Question about Ulysse Nardin Watches
What setting for ulysse nardin on watch winder
2 Suggested Answers
cmcduncand
  • 714 Answers
SOURCE: Elgin 18s pocket watch (1908). Will not wind,
Sounds like a broken main spring.
This is a fairly easy fix and may also be due for a cleaning and service.
Find a local repairman in your area.
http://www.nawcc.org/business-directory/
Hope this tip helps
R/
David
Posted on Feb 16, 2010
Steinhausen tm-478 single watch winder how it worcks
Watch Winder Setting & Instructions for Executive Collection
Jared Tracy
posted this on March 30, 2012, 2:44 PM
  • inShare
  • There are four modes for our Executive Collection of Watch Winders (TM and SM series):
    Mode 1 (both switches with the O pressed in): rotates for 180 seconds on then 12 minutes off.
    Mode 2 (first switch with the O pressed in, second switch with the I pressed in): rotates 180 second on then 15 minutes off.
    Mode 3 (first switch with the I pressed in, second switch with the O pressed in): rotates 180 seconds on then 18 minutes off, then 180 seconds in the opposite direction.
    Mode 4 (both switches with the I pressed in): rotates 180 seconds on then 24 minutes off.
    For switching winding direction:
    I pressed in will wind clockwise
    II pressed in will wind counter clockwise
    Neither pressed in will turn the winder off
    *Please note that the CW and CCW settings do not apply when the winder is set to Mode 3 as this mode winds in both directions.
Apr 10, 2014 | Steinhausen TM-478 New Single Watch Winder...
Can someone tell me how to set date month and day on an attention manual watch
A manual watch is set by pulling out the winder.
Those with a date have three positions:-
1 normal operation
3 fully out - used to set the time
2 half way between 1 & 3 which is used to set the date and day. In this position turn it one way to set the day and the other way to set the date.
Return the winder to position 1 after setting.
Jun 04, 2011 | Watches
How do i set the date on my oyster perpechual movement watch
Unscrew crown pullout 2 stepsturn hands around till the date changes .this will indicate to you it is midnight .turn ands around to right time.if you are setting this in the afternoon remember to go past the 12.When this is done push winder in 1 step and turn winder clockwise or anti cclocwise and this will let you set day or date. When you finish push winder back in and lock down.
Jul 10, 2010 | Rolex Day-Date President 118238 Wristwatch
Stop watch not zeroing
Pull out winder 1 step and us the push buttons to adjust hands to 12 o.clock . when you have done this pull winder right out and use push buttons to set other hands then push winder back in.
Jul 06, 2010 | Tag Heuer Aquaracer Quartz Chronograph...
How to set the date?
Pull the watchs winder to the first detent then turn either clockwise or counter clock wise. Then stop the day before the date you want it set, pull it all the way out to its last detent and manually turn the hands with the winder until it changes (around 3 or 4pm usually) so you know it's the AM and set your watch for the correct time.
May 01, 2010 | Giorgio Armani Emporio Armani watches...
Watch not running
The watch should start when the winder is returned home position.
If pressing the winder does not cause the watch to start it could be that the winder may need to be screwed in (some watches include this as an additional feature to improve water resistance). Turn the winder to the right.
The wacth should now start. if it still does not start, I suggest you find your nearest dealer in your area and speak to them about it.
( You can find your nearest dealer at http://www.tagheuer.com/tools/sitemap/index.lbl?lang=en ).
Apr 08, 2010 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Need switch settings for Steinhausen watch winder to suit an Omega Coaxial movement. I do not have the original manual, and I cannot tell how to set the switches to get the appropriate winding action for...
Leave the settings as for ordinary automatic movement. Co-axial movement has nothing to do with winding process - it was developed for more precise time keeping and friction reducing only, so, you can wind the watch in winder as usual.
Mar 26, 2010 | Watches
How do i set the time on my luminox 8100
I was unable to find any instructions on the Luminox web site but I suggest you try the following:
Screw the winder anticlockwise ( to release it) and the pull the winder out. I would expect to find two "out" positions, one for the time and one for the date setting.
After setting the watch push the winder home and screw it back in.
Jan 17, 2010 | Watches
I need to know if I need to purchase a watch winder for my TAGs
Use a winder if you must but I recommend just winding and setting when you want to wear them as most winders I have seen are very cheap and unreliable. Expect up to 50 hours from most watches usually not less than 30, this is if the have recent< 5 years, overhaul.
Jun 11, 2009 | Tag Heuer Link Automatic Chronometer...
Adjust the date and day on a festina 3 dial watch
I've just worked it out! Change month....depress inset button on side above hand winder. One push with cocktail stick or similar will advance month. Change date.....pull out hand winder half way, turn knob anti-clockwise until desired number is met. Change day...... pull out hand winder fully, turn clockwise passing midnight repeatedly until day is set, continue to set time, keeping an eye on 24 hour display for am/pm.
All the best, Bob
May 06, 2008 | La Crosse Technology E. Howard Ambassador...
Watches Logo
Top Ulysse Nardin Watches Experts
Jimmy Accardi
Are you an Ulysse Nardin Watch Expert? Answer questions, earn points and help others
