Question about GPX AF100S Silver 1.7 Cu Ft Mini Refrigerator
Gpx af100s will not cool
After cleaning the fan and putting the back panel it still will not cool. Is there a way to test board or reset it? If not where can I order a replacement board? Thank you!
Samsung plasma TV cooling fan didn't turn on and the TV overheated. Tried replacing with a new fan, but that fan will not turn on either. TV works just fine with back cover removed and a 12" desk fan...
the is a fuse on the board if you follow the power line on the board back to the main power board you will find it. also test the volts with a meter just make sure you have volts. some of these models also have a thermal switch that then the tv hit a surtan temp the fan kicks in.
Sep 17, 2013 | Hitachi 42 in. Plasma TV
Emerson mw9090ss just stopped while heating something
proceed with common sense, clearly, and logically.and fix it .God bless you
Microwave overheats and keeps turning off All microwaves have some sort of a cooling fan to help keep the magnetron and controls at a tolerable level. Most OTR models will usually use the vent motor for the cooling fan also. Countertop units have a small fan behind the control panel somewhere. Either way, if the cooling fan is not working and heat builds up, it is going to open a thermostat. On some makes, this thermostat might re-set itself as soon as the temperature cools down. Other makes, you will have to replace the thermostat or fuse.
If this is your microwave oven repair problem, you will need to check the operation of the fan. Below in the component testing chart, you will see how to test the fan. Also, if possible, make sure the fan is not obstructed somehow and not turning. Also check your fan relay at your control board for voltage, if no voltage, replace control board. This fan should come on at the same time any cooking starts.
Aug 02, 2012 | Emerson MW9090SS Microwave Oven
A/c will not continue to cool.. Starts fine, runs fine.. but shuts down cooling ( comp shuts off but fan still runs) after anywhere from 5 min to multiple hours. No circuit breakers or fuses blow. CAN...
One amateur test is to place your hand on the compressor and see if it
is too hot to hold your hand on it. You may have a restricted condenser coil
If it is too hot then the condenser coil is restricted inside the unit
if not be sure and clean condenser coils with good coil cleaner.
You can put a fan on the compressor and see if it runs for another test to confirm it
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 22, 2010 | Dometic Rooftop RV Air Conditioner
Cooling fan on dell inspiron 1545 does not run
The best thing to do for a beginner is replacing the fan. Fan is not an expensive part, and disassembling main board there is the risk to damage other parts.
Test the fan on a different motherboard (or connector on same main board if available) to see if the fan is working.
Use a multimeter to check if there is voltage on motherboard fan contacts. This test is quite delicate. The motherboard can be started and work with no fan only for a limited time, or CPU will get damaged. This test is for an expert DIYer or technician.
If the fan is not working (most common situation), then replace the fan.
If the fan is working and there is no voltage in main board, then the main board is usually replaced. In some case the problem are the solder joint to fan connector, in that case a repair can be done soldering the contacts back.
Aug 17, 2010 | Dell (6F858) Cooling Fan
Bottom cools and top cools but dose not freeze . Do not heart fan when frezzer is opened.
you do not hear the fan ? your evaporator fan is not working - shut off everything and remove freezer panel look for any excess ice or frust blocking the fan - if everything is clear try spinning the fan blades with your hands, is there any resistence or it spins freely ? Put back cover and turn it on - if fan fails to spin then you have to get it serviced and change the evap fan motor assembly or check the control board.
your unit won't cool if the fan is not working or working erratically.
Sep 24, 2009 | Hotpoint HSS25GFP Side by Side...
Frig side not working on Maytag MZD2766GEW
freezer not defrosting. probably adaptive defrost board in fridge.
take panel off freezer (inside, back panel). if all frozen, can defrost with blow dryer. best to remove fridge control panel (inside, top of fidge). access adaptive defrost board, jump test to f1 (i think) next to test. this should initialize defrost mode. buy new board.
May 23, 2009 | Maytag MZD2766GES Side by Side...
Not cooling
disconnect power ...remove lower back panel ...... remove fan and replace.... used appliance shops are a good place for free or cheap fans
I have done this many times on my rental properties
ed
Oct 20, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
HELP OTHERS LG32LC7D FLAT PANEL TV
MOST LG PROBLEMS HAVE NOTHING TO DO WITH THE INVERTER BOARD AND THE INVERTER BOARD WILL NOT CAUSE THE PICTURE T FREEZE. THE 2 MOST COMMON PROBLEMS ARE THE POWER SUPPLY BOARD ( DEFECTIVE CAPACITORS) AND THE MAIN TOTAL ASSY. THE DESCRIBED PROBLEM ABOVE OF PUTTING A FAN ON THE UNIT IS A TEMPORARY FIX. REPLACE THE MAIN TOTAL ASSY.
Sep 29, 2008 | LG 32LC7D Television
Magic Chef MCO153UW
You absolutely need the magnetron cooling fan to be working, or the magnetron will be destroyed!
It is part # 3511800100 and you can order it for less than $20 here.
Far less than a magnetron.
Aug 28, 2008 | Microwave Ovens
GPX AF100S Silver 1.7 Cu Ft Mini Refrigerator Logo
Top GPX Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a GPX Refrigerator Expert? Answer questions, earn points and help others
