Question about Drills
Remove drill chuck from keyed chuck - Drills
  • 31 Answers
Remove screw from in side chuck left hand threads, then Take a large allen wrench an tighten in chuck,then then hit it sharply with a hammer it has Rt threads
Posted on Jan 17, 2014
4 Suggested Answers
stug_57u
  • 99 Answers
SOURCE: drill chuck removal
The screw should be left hand thread and the chuck is normal thread. The 'workshop' way to remove the chuck is to remove the screw (done). If the jaws are still working then clamp a sturdy allen key in it and whack it against a workbench to unscrew the chuck. If holding the drill in the normal position you would stand with the workbench to your left and whack it down on that. If the jaws aren't working then you can grip the body in a vice and use large pipe grips or stiltsons on the chuck. Also check to see if the chuck spindle will accept a thin spanner to hold it, as this is a slightly more caring way to brace the spindle. Then you can can hold the spanner in the vice and use the allen key in the chuck and unscrew it that way.
Posted on Oct 25, 2008
SOURCE: bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
Posted on Jan 31, 2009
  • 100 Answers
SOURCE: Removing the drill bit from Makita bdf452.
try hitting the chuck with an hide mallet in the undo direction, it just needs shocking, to rease it
Posted on Feb 16, 2009
How do you remove or reset a stuck drill chuck
If it is a reversible drill there is almost certainly a left-handed thread screw or allen bolt through the centre of the chuck into the drill shaft and this must be removed before the chuck can be removed.
If it is a keyed chuck select low gear if there is one, fit the chuck key and then strike it sharply with a hammer to jar the chuck in an anti-clockwise direction. Usually it takes only a couple of blows before the chuck is loosened.
Keyless chucks are more problematic. I hold them in a vice and use the drill in reverse which has proved fairly successful, though sometimes the chuck is only fit for scrap afterwards.
Lots of the keyed chucks can be taken apart for cleaning and lubricating if necessary.
Aug 28, 2016 | Dewalt DC740KA Battery 1500mAh, 12V, Ni-Cd
Where can i find a 5/8 in. chuck for a Pit Bull CH-16NF Drill press
Take it to a local engineering sales shop. They are all basically the same and fit into the shaft with a morse taper. You just need the correct taper.
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p...
    • 4.5/5
    • 2 REVIEWS
    Email Signup. Never miss a sale and receive special online only offers.
  • King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for ... https://eastcoastpowertools.ca/chuck-drill-press-5-8-jt6-for-milling King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for Milling At East Coast Power Tools
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p... Help others make a decision about this product by sharing your experience.
  • Related searches for 5/8 in. chuck for a Drill press
  • Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 - Amazon.ca https://www.amazon.ca/Woodstock-D3455-Drill-Chuck-8-Inch/dp/B000HRXOLS This item: Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 CDN$ 47.71. In Stock. Ships from and sold by Amazon.ca. FREE Shipping. ... (Canadian Tire) Drill Press.
  • 5/8 Drill Chuck ' eBay 2q== www.ebay.com/bhp/5-8-drill-chuck Suitable for drill presses or lathes spindle accepts R8 shank. Chuck key and R8-JT33 arbor are also included in the package. Special quenching treated ...
  • 5/8" Drill Press Chuck [MAG-DPC58] - $29.99 : KMS Tools ... https://www.kmstools.com/5-8-drill-press-chuck-2990 KMS Tools & Equipment from Vancouver BC 5/8 ... Home > Metalworking > Lathes and Milling Machines > Chucks and Taper Adapters > 5/8" Drill Press Chuck 5 /8 ...
  • 1 32 5 8 Heavy Duty Drill Chuck with Chuck Key and R8 Arbor Amazon com
    Jun 05, 2016 | Drills
    I lost my chuck key. what one will I need to buy
    39 No Drill Chuck Key? No Problem • How To Remove Drill ...
    ? 5:23
    https://www.youtube.com/watch?v=AtB1MTYtgt8
    Nov 19, 2010 - Uploaded by AskWoodMan
    All you need is a slip joint pliers and the proper size drill bit. When a drill chuck key goes missing, it can ...
    DIY - Missing Drill Chuck Key? - I Have a Solution! - YouTube
    ? 1:10
    https://www.youtube.com/watch?v=MIegFURsGFE
    Jan 16, 2016 | Drills
    How to remove the chuck on bench drill model bd 315
    Well I'm guessing BD = Black and Decker and that it has a conventional chuck key?
    If so insert chuck key into chuck as you are about to tighten chuck onto a drill. Then, holding the drill firmly by the chuck end and using a wooden mallet; give the chuck key a sharp blow in the opposite direction to which the drill turns. The shock of the impact should enable you to simply unscrew the chuck by hand from here on.
    Dec 01, 2013 | Drills
    How to remove a bent chuck from a Ryobi DP101 bench drill press
    look inside the center of the chuck... if the is a bold inside, remove it. then place the short side of a 3/8" allen key into the chuck and tighten the chuck... then smack the allen key from the side with a hammer the same direction as forward rotation...
    Oct 25, 2013 | Drills
    I have a 0302-20 1/2 drill how do i remove and replace the chuck ? i have the bolt out of center.
    Chuck the handle of the chuck key in the chuck.Find a drill bit that fits in one of holes that the chuck key fits in.Then use a flat screw driver to lever off of the drill bit and the teeth to tighten the chuck .Use a towel and hold the drill motor,be careful not to squeeze to tight just enough to hold the drill from moving.Use a harmer and strike the chuck key and that should loosen the chuck.A 1/4 inch chuck key will work as well.If this is a key less chuck then use a small pipe wrench and hammer on the back part of the chuck with the handle left as you look at the drill.Good Luck & Thank You for choosing FixYa.com.
    May 17, 2011 | Milwaukee Garden
    I can not change the drill bit. Do I need another tool?
    that depends on whether or not you have a keyed or keyless chuck. if you have a keyless chuck then you do not need another tool you must turn the chuck counter clockwise to loosen the chuck and replace the bit. if you have a keyed chuck then you will see three holes around the chuck of the drill ie the part that holds the bit. just below the holes you will see teeth spaced evenly around the drill. a chuck key allows you to put the end of the key in one of the holes and using the teeth you turn the chuck key thereby loosening the chuck and allowing you to change the bit. if you have a keyed chuck just take it to your local hardware store and they can provide you with the correct key and show you how to remove the bit. if your chuck is keyless the hold the chuck put the drill in reverse and pull the trigger use a glove to protect your hand
    Feb 24, 2011 | Drills
    How i remove a dewalt drill chuck Model dc988
    put the drill in speed setting 1 before you continue~!
    Step 1. This step loosens the screw inside the chuck. Open the chuck all the way — if you see a screw inside, it’ll need to come out before you can remove the chuck. If there’s no screw inside, you can skip steps one and two.
    Step 2. If there’s a screw inside the chuck, typically the threading will be left-handed, so turn it clockwise to remove it. Be careful, and use the right size screwdriver — you don’t want to strip the screw.
    step-2.gif Step 3. Insert the largest hex key that you have into the chuck, short-side-in, and tighten the chuck. Tap the hex key sharply in a counterclockwise direction to loosen the chuck. Now you can remove it by hand.
    step-3.gif This won’t work for every consumer drill ever made, but pretty close. Most drills will match one of two common chuck-threading standards: 3/8′-24 threaded mount for 3/8′-capacity drill chucks, and 1/2′-20 threaded mount for 1/2′-capacity drill chucks — but on some drills just the opposite may occur. To be safe, always check the thread count before you buy a replacement drill chuck.
    Oct 07, 2009 | Dewalt DC988VA XRP 3 - speed 1/2" 18v...
    How do you remove a key chuck from a dewalt drill
    first shift the drill to the drill only position and the gear selector to the low position, remove the chuck retaining screw LH thread, find a bent handle allen wrench about the chuck capacity and lock in the jaws of the chuck, put the chuck on a block of wood at about a 30 degree angle to hit the long portion counter clockwise and strike it with a hammer, it might take a couple hits but it will come off. I misread the header last time.
    Oct 01, 2009 | Dewalt Drills
    Dewalt dc920 repair instructions chuck
    To remove the chuck on your drill follow the instructions for the type of drill chuck you have:
    Instructions for removing a keyed chuck
    Most reversing drills have a left hand threaded screw located inside the bottom of the chuck.
    1.) If the unit has this screw place the chuck key, with the chuck facing toward you, into one of the holes on the right side of the chuck. Strike the key in a clockwise direction with a wooden mallet or similar object. This will loosen the screw inside the chuck.
    2.) Open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
    3.) With the chuck facing toward you place the key into one of the holes on the left side of the chuck. Using a wooden mallet or similar object, strike the key sharply in a counter-clockwise direction. This will loosen the chuck so that it may be unscrewed by hand.
    There is no way to stop the motor from turning.
    It may require several attempts to loosen the chuck
    Instructions for removing a keyless chuck
    1.) If the unit has this screw open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
    2.) Insert the short end of a 1/4" or larger hex Allen wrench into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard right hand thread. This will loosen the chuck so that it may be unscrewed by hand.
    Oct 15, 2007 | Dewalt 18 Volt Compact Drill Kit
    Drills Logo
    Top Drills Experts
    Are you a Drill Expert? Answer questions, earn points and help others
