Question about Honda 8 HP Engine
What is the rpm of a honda 8 hp engine
I need to know what is the rpm of a 8 hp honda engine do you know
  • 1 more comment
  • milly3662 May 19, 2009
    it a water pump that i need the rpm to honda water pump 8hp
    it a honda 8hp water pump that i need the rpm for
    thank you !!!
  • 10,865 Answers
Full throttle it is 4500-5500 RPM
Posted on May 19, 2009
  • Joe Hogan May 19, 2009
    3510-3750 RPM for the 8hp water pump
What is the power of engine jeep grand cherokee 2001
2001 grand cherokee generally had a 4.0, 242, I6 engine with 196 hp @ 4600 RPM, 230 lb-torque @ 3000 RPM.
The 4.7 Ltr (287 c.i V-8) was available with 235 HP @ 4800 RPM & 295 lb-torque @ 3200 RPM.
Towing cap was around 5,000 lbs.
Nov 02, 2017 | Jeep Cars & Trucks
Engine racing very high when pump not using
Sounds like the engine governor is out of adjustment or it is sticking. The engine governor job is to regulate the engine RPM and torque that is needed to power a load and return to the manufactures no load engine RPM. Recommended RPM's on pressure washers and generators are usually governed at 3,600 RPM's because that is where the engine is producing most of its torque and HP.
Mar 10, 2014 | Honda Garden
How to get more hp out of a honda 5.5hp engine
Your compressor was designed to produce 11.8 acfm at 90 psi turning neer max rpm (depending on pully combination between 800 ~1100 rpm ) with max pressure of 135psi. At 3600rpm the engine is producing max hp of 5 to 5.5. More power would not really produce more air without potentially destroying the compressor pump by over-reving. If your compressor is not functioning properly you will not get good air flow. Check instruction manual for time period to fill tank from empty. Could be 2 ~3 min. It is takes longer then problems. You can tell how your pump is doing by periodocally checking the length of time to fill tank. The next size range of gas compressor is about 8~9 hp with four cylinder pump and will deliver about 17 cfm.
Mar 15, 2011 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Old 8 hp honda eng L head ,trying to get valve spring off
you need to get a valve spring compression tool to avoid damage to engine
Dec 15, 2010 | Honda 8 HP Engine
Engine 8 Hp: gx240 8 hp no spark...
i have one that did the same and found out it was the interanl coil...
May 18, 2010 | Honda 8 HP Engine
Honda water pump
normally all the water pumps coupled with portable gas powered engine have 3000 - 3600 rpm
May 19, 2009 | Honda 8 HP Engine
Manual doe not give vaulve clearance for the GX120 honda engine
I managed to find a free Download of the technical manual on the internet so this covers all questions about the engine
Apr 28, 2009 | Honda 8 HP Engine
Drum on my concrete mixer is turning to fast
Hi
At an engine lower and higher rpm is because of the governor sensitivity sistem.An arm attaches to the shaft(inside the crankcase)with a clamp-bolt/nut.This arm are provided with a series of holes.To decrease sensitivity hook the spring into a hole lower than its original position.If needed you can make some extra adjustment holes.Hope this help you.
best regards savumihai71
Feb 01, 2009 | Honda 8 HP Engine
Honda 8 HP Engine Logo
272 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
