Question about Kitchen Ranges
Baumatic qf6ss - no fan, no light
What can I do to solve this problem. Doesn't turn on - either fan or lights. Can't tell if I need to change a fuse or anything. There is a small box inside where the power wires go but I'm reluctant to dive inside, and there is nothing that implies fuse with them either. Can they get greased up and cause an issue?
  • 1462 Answers
SOURCE: Light blown then fan doesn't work!
take out switch assemby and check if the track of the pcb is blown - caused by the bulb goiung. you can often repair by soldering in wire links. bet you have 12a fuse in system - should be 3a. track has blown instead of the fuse
Posted on Mar 31, 2007
  • 1462 Answers
SOURCE: Neither lights nor fans work
don't know model but they are all much the same.
there will be a pcb behind the control buttons and you will find some of the track burnt out causedd by the bulb blowing. do a soldered wire link across the burnt section of the track
Posted on Sep 25, 2008
Treefrog15
  • 127 Answers
SOURCE: put new bulb in baumatic kichen hood turned it on,
It was probably a defective bulb that tripped a circuit breaker in your house panel. Check the breakers and replace the bulb.
Posted on Feb 25, 2010
SOURCE: Broan Allure QS2 Range Hood
Had same problem & fuse fixed it.
Before buying a new control board (approx $160), check the 3 amp fuse located on the inside of the vent on the control board. You have to take the light/bottom housing & black plastic air chute off to see control board/fuse.
Posted on Mar 11, 2010
canwoodjc
  • 3301 Answers
SOURCE: last night both fan and
could be simething as simple as a disconnected wire, prior to calling for help, check these items if you feel okay with that , first turn off the circuit breaker and where the house wires come into the unit,, remove the wire nuts and check for burned areas,, if thats ok, reattach them and move to the switch or switches, unhook the wires, ( make note where each one goes ) and check them with a meter , this is probably where your problem will be,
Posted on Jul 10, 2011
No reverse light, all fuse good. reverse Switch?
It's not that simple anymore . The transmission range sensor switch is what they have now . This range sensor informes the PCM - engine computer what gear the vehicle is in. When you put the gear selector into reverse B+ voltage from the range sensor to the PCM tells the PCM reverse has been selected , the PCM then will energize the reverse lamp relay (located in the under hood fuse/relay box) there by turning on the reverse lamps . There are two fuse's in the under hood fuse/relay box . F27 10amp. & F35 10amp.
Aug 11, 2017 | 2010 Ford Escape XLT
Reverse Light doesn't work, fuse good and bulb to.
I haven't worked on an escape, but i can tell you that switch is on the transmission.
Jun 02, 2013 | 2010 Ford Escape XLT
Hunter ceiling fan remote will not turn off light it just dims the light
Try this. Remove power from the fan. Remove batteries from the remote. Press butttons on remote (might be stuck). Apply power to the fan. Install batteries in the remote and try all functions. If this doesn't work, the remote may be defective or the remote receiver may be defective. I can tell you from my own experience I have a ceiling fan that loses its mind whenever there is a power outage. Has to be reeducated from scratch
Oct 06, 2012 | Hunter Ceiling Fan Remote Transmitter...
2000 kia sportage, blower fuse location
Let's start with the passenger compartment fuse box. If you checked the 30A HEATER fuse the blower motor should run at various speeds as you operate the blower switch. If you checked the 10A REAR WIPER fuse (!), and also checked the 30A ADD (?) fuse in the engine compartment fuse relay box, turning on the air conditioner should operate the A/C relay to turn on the condenser fan motor. If this doesn't solve your problem, you'll have to trace power through the various circuits.
Sep 11, 2012 | 2000 Kia Sportage
Ck engine light problem on 2001 Impala
Well the code is for the circuit - the computer commands the relay to turn the fan on and it doesn't happen.
The computer provides the ground for the relay.
If you have replaced the relay and the fan and the fuse still blows, I would look for a problem in the harness between the fuse box and the fan, including the ground circuit for the fan.
The fuse for the cooling fan is usually a 30amp marked "cooling fan" in the fuse box in the engine compartment.
Do you know what the 25amp fuse that is blowing is for ?
Jul 30, 2012 | Chevrolet Cars & Trucks
No power to ignition or dash or anything but do have interior lights. no clicking and no reactions when key turned. same when i try to jump start it.
First check your fuse box and make sure you don't have blown fuses. If that doesn't tell you anything, you need to check if you are getting 12V to your PCM.
Jul 13, 2011 | 2006 Ford Explorer
Does a 95 cutlass supreme have a fuse for the cooling fans or only the relays. I dont see a fuse for the cooling fans. Neither fan is coming on, Ive jumped the fans they both work, Ive changed out the...
There are three fuses and two relays for your coolant fan. They should all be in your underhood fuse box. They may not be marked "coolant fan", so check them all, (2) 60 amp , (1) 20 amp, (1) 15 amp. If all the fuses are good, you may have a bad fan switch (temp sensor). It tells the fan when to turn on, follow the wire from the fan motor to find it.
Dec 19, 2009 | 1995 Oldsmobile Cutlass Supreme
Gigabyte GA-7N400 Pro fan makes tick noise after shutdown
i have a tick sound everytime my computer is on use.
Dec 26, 2008 | Gigabyte GA-7N400 Pro Motherboard
Why does my Hampton Bay fan light goes on by itself
I had the same problem as well.....It turn out that there was interference from some other electronic device, garage door, microwave, digital phone etc etc etc who knows for sure. I removed the fan from the ceiling and pulled the small remote control box out, changed the code on the four tiny switches...changed the code on the remote control to match the control box...... Completely solved the problem with the lights. Hope this helps..
Dec 14, 2008 | Hampton Bay 24002 Ceiling Fan
Kitchen Ranges Logo
65 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
