Question about Philips 55pfl4706/f7 TV
Left half of tv flickers and then at times the tv shuts off
Picture blinks on an off an has no sound how can this be fixed
TV pic blinks on/off when connected to satellite via hdmi - Forums ...
www.cnet.com > Forums > Sony
CNETApr 7, 2013 - We have a sony bravia LCD tv, model KDL-60EX500. ... The tv then started "blinking" on and off - no sound, black screen - for a half second or ... Samsung Series 3 (330), won't show any picture/no sound?
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
LG TV : Picture not coming on screen, but TV is on.
Jul 14, 2014
How many have 'blinking' issue with Samsung led tv
Jan 26, 2011
More results from www.cnet.com
VIZIO flickering Tv screen easy fix( no money ) - YouTube
? 1:58
https://www.youtube.com/watch?v=oWSFwS3FH_c
Aug 28, 2012 - Uploaded by Bill GatesBestfriend
VIZIO flickering Tv screen easy fix( no money ) .... I left town unplugged the Tv. When I came home home ...
Jan 26, 2016 | Televison & Video
Philips 52 LCD TV turned on left side is flickering right side ok what to do
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Dec 11, 2014 | Philips Televison & Video
Sound but no video
Sound like you have a faulty inverter. The next time the picture turns off, turn off the lights in the room. Take a bright flashlight and shine it on the screen. If you still see a faint picture, more than likely you have a fault with the inverter.
Jun 12, 2013 | Vizio E3D470VX 47 in. 3D LCD HDTV
Element HDMI 32 inch. Left half showing picture, right half only showing vertical rainbow lines.
One of 2 things happened here. Either your T-con board is defective and needs changed, or your Panel is defective and you need a new TV.
Apr 11, 2011 | Element Electronics FLX-3211B 32 in. LCD...
Screen Flicker then tv shuts off
please re solder  first all parts specially in hot area, and observe if problem still occur, then next is replace filter capacitor. observe also too hot parts and check for change value resistor.
Feb 25, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
Upper half of screen is flickering. Started last night. Appears to heat up and flicker. When I shut the TV down and let it cool off, flicker stops, but then starts again after the TV is on for a while. ...
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 16, 2009 | Gateway XHD3000 LCD TV
My power light flickers 4 -5 times, but the tv will not come on manually or with the remote.
my emerson t.v. model no. lc320em9 3 will not stay on. it will flicker 4-5 times and then shut off.
Aug 29, 2009 | RCA Televison & Video
Screen flickers upon power up
Looks like your picture tube is dying, or there is a bust capacitor(s) inside...I'd recommend taking it to a service shop to get it repaired.
Cheers!
IrishDruid
Jan 08, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Philips 55pfl4706/f7 TV Logo
43 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
