Question about Kitchen Ranges
Viking oven knob was hit off. Now I cannot put it back on
4 Burner Viking Professional
Need to check that the connection rod is white plastic, if it's black its a piece broken from original knob. Replacement knobs from Viking are $25-34. I used a Brainerd #64686 from Lowes (under $3) that works and looks just fine
Posted on Jan 28, 2014
4 Suggested Answers
catriver
  • 878 Answers
SOURCE: Viking Range
Juliac, the burner valve switch for that burner is either shorted or grounding out. Each burner control has a valve switch that controls the power to the igniter. Sometimes they just get full of gunk and short. Part number is PA020015. Catriver...post back.
Posted on Nov 10, 2006
  • 42 Answers
SOURCE: my viking electric oven does not have accurate temperature
how bad is the temp off?
Posted on Dec 21, 2008
  • 30 Answers
SOURCE: replacing PB010036 Bake / Broil Thermostat Viking
you do not need to take apart any switches, all you need - unplug it from power, open front panel (2 screw on each side) remove all knobs, there is 3 more screws behind them). unscrew thermostat 2 screws behind knob. open top part of stove, remove grates and cover. you will see wires to thermostat unplug them and plug one by one to new thermostat. remove old thermostat from inside the oven (it has bracket inside). put the new one. close everything back.
appliancesrepairla.com - viking repair LA
Posted on Jul 02, 2010
Have a viking professional oven and it takes too
A weak oven ignitor will cause this problem. even though it eventually lights the temp has dropped considerably so you don't get consistent temp. turn the oven on and listen for the burner to light. should light within about 2 minutes. if not replace oven ignitor(s)
May 20, 2010 | Viking 27" Professional Select Built-in...
Replacing PB010036 Bake / Broil Thermostat Viking
Dec 12, 2009 | Viking VGIC485-6G Gas Kitchen Range
How do you set the analog clock?
My eaton viking imperial stove came with the house and no manuals. The timers are digial, how do i set them
Oct 20, 2009 | Viking 27" Professional Select Built-in...
Incorrect temperature
under the oven knob is the screw that adjusts the temp. remove the knob and with a small blade screwdriver adjust the temp according to your wife's oven thermometer CW+hotter CCW=cooler
then on the back of the knob is a screw to adjust the position of the knob with respect to the marker
Apr 20, 2009 | Viking 30" Professional Select Built-in...
Lost manual for eaton/viking model # RS3025W-1.
set both knobs the temperature and the bake broil to the lock mode, set the time such as 3 to 4 hrs I think and hit start. You should then here the oven begin to lock.
Jan 28, 2009 | Viking VESO105 Electric Single Oven
Viking professional 30 inch, sparking problem
If you have replaced the spark module with the new, blue PA020041 Tytronics 0+4 spark module, the physical positions of the leads that go to the burner igniters are reversed compared to the positions on the old, white module. Make sure that the switch wire for the burner and the position of the spark wire both go to the same burner! The positions are marked on the white label with green lettering.
Nov 25, 2008 | Viking 31 in. VGSU101 Gas Cooktop
Calibration
Electric ovens are calibrated behind the temp knob. Pull the knob straight off of the shaft and look at the back of the knob. There should be a metal slide with a scale and a little set screw. Loosen the screw and move the slide in the direction indicated for your needs.
Mar 06, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Kitchen Ranges Logo
149 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
