Question about General Electric WCVH6800J Front Load Washer
Cannot get into test mode for ge front loader wcvh6800j1ww
Wcvh6800j1ww leaking under soap dispenser
Three screws at the back of cover, three screws at the front, push the cover back and you can remove it. 1 screw at the front of the soap drawer and two more on the dispenser and you can lift the whole unit up.
Sep 24, 2012 | GE WCVH6260F Front Load Washer
GE washer WCVH6800J1WW - fabric softener doesn't empty
see the causes and remedies:
It spins, but doesn't pump
drain lines clogged, repair+sock in outer tub port, if the lines is not clogge the problem is pump replace
It doesn't spin or pump
frozen pulley pump, replace
It pumps, but the water returns improve the draininin laundry, if have reaches 4 inches cut off the excess. if is lower install air/gap siphon break assembly.
God bless you
Jul 18, 2012 | Washing Machines
GE Washer model #wcvh6800j1ww stops in mid cycle and the start/pause button flashes?
Try to clean the discharge pump filter first (Instructions on page 13 of the Use/Care manual).
If the drain pump is working, it's most likely related to the pressure switch. Check out these postings:
http://www.fixya.com/support/t9807344-ge_front_load_washer_stops_45_min_35_min
http://www.fixya.com/support/t8933273-general_electirc_washer_model
Do a diagnostic test -- Easy and free, and the machine will likely diagnose its own problem. Instructions in those postings.
Post back any code you find and we'll go from there.
Aug 20, 2011 | General Electric WCVH6800J Front Load...
Any way to do a factory reset of the control panel of a GE Washer WCVH6800J1WW?
the only way to do a reset on this unit is to unplug while powered on, let me know how it goes,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | General Electric WCVH6800J Front Load...
Our GE washer model #: WCVH6800J1WW is overfilling and it won't wash anything we have already replaced the pressure switch and the control pannel and still nothing. Please help.
When you replaced the pressure switch, did you fully test the pressure switch hose?
Here's a similar posting that explains a potential issue and how to troubleshoot:
I highly recommend doing a diagnostic test because it's free and easy. Most of the time, the washer will self-diagnose. Check out that posting for instructions on how to do the tests.
Feb 26, 2011 | General Electric WCVH6800J Front Load...
My front load GE washer would not drain . balance looks fine. pulling the power source and replugging did not help WCVH6800J1WW Serial IS205695T -
if this washer has a control board on top of motor try opening the lid six times within 6 seconds... then start washer .... if it does have board ontop of motor look at board is green indicator lit up if not replace fuse link white wire with red line threw it from motor has a one time fuse link in wire replace fuse link or jump across to test
Jan 24, 2011 | GE WJSR2070B Top Load Washer
WCVH6800J1WW GE Washer error codes
need same solution, please post
Mar 03, 2010 | GE Washing Machines
General Electric WCVH6800J Front Load Washer Logo
42 people viewed this question
Top General Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Chris Goulet
Are you a General Washing Machine Expert? Answer questions, earn points and help others
