Question about 2004 Mustang Factory Wiring Diagrams
Executone speaker sr8w4 wire colour terminal and wattege
I would like to know the wire colour ,terminal and wattage on the executone sr8w4 ceiling speaker
  • Ford Master
  • 9,639 Answers
Looks like its a 8 inch diameter 4 watt speaker.
Posted on Jan 01, 2014
Need to know what colours of rear speaker wiring
Not sure if this car follows the standard - but the wires should be as follows:
Green - rear left speaker + terminal
Green w.black stripe - rear left speaker (-) terminal
Violet - right rear speaker + terminal
Violet w/black stripe - right rear speaker (-) terminal
Jun 21, 2015 | 2011 Nissan Qashqai 1.6
How do i wire my kicker dcvr122 up to a 4 ohm amp
I am going to assume the 2 speakers in the sub are each 4 ohm loads, and are wired together in parallel, creating a 2 ohm load. And your amp pushes 800W at a 2 ohm load. And actually goes down to 1 ohm/1100W. Anyway...
Seems you want to lessen the wattage output of the amp by making a 4 ohm load. To do that, you need to wire the both 2 ohm speakers in SERIES.
In general wiring principles, to wire in SERIES, take the POS terminal from the amp and wire to the POS terminal of first speaker. Take the NEG terminal from the amp and wire to the 2nd speakers' NEG terminal. Then place a "jumper" piece of speaker wire to connect 1st speakers' NEG terminal to 2nd speakers' POS terminal. Now you have a 4 ohm load, and will be pushing 450W from your amp.
This way the load will now be 4 ohms.
Jan 08, 2013 | Kicker DCVR122 -- 2 Ohm Dual 12in CompVR...
More clarification on the original question sub connection have no markings as + or - red or black nothing need to know which is what on these 12 dvc visonik subs if you put upside down which side is +...
To be absolutely sure of which terminal is positive and which is negative, we will use a 1.5 v battery to have the speaker react as though it is playing music.
* special note * do not use any more than 1.5 v as it may damage the speaker coil
As we know, batteries are marked positive, negative, or both ... we will use this to our advantage when hooking up the battery to our speaker.
To start the process, temporarily attach a short piece of wire to each terminal of the speaker (be sure to either use wire that is marked, or wire of differing colours to help determine which terminal is which).
In our example, we used standard speaker wire which is "polarized" (one wire is made of copper and the other is made from tin .. interestingly, this serves no electrical purpose)
Once you have connected the wire to your speaker, proceed to briefly touch the free ends of the wire to the battery terminals (as shown below). In some cases, extended contact with the battery has caused cancer of the voice coil (ie. blown speaker)
If the speaker moves OUT when the battery is first connected, the battery is connected in proper alignment. Be sure to take note of which wire is connected to the positive terminal of the battery as this is your speaker's positive terminal.
Aug 08, 2012 | Visonik Car Audio & Video
Peavy 112 monitor,1 yellow and 1 blue wire going to speaker .Which is positive,and negative?Thanks:)
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica; color: #1a1a18}
The wire which is coloured and yellow must be connected to the terminal which is marked by the letter E, or by the earth symbol.
The wire which is coloured blue must be connected to the terminal which is marked with the letter N, or coloured black.
The Yellow coloured wire is going to be the positive, and the Blue wire is going to be negative wire.
Jul 18, 2011 | Audio Players & Recorders
How do I program the Executone model 64 LCD to
I assume you mean change the time and date and that depends on which system model you have....assuming you have an "IDS"...go to the receptionists phone ( the phone you reach by dialing 0 or 3001/ 301 ) and without lifting the handset dial 28 followed by the time in military format...if it worked you'll hear a few quick beeps after inputting the time. You might have an Executone Medley...if so > http://www.mainresource.com/PDFs/TipsMedleySysAdmin.pdf
If you have an older version of IDS you need to program it via a programming terminal or laptop. Leave your email here if you get this and I'll email you - can do it remotely via built in modem.
May 14, 2010 | Executone 64 Corded Phone
Wiring colours
Not sure of your setup re hedunit.
the plug from the old sterio should have the following:
Black- Earth
Red - ignition (only supplies 12v when key is in the ACC position.
Yellow green (12v all the time) even if key is in the off position)
you can check the speakers by using a 9v battery and QUICKLEY toutching the wires on the terminals to distinguish what two wires run to what speaker.
Then use the same sequance for wiring the headunit making sure thar all the solid colour wires are used as the positave connection for the individual speaker wires.
Dec 05, 2009 | Car Audio & Video
Amp pushing speaker outward and makin a humming sound when I attach speaker wire to terminals.
how many watts is the amp and how much wattage can the speakers handle?
sounds like you may be pushing to many watts to the speakers
Aug 16, 2009 | Alpine MRD-M1005 Car Audio Amplifier
I have an M&S system DMC1 intercom and sound system.
It really depends on what speakers you have in the ceiling. There are several different models. Do the speakers not work at all now? There is a power amplifier for the DMC1 that will give you Stereo
May 02, 2009 | M&S Systems M & S SYSTEMS DMC1CDB Whole...
Need to know how to wire Alpine 12" 1242D 4ohm Want to use 1 speaker in ported box with Phoenix gold 2200pro amp
As long as the total wattage of the amp does not exceed the total wattage of the speaker, you can bridge the amp. To do this, put the positive wire of the speaker on the positive terminal of channel 1 on the amp, and the speaker negative wire on the negative terminal of channel 2. This allows you to run the amp's full power into one speaker.
Aug 02, 2008 | Alpine Car Audio & Video
Wiring diagram for Altec Lansing Vs4221 Right Speaker Wire
red-positive . blue-negative and if another colour mostly brown-Earth.
Jan 15, 2008 | Altec Lansing VS4121 2.1 Channel Powered...
2004 Mustang Factory Wiring Diagrams Logo
153 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
