy with the handle already installed on the latch.
Jun 24, 2009 | Maytag 24 in. MDBH950AWS Built-in...
On/off switch for Oreck XL2600HH
Would have to assume by now you figured this out. However, need to open up the handle. It is a clamshell arrangement. Remove switch from handle, pull one wire at a time from the switch. The electrical connectors are a push-on type. Replace each one, one at a time, to the new switch, and then re-insert switch into handle. Close up the clamshell, tightening all of the screws, but do not strip the plastic housing.
Jun 19, 2009 | Oreck XL2600 Vacuum
On-off switch is stuck on
on the back of the handle down below the grip you will see 4 screws take them out.then slide the handle out towards the back.on the sides of the handle you will see small notches those are the snaps the hold it together.the handle will come apart.feel free to call me if you need help i don't charge just like to help people save money.if there is a cord cradle there you may have to take that off also,held onby 2 screws.314-628-9153
Apr 23, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Handle on kirby ultimate g won't stay upright
Just take the handle off, rermove the 2 screws on the front of the cover, remove the plastic piece on the back of the top, then remove the 2 screws and the top cover will come off. There are 2 screws holding the handle pivot on, remove those. Install the new pivot making sure that it alines with the transmissing on the left side, re-install the 2 screws and make sure they are tight. Then put the rest back together.
May 10, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
