Question about Evenflo Triumph 5 Comfort Touch
How to put back seatcover and belts on model#3702098
How do I remove the frontseat headrests?
There is a button location underneath the headrest. Lift headrest as high as possible, feel for the button, press and continue to lift up.
Apr 10, 2015 | 1993 Lexus SC
How do I remove the headrest on my 2002 silverado to install seatcover
Pull the head rest up and look at the bottom of both shafts for small holes. Put a paper clip or something a little stronger into the holes to depress the locking tabs while lifting up on the head rest at the same time.
Apr 02, 2014 | 2002 Chevrolet Silverado
Seatcovers on drivers side do not fit properly too short on my 2014 Forerunner
Go back to Toyota in Coos Bay and tell them to repair or replace. The seat cover may have been improperly secured during assembly.
Mar 24, 2014 | American Standard Williamsburg Toilet Seat...
I want to install a seatcover so I need to get the headrest off, how do I remove the headrest?
If there is no button on side or in back, you just have to pry it straight up with a padded strong flat tool.
Dec 04, 2010 | Ford Escape Cars & Trucks
How do I remove the headrest from the front seats so that I can put seatcovers?
there should be a button you push in under the headrest on the top of the seat
May 08, 2010 | 2007 Pontiac Montana
How do you remove a 1996 BMW rearseat? We are trying to put seatcovers on it.
push in on the bottom of the seat to release the spring retainer clips on the right and left sides
Nov 02, 2009 | 1996 BMW 318
How do I take the entire cover off to clean?
remove the belts and there are some elastic straps that attach the seatcover to the seat. they will be hooked onto the back of the seat.
Sep 29, 2009 | Cosco Alpha Omega Elite 5-Point 22-155
How do I take off a headrest, so I can put on seatcovers
On your headrest, there will either be a push button that you can push to release the headrest, or on some models, there's actually a tiny hole that you will need to push something like a paperclip into to release the headrest
Sep 29, 2009 | 2001 Oldsmobile Alero
Seat probs can't get cumfy, pilion and rider slipping around on 2009 er-6f
Buy a sheepskin seatcover and put it on.You bum will love you for it.Hope this helps
Aug 26, 2009 | kawasaki ER-6f Motorcycles
Headrest removal
Usea small flat screwdriverand run down along side the inside of the headrest rod. You will unclip 1 side and the rod will release. Do the same on the other and the headrest will come off. When you want to put back on just install and push down. Follow same procedure when you want to remove again. It is a little touchy but as soom as you remove 1 you will become a expert. I have done hundreds of those in the past couple years.
Jul 19, 2008 | 1998 Pontiac Sunfire
Evenflo Triumph 5 Comfort Touch Logo
109 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
Vic Fkiaras
Level 1 Expert
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
