Question about Rival 8420-TB 4 Quart Ice Cream Maker
Paddle not rotating
Can turns but not the paddle......is this right?
The paddle is supposed to scrape the frozen mix off the inside of the can as it turns. So yes, that sounds right.
Posted on Jan 03, 2008
Is the paddle supposed to spin
Your paddle won't turn. Your silver bucket is the one moving (turning) and not the paddle. It's working like it should. I thought the same before I found the lid (cover).
Jan 11, 2013 | Back to Basics -- Plastic Bucket Ice Cream...
The paddle in my new 1.5 L ice cream maker is not turning - is this normal?
Hello Maryo803,
It is not normal for the paddle not to move in these units. First we have to determine weather the paddle is striped or the gear is stripped. At the bottom of the paddle there is a hole that attaches to the turning gear on the machine. Look and see if it still matches the sprocket in the bottom of the ice cream maker. If it does not still match I would suggest buying a new paddle. You can purchase a new paddle from Cuisinart for $8.00 and here is a link to the page. http://www.cuisinart.com/parts/ice_cream/ice-20.html
However, if it is not the paddle please post back to this thread and I will see if it is worth changing out the bottom gear.
Thank you for choosing FIxYa.com
Justin
Mar 11, 2011 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Paddle is not turning when pluged in and tyrned on.
Be sure the little gear is inserted between the paddle and the motor. I have found that it falls out of the motor and then out of the paddle if you are not watching._437.jpg
Dec 10, 2010 | Krups 358-70 La Glaciere 1.5 Quart Ice...
Dose the paddle inside the pot turn? the pot is turnning but not the paddle.
The paddle is stationary while the pot turns the ice cream to mix the cream.
Jun 30, 2010 | Rival 8804-BL 4 Quart Ice Cream Maker
When plugged in& on cylinder turns but paddle
... as it should
When making ice cream,make sure your ice is crushed fine and you use enough rock salt.
Sep 27, 2009 | Maximatic Elite 4 Quart Ice Cream Maker
Paddle does not move. Machine is about two years old.
sometimes the brushes take a set when unused.. Unplug the motor. Without using rnough pressure yo break anything, try turning the motor by hand using the paddle. You will be trying to turn the motor through ithe gesrs so use slow steady moderate pressure. This does work. as long as you watch what you are doing wiyh yhe force you apply. Good Luck. and enjoy the ice cream
Sep 07, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Is the paddle supposed to turn all the time?
This just popped up on my screen. Are we talking about a ide cream maker? IF yes ... generally, the can revolves around the paddle. The paddle doesn't move.
Hope this helps.
Sep 06, 2009 | Magimix 2200 Gelato Chef 1.03 Quart Ice...
Mixing arm/bowl will not turn once machine is turned on
The only thing I can really suggest is to make sure the easy-lock button is fitted into the right place on the lid, and to make sure that the ice cream mixture is not too thick. But, if the turning paddle is locked into place properly, and the mixture is still in liquid form, then there is a problem with one of several parts - could be the metal sliding switch or even a motorized part. These parts cannot be replaced. It is worth a shot to replace the mixing paddle - the unit has a 3-year warranty, so I would Call Cuisinart to get the part instead of ordering it online - they may or may not give it to you for free. If the new mixing paddle still won't spin, get the unit replaced either thorugh the store (depending on the store -each has a different policy) or get it replaced directly through Cuisinart. This model is actually pretty solid, so a second one shouldn't give you any problems.
-Tha Mp3 Doctor
Mar 05, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
I purchased a rival ice cream maker. I used it once and the ice cream came out great. The next time I used it the paddle didn't turn and the ice cream and paddle was frozen to the sides of the can. The...
The tub turns around the dasher(paddle). You live in a high humid area... to much ice and salt around outside. Plus you need to age the ice cream a few hours after mixing. See your book.
Jul 07, 2008 | Rival 8550-X 5 Quart Ice Cream Maker
Motor runs, but paddle doesn't turn
groove has worn out replace it if you can get parts.good luck.
Sep 28, 2006 | Krups 358-70 La Glaciere 1.5 Quart Ice...
Rival 8420-TB 4 Quart Ice Cream Maker Logo
258 people viewed this question
Top Rival Ice Cream Makers Experts
Dan Webster
Dan Webster
Stan Skaggs
Stan Skaggs
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Rival Ice Cream Maker Expert? Answer questions, earn points and help others
