Question about ASUS MyPal A626
I cannot get my new ASUS A626 to synch to my PC I am running Vista.
How do I get my new ASUS A626 to synch with my PC running on Vista?
  • 3 more comments
  • mgiddinge Nov 28, 2007
    Can't get my device to connect with the PC
  • buttercup2 Dec 06, 2007
    I cannot get my asus 1626 to sync to my pc. I am running Vista.
    Help!
    Thanks
  • Anonymous Dec 09, 2007
    I can't get the A626 to sync to my new PC running Vista. Does it work with Vista?
  • Anonymous Mar 19, 2008
    I am having the same problem and I was told to get the upgrade from Windows to make A626 compatible with Vista. Problem is, I can't find the upgrade. I have searched Windows inside and out and nothing works. However, Staples says that they will fix it for $10.00 here in Montana. That is my next option.
  • sendalot Oct 08, 2008
    It won't synchronize with my Outlook 2007.
    But interestingly, "Windows Mobile Device Center" tells me I have successfully synchronized when nothing in ASUS A626 changed/updated.
    What is that $10 solution Staples offers? What is it called?
    Because I might need that too.
I am having the same problem and according to the computer experts at Staples in Montana they say that there is an upgrade in Windows that we need to download to the A626. However, I have searched Windows and not found anything so, I am off to Staples to have them fix it for $10. Best of luck everyone.
Posted on Mar 19, 2008
  • 3 Answers
You need to download and install the Windows Mobile Device Center (WMDC). Go here:
http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/device-center-download.mspx
Read the system requirements and verify that your PC and device meet the system requirements. If so, download either the 32-bit or the 64-bit version depending on your PC. Install the software and ensure that it is running, That window should display a "Not Connected" message.
Now connect your device to the PC using a USB cable. The WMDC should detect your device and attempt to connect with it . If your device is locked, a popup will appear asking you to unlock the device if you want to synchronize or connect. After authentication, WMDC should complete the connection.
If you have problems or WMDC does not see your device, unplug the device from the USB cable. Wait a little bit and reconnect the device. Once your device is connected, you can choose to Set up your device (for synchronization) or connect without setting up your device.
Posted on Sep 23, 2009
Asus A626 won't charge.
Power supply problems are relatively common with ASUS products like this one it should be covered under warranty and be easily replaceable if not simply order one online.
(it is rare for the device itself to have charging issues, unless it was dropped in which case that could be a possible explanation)
Mar 01, 2011 | ASUS MyPal A626
HOW TO REPLACE SCREEN ON ASUS A626
You have to visit Asus Service centre in you country
please visit www.asus.com and find the address of nearest service centre in your country.
Jan 23, 2010 | ASUS MyPal A626 Pocket PC
Hi... I have an Ausu a626 PDA. It no longer syncs
May God help you because in my experience with a malfunctioning A626 ASUS won't lift a finger to help you. They are great at lip service like a lot of companies nowadays but short on customer service.
Did you get the Microsoft Mobile Device Center yet? I cannot get the Clarification Request radio button to function on this Web site so I'm asking about the Mobile Device Center because I have a few questions and suggestions which I can offer if you are still around.
There is no date on the posts in this FixYa place so maybe its a dead end.
Jan 14, 2010 | ASUS MyPal A626
Asus A626 keeps cutting off
I had a problem similar to this, and I used YOUR solution to fix it. In fact looking for you to thank you for the idea is how I found this problem.
Sometimes even with the battery cover on and intact, the sensor does not correctly detect it. My screen was turning off randomly and sometimes would not even get through the Asus init before it would turn off again.
So, looking at the solution you posted I pushed a small wad of Kleenex in the hole and then put the cover back on. It's been running fine for almost a day now.
So, thanks for the suggestion. I had no idea that sensor was there.
Jan 04, 2010 | ASUS MyPal A626 Pocket PC
I need to get a new battery cover for my ASUS A626 - the one that came with it fell off and was distroyed. How can I get a new one. Please help me as ASUS A626 will not turn on if that cover is not...
there is a little hole on the left side of where the pda battery goes. Inside of that hole is a tiny white button. Stuff it with a little toilet paper and it will turn be functional again.
Nov 23, 2009 | ASUS MyPal A626
I just purchased my 2nd Asus My Pal A626 Pocket PC. And I cannot run the setup program on any of my 5 computers. It tells me I need Flash 8.x or higher and I have Flash 10.x or it says I may have a...
Go to a command prompt (CMD) by navigatinf to START->RUN and typing CMD In the command prompt, type Type c:\Program Files\Common Files\InstallShield\Driver\8\Intel 32\IDriver.exe -Embedding Then run your setup.exe or install.exe of the prog you are trying to install...
If this doesnt run, think there must virus infection in all your system...
Does any other setup files runs in your system?
Please leave these details as comment and we will provide further assistance
Rnj VINODKUMAR
Nov 03, 2009 | ASUS MyPal A626
Asus mypal a626 will not stay connected to cisco
hello,
ok take a look for connection and securite setting in asus.
Sep 10, 2009 | ASUS MyPal A626 Pocket PC
Download software on windows vista
go to the address www.filehippo.com and download the DAP Premium 9.0 or above version (Latest One, its free) then run this software. its a good Downloading Software as i knew.
good luck.
shafky
May 06, 2009 | ASUS MyPal A626
ASUS MyPal A626 Wouldn't boot
On the right side of your ASUS A626 there is a switch that says "HOLD". Make sure that isn't flipped on.
-Sean
Apr 02, 2008 | ASUS MyPal A626
4 GB Expansion (ASUS A626)
Yes, my card of 4gb works perfectly, thank you very much.
From El Salvador Central América.
phone:(503)7774-2842
Feb 06, 2008 | ASUS MyPal A626
ASUS MyPal A626 Logo
569 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
