Question about LG WM2487H Front Load Washer
LG FRONT LOAD - SPYDER BOLTS SPINNING - WON'T COME OUT, STRIPPED ?
Remove pedestal from washer
Those washers are heavy! They have weights in them to prevent moving when spinning. Some use bolts through the bottom of the pedestal up through the washer and others use bolts down through the washer into the pedestal. Remove the bolts and lift the washer off the pedestal. You might need to get levelling bolts for the washer or check to see if the bolts are on the bottom of the pedestal. Make sure you get help to move the machine.
Jan 13, 2016 | LG WM2487H Front Load Washer
I stripped the head of the shaft end bolt of my Frigidaire front load washer. How can i get the bolt out ?
There is a special socket set made for stripped nuts and bolts. Sears sells it. There are about five sockets in the kit, each covers a couple different sized stripped nuts/bolts. The socket is spiraled inside and tightens onto the stripped head as you turn it counterclockwise to remove..... DW
May 12, 2014 | Washing Machines
Large loads won't balance & spin
Could be:
1. Broken spring(unlikely)
2. Bad shock absorbers (maybe)
3. Broken spyder-the Inner drum part that holds the drum to the hub(kinda likely). If inner drum can be moved without outer tub also moving in tandem, then broken spyder is likely.
Good luck
Mar 06, 2018 | LG WM2301HW Front Load Washer
Not Spinning LG WM2301HR
Steve R is right except that if the splines in the rotor are stripped you will have to buy a new rotor or the bolt will just continue to lossen itself up. The rotor is $64.33 online. Still a ten minute fix, after you wait a week for part delivery.
Jan 11, 2012 | LG WM-2077C Front Load Washer
I have an LG washer front load WM2032HW. It won't
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 26, 2011 | LG WM2042 Front Load Washer
Won`t spin.
heatman101
Aug 14, 2011 | LG WM1814CW Front Load Washer
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
Spin cycle not working on my LG WM0642HW
heatman101
Apr 18, 2011 | LG WM0642H Front Load
It won,t spin
heatman101
Sep 16, 2010 | LG Washing Machines
Buying a front load washer
NO, All of the fridgidare products are bad. Buyer beware. Check out more internet if you need further warning. Spyder bracket and drum bearings on the front load fridgidares are a money pit. Buy and LG from anyplace but Sears. Buy anything otherthan GE,Electrolux, Kenmore, Hotpoint from Sears.
Jan 11, 2009 | Frigidaire ATF6000ES Front Load Washer
LG WM2487H Front Load Washer Logo
71 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
