Question about Canon Speedlite 430EX TTL Flash
Canon 430ex ii seems to flicker rapidly sometimes before taking pictures
My new Canon 430 works fine except sometimes before I talk a picture the flash shoots several times in a rapid sequence before it takes a picture. Is this normal?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Yes it is. The system is simply measuring the flash to meter the exposure.
Posted on Dec 29, 2013
Testimonial: "Thank you for your reply! But this does not happen all the time and when it happens it sounds like it goes crazy and it flickers 5 or 6 times with intense lighting sand makes high buzzing noise. I have owned other non Canon flashes but never seen this."
SOURCE: canon speedlite 430EX
Make sure it is not set to manual 'M' on the display. To get it to shoot in ETTL (Through the lens) press the mode button and it should read ETTL in the top left corner. This then means that the light is metered thorugh the lens and you are not relying on the manual settings.
Hope that helps. I had the same problem when i first got my.
By the way a brilliant all round bit of kit. I have traveled the world to some fairly extreme temps and got it wet (Rain, humidity, sea spray to deserts and serious dust) All good.
Good luck
Posted on Jul 13, 2008
SOURCE: Flash is acting weird...
The problem with troubleshooting is that you have to try different things to see what changes when you do something different. Try new batteries, then try another set, then connect the flash to another camera and see if you have the same results. In my opinion, I'd have to say that it's probably the flash but like anything else, you have to try different things. Try using a different flash unit to determine if it's a flash issue or a camera hot-shoe issue. Once you find the culprit, then either replace the flash (hopefully this is the issue because it's cheaper) or it may unfortunately be the body. Hope this helps... just try a few things and cancel out what's working vs. what's not working.
Posted on Mar 26, 2009
SOURCE: canon 430EX flash will not flash in slave mode.
This site worked foe me http://flashzebra.com/wizardcables/index.shtml
Good luck
Posted on Apr 15, 2009
SOURCE: Canon speedlight 430EX II won't fire
The conceting piece of the Flash has cracked when i dropped it, is there any thing i can do to repair or exchange it?
Posted on Nov 03, 2009
  • 685 Answers
SOURCE: Trigger a Speedlite 430EX II with a studio flash
  1. Make sure the trigger you are using is compatible with digital flashes.
  2. isolate the smaller contact so they do not "short out" on the trigger.
  3. make sure the trigger is working and will fire other flashes
Posted on Nov 21, 2009
When I take a promaster remote flash trigger system with my canon 430ex half of the picture is exposed. What am I doing wrong?
this is most likely a sync issue. you shutter speed is too high. try lowering it. 1/200 or 1/160 of a second should be fine for your case.
Sep 19, 2012 | Canon Speedlite 430EX TTL Flash
Just got a Canon 7D. Attached my 430EX to the hot shoe and it won't fire. Tried new batteries and checked the contacts, and it still won't work. Put th 430EX back onto my Rebel XTI, where it has always...
Make sure you using flash grade batteries and not rechargables. try energiser ultra or litiums or duracelll plus but nothing else. if the charge light is not coming up then most likely batteries. I would take it to your local camera shot and test your 7d with one of thier 430 just to make sure the hotshoe didnt short out the flashgun
Feb 21, 2011 | Canon Speedlite 430EX TTL Flash
Takes pictures but they are very distorded and pink
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Apr 25, 2010 | Canon PowerShot A85 Digital Camera
My 430 is making a buzzing noise then it flickers
the buzzing noise is normal for that model .. first it makes noise as it charges and maintains the capacitor then when it auto focuses ..
here is a discussion of your speedlite model and the buzzing it produces
http://www.cameralabs.com/forum/viewtopic.php?t=19864&sid=ed65281bc80849c5fa34264a56c5f9f4
Jan 19, 2010 | Canon Speedlite 430EX TTL Flash
I have purple horizontal lines across my screen when i try to take a picture. When i snap the picture that is all i get. The memory card seems to be fine in that all the pix stored on it look fine when i...
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Jan 17, 2010 | Canon PowerShot A95 Digital Camera
My xti fell with the 430 ex II attached now it
The hot shoe was bent slightly causing the flash contacts to not touch those of the camera. By using a socket from a socket wrench set, place it over the grids of the hot shoe and tap firmly with a hammer to straighten it.
Jan 02, 2010 | Canon Speedlite 430EX TTL Flash
Blurry picture
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Aug 13, 2009 | Canon PowerShot A85 Digital Camera
SD 110 won't display picture to be taken and comes out a blur
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info, I think you'll be pleasantly surprised and satisfied with Canon's response to your problem:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Mar 13, 2009 | Canon PowerShot SD110 / IXUS IIs Digital...
Canon speedlite 430 EZ does not match with canon 400 D digital camera how to use the same flash with 400 D.
You can't. The metering systems are incompatable. You must use the EX range with the 400D, such as 430EX or 580EX (versions I or II)
Feb 25, 2009 | Canon EOS 400D Digital Camera
Camera is taking Blurry pink pictures
Defective ccd imager!! company will replace this ccd imager free of charge. Year 2002 up to 2005 released unit has a factory defect ccd imager. the company recalled those units and replaced with a stronger version of ccd imager ( they are still doing it). check it out.
Nov 09, 2007 | Canon PowerShot SD110 / IXUS IIs Digital...
Open Questions:
See all Canon Speedlite 430EX TTL Flash Questions
Canon Speedlite 430EX TTL Flash Logo
108 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
