Question about Car Audio & Video
Wiring diagram i have to kicker 12'l5 speakers i want a diagram to wire it up to a 2ohm amp
  • Lacey Simmons May 11, 2010
    which configuration speaker do you have dual 2 ohm or dual 4 ohm & is the amplifier you are hooking them up to 2ohm stereo stable or 2 ohm mono stable?
    Problem Solver:
  • 4 Answers
Are your Speakers dual or single voice coil? The best way to find a wiring diagram is look at the rockford fosgate web site. I ll give you a tip to keep in mind. when wiring the ohms of a sub when you wire it in parallel positive to positive and negative to negative on one speaker you have left it in 2 or 4 ohm configuration depending on speakers. When in a series the ohm load will change by wiring positive and negative together will give you a lower ohm the more speakers you add to the amp. Fosgate will let you see how its done
Posted on May 19, 2009
3 Suggested Answers
  • 19 Answers
SOURCE: how to wire up my
Well first of all all solobarics are dual voice coil so you have 2 2ohm voice coils so if you wire them in parallel the sub will be pulling a 1ohm load wich would in time blow out your amp. So you want to wire both voice coils in series to produce a 4ohm load.
Posted on Oct 27, 2008
  • 6 Answers
SOURCE: Wiring
You have 2 subs and 2 amps right?In that case make sure that the amps are capable of stable 1ohm load and also you'll need a lot of power and 4 gauge power cable for each amp with fuse of course.
Now....take one sub and connect the (-) with the (-) and the (+) with the (+).Now you have one (+) and one(-) to connect to the amp.Do the same with the other sub and you're ready to rock!!
Posted on Nov 14, 2008
I have a comp s 12 2ohm kicker and a comp vr 12 dual 2ohm kicker how do i wire these to stay at 2ohms to the amp
you can wire them to be at 2ohm load you need two of the same speaker. its is very bad on the amp to run like that and you will not get a good bass sound because one will over power the other sound wise
Mar 23, 2013 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
Bad sound while playing at low volume, tested both voice coils and they are both are around 4 ohm.
do you have it wired down to 0 ohm or 2ohm if u have a mono block amp wire it to where a pos. from one side goes to a neg on the other side and then use a pos an neg from diff sides coming from amp
Jul 30, 2009 | Kicker Solo-Baric L5 Car Subwoofer
How do you wire four 12 inch kicker cvr dual voice coil, to a 2400 watt 1 channel class d amp
Hello brysonford00,
The wiring configuration depends on what final impedance you want the amp to see. If the subs are 4ohm DVC's, you can wire them to present a 2ohm impedance or an 8ohm impedance. The diagrams are here. If your subs are 2ohm DVC's, the wiring is the same. The impedances will be 1ohm and 4ohms.
Hope this helps.
Jun 07, 2009 | Kicker CVR12 Car Subwoofer
DONT KNOW HOW TO RUN 2 OHMS
Hello storres18,
If you have the Kicker model number 06CVX122, with dual 2ohm voice coils, they can be connected to a mono amp at 2ohms. First jumper the voice coils in series, the dotted positive (+) to the undotted negative (-) (or vice versa). Each sub is now 4ohms. Then wire both of the remaining positives and negatives together on the amp terminals (in parallel). The amp sees a 2ohm load. Here's the diagram:
If you have the Kicker model number 06CVX124 with dual 4ohm voice coils, they cannot be wired to present a 2ohm load. They can only be wired as a 1ohm load (too low for the amp) or as a 4ohm load (at reduced power). Here is the diagram of the 4ohm wiring:
Hope this helps.
May 10, 2009 | Visonik V900XD Car Audio Amplifier
Wiring
Nov 13, 2008 | Car Audio & Video
How to wire up my kicker 12inch solobaric l5 2ohm to my zx500 2ohm mono amp. should it be ran in parallel or series? what is the best suggestion
Oct 25, 2008 | Kicker Car Audio & Video
Wiring Diagram
i HAVE 2 12 KICKERS L7 RUNNING ON A PERFORMANCE TECHNIQUE AMP 2000 WATS THE ampl its a mono //and i want to know how to wire the speakers
Jul 26, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker solobaric l5 12''
how to wire a kicker solo baric l5 12'' 4ohm down 2 and 1 ohm
Sep 25, 2007 | Car Audio & Video
Kicker zx750.1& two 15"kicker solo L7 2ohm
if the amp could handle 1ohm paralell would work if not they wire in series
Apr 08, 2007 | Kicker (ZX750.1) Car Audio Amplifier
Car Audio & Video Logo
536 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
