Question about DeLonghi KG40 Electric Grinder
Manual for delonghi electric coffee grinder
I need a manual
4 Suggested Answers
SOURCE: Delonghi DCG49 is suddenly quieter and will not release coffee
Had this problem with my burr grinder, coffee (or something else) is clogged between the burrs and the output chute, so new coffee can't feed in from above. You can try a few things:
1. Unplug and try to dislodge the blockage from underneath with a toothpick.
2. Disassemble and remove the blockage.
3. I've had luck with drizzling a little bit of cooking oil on to the burrs,letting it soak in a while, then running it, the clumped coffee came loose. It made a terrible mess in the bin, but I ran a couple cups of beans through and it cleaned up the oil.
Good luck~
Posted on Feb 12, 2010
Testimonial: "You were right about the clog. I tried the white rice fix seen elsewhere and it's grinding perfectly again. Thanks."
SOURCE: My DeLonghi KG79 coffee grinder
I should imagine one of the safety switches are not closed. The lid of the maker must be on and the filler has to have its cap on and inserted in the machine.
Posted on Aug 08, 2011
ercupa190
  • 12223 Answers
SOURCE: DeLonghi DCG4T Electric Burr Grinder
go to www.repairclinic.com or www.appliancepartspros.com
God bless you
Posted on Jul 20, 2012
DELONGHI ESAM 5500 WON'T MAKE CAPPUCCINO SAYS GRINDS TOO FINE, BUT WILL GRIND AND MAKE REGULAR COFFEE
have you tried cleaning it as described in your user manual,, can you hit the button for regular grind? there are alternatives, a coffee grinder if failry cheap at 10 dollars US,,
Jun 07, 2016 | DeLonghi Perfecta ESAM5500 Fully Automatic...
God bless you
Jul 19, 2012 | DeLonghi DCG4T Electric Burr Grinder
DeLonghi Esclusivo Magnifica grinder cogs have stopped spinning while the hub turns, thus no grinding is done! Help
u need it all set back up///needs grinder tanken out . if lugs are broken u need to put new grinder in....
Jan 25, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Good luck~
Feb 09, 2010 | DeLonghi DCG49 Electric Burr Grinder
My Delonghi Magnifica (manual not digital) won't start the grinder, could this be the circuit board?
Delonghi Magnifica comes up with waste tray full light when there is nothing in the tray. It doesn't make coffee, the grinder is rotating and appears to be clear. Could there be a blockage below the grinder, if so how do I access it.
Aug 21, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Grinder is not working
http://www.delonghi.com If your machine is still under warrenty they will tell you by numbers on the bottom. If you have receipt, even better. They will send you a new machine for shipping costs only. If machine is out of warrenty they will tell you where to get repaired. Very easy to deal with.
Jun 07, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLongi coffee mill #DCG-4TB
DeLonghi PARTS AND ACCESSORIES
1 (800) 865-6330.
8:30 a.m. – 5:00 p.m. (EST) Monday through Friday.
Oct 24, 2008 | DeLonghi Electric Coffee Mill Grinder
Won't come on?
I just bought a brand new unit and as recommended I unscrewed the top bean hopper and the coffee ground container-cleaned and wiped.After that I screwed back everything and tried to grind some beans.The timer was ticking away but the grinder just refused to start.I switched off the main and unscrewed the hopper and carefully screwed it back.Halfway through,I noticed and felt that you must balanced and screwed it with a smooth movement until the the whole piece is in place.The grinder just started without a hitch.This grinder has a protection circuit whereby if any part is not properly installed it will not start.
Mar 07, 2008 | DeLonghi Retro DCG59 Electric Burr Grinder
Parts
Try these guys: http://abtecparts.com/ They are Canadian. Many US distributors don't ship to Canada.
They come off this list http://www.jneuhaus.com/appliance/index.htm.
Nov 27, 2007 | DeLonghi DCG4T Electric Burr Grinder
How to select grind courseness for a DeLonghi DCG39 grinder
Go to delonghiusa.com. customer care. manuals. They have yours to download.
Aug 18, 2007 | DeLonghi DCG39 Electric Blades Grinder
DeLonghi KG40 Electric Grinder Logo
32 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
