I got a Emerson portable electronic key finder for christmas and it does not work i put new batteries in it
Furby has stopped working only after 2days
Furbys have a very small reset Button under the battery cover , on the lip of plastic that surrounds the batteries , hold this down with something sharp for a few seconds.
Dec 29, 2012 | Tiger Electronics Furby Model 70 800
The CIR electronic finder dose not work
This is a simple red dot finder. First check the battery inside the finder-- and replace it.
If it still does not work you can buy a new one here:
http://www.telescope.com/control/accessories/telescope-finder-scopes
Feb 13, 2011 | Galileo (DB160) Telescope
Battery compartment in my angle finder overheats and battery indicator comes on a brand new set of batteries . why is that? i put a fresh set of batts.and when i turn it on the batteries on the right get...
There is an electronic component that is defective and it draws a lot of current (more than the normal rating) this makes the batteries over heat, if it's new ask for replacement of the tool.
Cheers!
Jan 12, 2011 | Bosch DWM40L Miter Finder Digital...
Camera turns on with display in view finder but says remove battery and replace did that with new Cr2025 and other battery turns on camera . Is the main battery bad?
the battery has lost it ability to hold correct drive current buy a new battery
merry christmas
please take the time to rank this advice below
thank you
Dec 25, 2010 | JVC GR-AX750 VHS-C Analog Camcorder
Know anyone that will rerpair an Eagle Fish finder ID 6300?
I dont know what state your in but in minnesota call Fish Lectronics at 281-963-4375. or Lakesonic at 507-281-4445. Call if you need more
Apr 19, 2010 | Eagle Fishmark 320 Portable Fishfinder
Snooze doesn't work anymore
1.You will need to reset the microprocessor of the Clock/Radio. To do this you must unplug the Clock/Radio and take out the internal battery. You must let the Clock/Radio set unplugged and with out the battery for at lease 1 hour. Then replace the battery and plug in the Clock/Radio and see if the functions return to normal.If not try replacing the internal battery (CR2430) and leaving the Clock/Radio unplugged for a few hours. Then put in the new battery and Plug in the Clock/Radio and see if the functions return to normal. If not you may have other problems with the microprocessor. You can call Emerson customer support at this telephone number 1-800-898-9020 between the hours of 7am-5pm CT. Give them the make and model number of your Clock/Radio and ask them for assistance. 2.http://www.emersonradio.com/dst.htm Copy this web link and paste it into the address bar of your browser. This will take you to the Emerson customer support web page. This page has the procedure for setting the day light saving feature in your Clock/Radio. I hope this information helps you with your problems.
Mar 13, 2009 | Emerson Smartset Clock Radio
I am looking for a owner's/operator's manual for an Eagle Silent Sixty 1 Depth Finder by Lowrance. This is one my Dad had for many,many years. It still works just fine although it would be considered an...
On the web transducer model XD-2 Find eagle model silent six/sixty will give you the owners manual for the unit mounted on the boat same as portable.
Feb 28, 2009 | Eagle Boating
Battery
call customer service 1 800 315 5885
send $30 in a money order to
Lenoxx Electronics CORP.
35 brunswick ave
Edison,NJ 08817
you need to write on a card the model number and that its for a rechargeable battery pack
 I called customer service myself to find out   Oct 22  2007
hope this helps
Sep 13, 2007 | Durabrand PDV-709
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
