Question about Drills
How to remove drill chuck
Black@ decker 3/8 drill mod 1180-1 remove chuck to replace holders
  • 31 Answers
Screw in side Has Left hand threads
Posted on Jan 17, 2014
4 Suggested Answers
  • 16 Answers
SOURCE: HOW DO I LOOSEN A KEYLESS CHUCK TO REMOVE A DRILL
Keyless chucks normally have a knurled ring at the base of the chuck that you hold in one hand while turning the large knurled taper with the other. If the chuck has been overtightened, and you cant open like this, try using two stilson wrenches (Pipe wrenches) one on each of these parts. Use a soft cloth in the jaws to avoid damaging the knurling. You can also try some Q20 or similar into the chuck to help lubricate it.
Posted on Jun 15, 2009
  • 583 Answers
SOURCE: Cordless Drill, Keyless Chuck stuck in full open position.
if chuck is wide open ,look down inside there should be an allen screw or bolt at the bottom of the chuck it should undo anti clocwise and the chuck comes off
Posted on Aug 18, 2009
woobie dog
  • 1273 Answers
SOURCE: Black and Decker Cordless Drill Chuck stuck in full open position
I'd put penetrating oil in it and tap the chuck with a plastic hammer. That should free it up.
Best rgrds, W/D
How to remove a dr200 BLACK & DECKER 3/8" DRILL CHUCK, no chuck screw in chuck
Hi- We have instructions on how to remove the chuck listed on our website Q&A. I have included the link. Please use the instructions for the Keyed chuck. blackanddecker com
Thanks Black + Decker Customer Care
Mar 18, 2015 | Black & Decker Drills
Black & Decker cordless drill 9.6V chuck will not come off shaft
If it won't close the only other option you have is to break the outer collar and use a chisel to hit on the exposed jaws inside the chuck. I have detailed instructions in the tip section on how to remove a chuck from these drills. Let me know if you need more assistance.
Jan 31, 2012 | Black & Decker Drills
New Black and Decker, 18 volt, cordless drill. I can't tighen the bit
I oil mine up to help the jaws move . also check the screw at the base of the chuck inside its a standard head. shine flash lite where you put the bit it holders the Jacobs chuck to the shaft.
Jul 07, 2011 | Black & Decker & Cordless Drill
The chuck is frozen on my 14,4 Black and Decker cordless drill. This is the second time that has happened with a Black and Decker drill so I assume it is a product defect. In use it was not that...
Yes, they are an inferior product. However you can replace the B & D chuck with a Jacobs chuck that will hold up and last for a long time!
Jacobs Chuck
heatman101
May 23, 2011 | Black & Decker Drills
How do I exchange bits in the keyless * BLACK & DECKER 12-Volt 3/8" Cordless Drill
In Black and Decker drills when the drill stops turning the chuck spindle locks automatically. All you have to do is grip the outer sleeve of the chuck and turn it anti clockwise to open it. Turn it clockwise to close it. When you press the trigger to start drilling the spindle unlocks automatically again.
Jan 10, 2011 | Black & Decker Garden
How to remove the chuck of Black & Decker Drill BD154R?
You need to open the chuck and remove the bolt from the bottom of it[usually a #2 phillips].The next step is to insert a 5/16 allen wrench into the chuck and tighten the chuck.Hold the drill with the chuck facing away from you then strike the allen wrench with a hammer on the right side[so it goes down] and now you will be able to remove it by hand,good luck.
Mar 21, 2010 | Rotary Ryobi 1/2" Hammer Drill ZRD551HK
Replacing the chuck on black & decker drill
remove the chuck retaining screw LH thread, and then find a bent handle allen wrench about the chuck capacity and insert the shorter piece in the jaws and tighten, Shift the tool to the low position (if it has one) and the selector to drill only (if it has one) position the chuck on a block of wood at about a 30 degree angle so you can strike it counter clockwise and hit it with a hammer, it might take a couple times but it will come off. Reinstall in reverse order,
Oct 10, 2009 | Black & Decker Drills
Black decker drill keyless chuck won.t open !
hold the back of the chuck with channel locks or a vice and use the same channel locks on the front and open the chuck manually it should work and you can get to the screw to replace it or the hand chuck. this can be a little frustrating but hang in there and you'll be a pro shortly.
Sep 02, 2009 | Makita Usa Inc No.8390DWPE 18V Crdls...
Keyless Chuck how do you change the bit? Model
hold outside collar on chuck firmly with your hand and reverse drill
Jul 10, 2009 | Black & Decker 3/8" Variable Speed...
Black & Decker Impact Drill. Mod. 7277 type 3
If you say that the chuck can not be tighten only, then I would say that the left thread screw that keeps the chuck to the tool have become unloosen and can not allow the chuck to be tighten. The remedy for that is to unloosen the chuck as much as you can, then tight the left thread screw but rotating it left till the bottom and then the chuck will work. All the above if the chuck can not be tighten...
Mar 23, 2009 | Black & Decker 18V Drill / Impact Combo
Drills Logo
73 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
