Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
My all-pro torpedo with about (20 hrs use)heater was in a flood. I need one & money is tight, so I'm trying to fix this one. The igniter glows bright & then I hear a noise like the motor is ab
It has sat for over a year so it is dried out. There is some rust in the tank I rinsed it out as much as possible with kerosene. I have taken it apart and wiped it down except photo cell, and filters. Im not an expert but I am capable of troubleshooting anything with good info.
  • 451 Answers
The electric motor may be rusted tight. Spray it with WD 40 or other penetrating oil to see if that loosens it up. Make sure motor spins freely. Hope this helps.
Posted on Dec 29, 2013
  • 193 Answers
SOURCE: will not fire
this unit operates with a small air compressor at rear of motor. Remove the solid 1/8 inch plastic plug. install a low pressure gage. you should read around 5 psi
Posted on Sep 25, 2009
  • 193 Answers
SOURCE: Hi, I need parts for a kerosene torpedo heater.
You need to call Portable Heater Part in Valparasio,in for replacement parts
Posted on Oct 18, 2009
SOURCE: master 110 torpedo heater will not start , kerosene type
open the vac pump off back of motor, clean and lube vanes and reassemble. your vac pump is stuck.
Posted on Dec 01, 2010
mxc2
  • 146 Answers
SOURCE: I have an All Pro
First thing is to download the service manual.
http://www.desaparts.com/service_manuals.html
You need to make sure the filters are clean and that you are getting the proper air pump pressure.
If the units starts up and runs good and slowly goes out it will normally be due to a lack of fuel getting to the nozzle. When there is not enough fuel being delivered to the nozzle from either a clogged fuel filter of dirty air pump output filter the unit will slowly shut down from lack of fuel.
If the unit shuts down while it is running properly and the nose come is orange then you probably have a problem with a photocell or the flame out control.
If you have other questions you can contact our service department at 269-685-4125 at extension 224
Thanks
M Cramer
www.allpartsinc.com
Posted on Jan 05, 2011
heatman101
  • 43501 Answers
SOURCE: i have a 150000 master
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Jan 16, 2011
Propane torpedo lights but doesnt stay lit
I'm confused. First you listed this as a propane torpedo heater. Second, it's a problem with and All Pro PK115 T Forced Air Kerosene Space Heater. And finally, you say "propane torpedo lights but doesn't stay lit."
Which is it? To really help you, I'll need the correct manufacturer's name & model number. And whether it's propane or kerosene fired?
Thanks.
Mar 02, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Heater blows smoke out front, wont ignite...please help!
Two things cause it ,No fire at Spark plug or low air pressure
Jan 22, 2011 | Reddy Kerosene Heater with Thermostat:...
It is kerosene, it ignites, runs from 1 - 5 minutes and loses flame
heatman101
Dec 14, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
Top All-Pro Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Mack Baxter
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
