Question about Mitsubishi "WD-82840 DLP 3D HDTV"
Wd-82840 random color flicker/shift
Picture looks perfect, then a slight flicker and everything gets a purple hue and the color gradients in the picture look strange. May go for 10-20 minutes with no issue, or may do it every few seconds. Duration of flicker is usually just a second or two, but can last longer. I've tried carefully wiggling various connections with the rear cover off to see if it was just a cable issue, but can't seem to make it better or worse. TV is about a year old, but probably has less than 200 hours operating time.
  • 301 Answers
SOURCE: mistubishi WD-52527 52" LCD Projection TV
those are going to be dust spots on the LCD panels internal to the optical engine. i suggest that you take the screen off and take off the panel i nthe middle of the tv with 2 screws in it and there will be an area that has 3 metal fins covering thin orange ribbon cables. the 3 square objects at the end of those ribbon cables will be the LCD panels spray wiht air compressor unitl clean and that should greatly help your problem.
Posted on Feb 20, 2008
Slinteriors
  • 8617 Answers
SOURCE: sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Posted on Mar 20, 2008
SOURCE: Mitsubishi VS-6071 60" Rear Projection TV Problem
can you give me the number of the manufacture of a 60in mitsubishi VS-60707
Posted on Nov 17, 2008
budmrtn
  • 11361 Answers
SOURCE: i have verticle lines on my Mitsubishi LT-52133.
That is not good, it can be as bad the LCD panel is bad which is more likely or the LCD panel inteface board betwwen the screen panel circuit and the main video processor board.
Posted on Nov 03, 2009
  • 8457 Answers
SOURCE: I have a mitsubishi 60
The tv projection lamp have problems,it shorting out some how.That why,u have a dim picture.Tries websites like Partstore.com,Ebay.com to buy a new projection lamp for the replacement.New tv,call mitsubishi for a warrenty repair.
Posted on Oct 18, 2010
I have an RCA L32HD31R LCD tv that has: - Double imaging - Red, blue and green are unaligned - 2/3 of the screen is has a background that flickers random colors (usually purple to turquoise) - Lines and...
I have one doing the same thing. I noticed capacitors on the power supply were bulged slightly but everything else looked fair but dirty. I blew it out with compressed air and there seemed to be a change but I am still stuck in the same place myself....
Jan 30, 2011 | RCA L32HD31 32 in. LCD HDTV
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
Sony-kp51ws510 picture turns to a blue hue with flickering colors
hello there this is an easy fix unplug the tv and take the back of the set, once inside the set you will see 3 coloured bulbs and a big mirror in the back theses over time get dusty and dirty and if you smoke it can get really bad you simply just need to clean the bulbs and the mirror with computer screen wipes or some sort of window cleaner be sure not to get everything wet inside this should sort if for you nice and clear again!
Thanks For Using FixYa
Feb 07, 2009 | Sony KP-51WS510 51" Rear Projection...
Mitsubishi DLP 62" WD-62725- Clear Picture w/ Purple Screen
Sounds like one of your colors are missing. make sure all colors are lit, Blue, Red, Green
Dec 27, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Faded colors
If the picture is dark or messed up too bad, the magic focus will not function, are all the primary colors faded? RED GREEN BLUE? You might have a bad CRT, would call a service man to check out.
May 21, 2007 | Samsung HCN5527W 55" Rear Projection...
Samsung TXN3275HF 32" tv - purple picture
Chuck the TV - probably It depends on the repair facilities available where you live. In big urban areas the cost of staffing a repair shop is such it can cost nearly as much per hour just to look at an item is it does to buy the next one-plus you get all the latest features.
May 21, 2007 | Samsung TXN3275HF 32" TV
Severe gradient issues / problems with darker grays
So your sure when you go into the monitor settings, and color, it is set to like 9300k or something? It probably isn't the monitor, because the video games you said display just fine.
Dec 19, 2006 | Dell M992 19" CRT Monitor
Mitsubishi "WD-82840 DLP 3D HDTV" Logo
26 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
