Question about Eureka Smartvac 4870 Bagged Upright Vacuum
Roller brush spins
My problem is my roller brush still spins even when it's in the locked upright position, causing burns in my rug. What do I need replaced to resolve this issue?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 22 Answers
The roller brush will turn as long as the sweeper motor is running no matter what brand you have. Turn it off as you return it to the upright position.
Posted on Dec 30, 2013
4 Suggested Answers
yeroc
  • 397 Answers
SOURCE: Eureka Maxima Bagless brush not spinning in vacuum position
belt doesnt have to be broken, check the metal arm on the vacuum, see if there is build up of old rubber from previous belts, clean the arm that spins the belt and double check to make sure u have the correct belt
Posted on Jan 20, 2008
  • 5 Answers
SOURCE: eureka 4870 roller only spins in upright
if the belt has been slipping it may have pollished the moteror brush shaft and it just slips. take a small piece of sand paper or enery cloth and ruffen up the shaft to give it some grip.
if the metal shaft of the motor has been heated up due to slippage it will take some doing to ruffun it as the shaft will be hardend due to heat
Posted on May 14, 2009
SOURCE: My eureka 5902 4D bagless uprights roller brush
The same thing happened to me about a year ago with this very model.
The issue on mine was a small, copper-colored metal wheel that attaches to the end of the brush roller. You'll need to remove the top cover (there are several screws).
Once it's off, you should see the belt, the beater brush, and the metal gear. The gear didn't fit correctly - so the motor just spins without moving the brush. I ended up going to the store and buying superglue that withstands high tempuratures, then gluing the gear to the motor's shaft... and hammering the thing into place before the glue 'set' too much. ...Not fun, but it's working and has been ever after. I can take photos of the thing if need be.
Posted on Jan 03, 2010
How do I fix my vacuum the brush will not spin
Lubricate each end of the roller brush with motor oil. Bearings inside the roller brush need lubrication for the brush to turn easily. Remove any pieces of thread that have wrapped around the roller brush. If it does not spin after doing the above steps, then either the belt is slipping or the bearings are severely damaged in the roller brush. Then you need either a smaller belt or a new roller brush.
Apr 26, 2015 | Dirt Devil UD40270RM Quick Power Compact...
I ran over a big floor rug with my vacuum and some of the strings from the rug got tangled in the roller on the vacuum. It makes a terribly loud noise even now after I have cleared the strings from the...
You will need to pull the roller out and clean it. I think some of the strings are tangle up at the end of this roller. (Most rollers will come apart at the end for cleaning.) Make sure that the strings are not tangle up on the belt pulley as well. I hope this will help you.
Jan 25, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
The problem started when i sucked a corner of a rug,now it will not **** very much at all??Kenmore upright progressive
This definitely sounds like your belt is broken. The belt is the part that is attached to the motor at one end, and to the roller brush at the other end. If something gets vacuumed up into the brushes that prevents the brushes from spinning, the motor will continue to try to spin the belt, and the motor shaft will then burn right through the belt, or cause the belt to fall off the motor shaft, preventing the brushes from spinning. On an upright vacuum cleaner, if the brushes are not spinning, it will seem like the vacuum cleaner is not sucking well, but in fact the brushes are just not spinning.
To see if the belt is your problem, while the vacuum is plugged, in turn the machine upside down so that the brushes are facing upwards. Make sure that if your machine has a rug/ floor setting that it's set to carpet mode, and now turn the machine on. Does the brush spin? If no, then this is because the belt has either broken, or stretched out so much that it no longer can spin the brushes.
Here's a link to the owners manual for your Kenmore that will walk you through, step by step on how to to replace the belt.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0403213.pdf
I have also uploaded the instruction manual to the main page on Fixya for your Kenmore 34612.
I really hope this helped you. If it did, please help other people who have this vacuum be able to find this repair on Fixya by rating the repair helpful. You may do this by clicking the 4 thumbs up icons in the right hand corner of the repair. If you have any questions about how to replace the belt, or if the belt is ok and something else is wrong, please just use the clarification request form here on Fixya, and I'll be happy to answer any follow up questions that you may have.
Thanks again,
Chris J.
GoVacuum
Apr 09, 2010 | Kenmore 34612 Bagged Upright Vacuum
Brushes will not turn
Look for something wedged between the belt and the turning components. The smallest thing can cause a lock down. Make sure hair is not wrapped around rollers causing it to tighten up at bearing sufaces.
Jul 08, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Brushes won't turn and vacuum will not pick up sprayed cleaner
There's a Capt. Obvious fix to check before you go any farther. Like many vacuum cleaners, the brushes on the Bissell carpet cleaners, by design, only spin when the handle is not locked in the upright position, so be sure to plug it in, turn it on, and depress the foot pedal to lower the handle while watching the brushes one more time to be sure that the fix isn't that easy.
If the brushes still won't spin with the handle in the unlocked position, lift the handle back up into the locked position, power off and unplug the Bissell, and look down and see if either of the two belts that make the brushes spin are broken, as a broken belt, or a belt that's come off the track, is the next most likely problem. Both belts must be unbroken and in the right place for the roller brushes to spin.
These belts can be seen in the clear plastic pieces on either end of the roller brushes. If you're having trouble locating them, **with the Bissell unplugged so the brushes won't suddenly start spinning and hurt your hand**, try spinning the brushes with your fingers while watching for the belts. They're black, about the thickness of two quarters, and the bigger one of the two (on the left end of the roller brushes, as you face the front of the Bissell), is just big enough to fit around both roller brushes. The smaller belt, goes around the back roller brush on the right and to a smaller cog wheel behind it. If you see a broken belt, or a belt off the track, that's your problem.
Here's a video you can watch for free on Bissell's website that tells how to replace a belt. I'm sure the belts can be ordered online somewhere or found at some Bissell dealers or repair shops. Note, again, the two belts are different. If only one is broken, be sure to order the correct one.
http://cache.vendaria.com/vpop/VpopV6.html?ct=13&ctname=CT630X556D630X390&fw=630&fh=556&logo=49&fv=10&ap=vnd_bissell_change_belt_proheat_2x&purl=MAIN_bissell_change_belt_proheat_2x&iid=sbpgzLIuvIlJlJquLvumgwqKqvIqvv&bg=ffffff&nm=BZOpener&curl=&err=0&title=Bissell&tp
If the belts are intact and in the right place, does the metal cog wheel behind the roller brush right turn when the Bissell is on and the handle is dropped? If not, then the motor that turns that cog wheel must be burned out.
Jun 08, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Oreck XL was working fine, then when I vacuumed a shag rug is started smoking and smelled like something is burning. (I changed the bag, checked for clogs--none found, and roller brush is turning. It...
Even though the brush is spinning, the belt is probably worn out and stretched. when you vacuum the shag carpet, it puts more drag on the brush. try running it on a shorter carpet or hard floor for a few minutes. if it doesn't smoke, then you know it's your belt. if it does smoke, then it's probably the motor burning up.
Jim
Jun 02, 2009 | Oreck XL2000 Bagged Upright Vacuum
Beaters stop when vaccuming rug...didn't when new
I believe you need to change the belt that drives the brushes. When it gets stretched out, it will just spin on the axle of the motor or spin on the brush and smoke.
Jim
Jun 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Bottom roller bush does not spin
Sounds as if the v-belt came off the idler arm or you broke the v-belt. Either way, take the 4 screws out of the plate around the roller brush and make certain the belt is there and that it sits on the idler wheel. If you remove the roller brush you'll see the wheel. Pay attention to how the ends of the roller brush go back into the vacuum when inserting it and put the plate back on. Also check the thicker main belt is in place as well, it's to the left of the v-belt.
Also, the roller brush should stop when you put it in the upright position. Next time just stand it upright so the throw rug doesn't get drawn quite so far into the vacuum.
Dec 19, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuum roller stops at half tilt.
You need a new belt. Belts will stretch to the point that they won't turn the brush roll under load, they will just slip. Check the brush when you change the belt to make sure the ends turn easily, if not, then replace it also.
Apr 22, 2008 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka Smartvac 4870 Bagged Upright Vacuum Logo
79 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
