You can try searching for the replacement K-29 V-belt for your Mastercraft drill press at local hardware stores or online retailers that sell power tool accessories. Some options you can consider are Home Depot, Lowe's, Amazon.ca, or Canadian Tire. You can also contact the manufacturer or a local repair shop to see if they carry the replacement belt or can order it for you.
Most self propelled snow blowers are driven by a sliding rubber disc. That disc is driven by a belt from the engine. The belt can wear and needs adjustment. The handle that you hold has an adjustment for the tensioner pulley and spring assembly used to engage the belt. The belt can also be worn to the point of needing to be replaced.
Have you checked all belts and belt tensioners? If so, you will have to tip unit up and take bottom plate off of unit. The drive system consists of a rubber lined wheel that makes contact with a friction plate once handle is depressed for drive. As you change gears you can see rubber drive wheel changes position in relation to friction disc to change speed. If belts are good, I would look in this area for problem. These rubber lined dive wheels do wear out and are replaceable. Also, on some models you can adjust further. Hope this helped. Happy wrenching!
See if you can find a manual at this web site.
I FOUND THIS WEB SITE that I think will help you with this question and a lot more. Since this web site will have access to many different vehicles I hope you do not feel like I am lazy by just passing along the web site instead of giving you the exact information you asked for.
