Question about CRL 1986 Honda Accord Headliner and Cowl Fastener
Broken abs plastic vent
I am attempting to repair an abs cowl vent panel and it has some distortion around the broken out guide pin. how can i restore the deformed area. should i do this before or after i use adhesive to piece it back together
  • 465 Answers
Heating the plastic with a hair dryer may make it piable enough to straighten the deformed area but be vary careful not to overheat the area because you may make the deformation worse. If it is ABS plastic you should be able to use abs cement for plumbing piping to glue any pieces back together. Best of luck on your project.
Posted on Dec 29, 2013
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Side panel of the seat has come loose
Panels are held in place by plastic "pins" (to use your words) that are held in place by the shape of the part it is being pushed into.
Either the pin itself is broken, the part holding this plastic pin is broken, or the other piece being pushed into is broken or cracked such that it can't hold the pin in place.
Inspect both the side panel and the part it connects to. Replacement pins can be purchased from an automotive store or a salvage yard. If the receiving end is broken, you may be able to repair with glue or other type of bonding material.
Feb 09, 2014 | Vehicle Parts & Accessories
Looking for cabin filter
  1. From inside vehicle, release hood.
  2. Remove four quarter turn nylon push pins retaining RH cowl vent screen
  3. Remove push-on clips retaining RH cowl vent screen and remove RH cowl vent screen from vehicle.
  4. Remove two screws and remove cowl top inner panel shield from vehicle.
  5. (RH IS THE PASSENGER SIDE THE COWL IS THE PLASTIC PIECE AROUND WHERE THE WIPER BLADES ARE)
Dec 03, 2010 | 1999 Ford Taurus
93 silverado 2500need free online mechanical diagram of doors
GM Full-Size Trucks 1988-1998 Repair Information Doors - REMOVAL & INSTALLATION
R/V Series
See Figures 1, 2 and 3
If the door being removed is to be reinstalled, matchmark the hinge position.
  1. If the door is to be replaced with a new one, remove the trim panels weathersheets and all molding.
Fig. 1: Door hinge-R/V Series
  1. If the door is to be replaced with a new one, remove the glass, locks and latches.
  2. If equipped with a wiring harness, remove the trim panel and disconnect the harness. Guide the wiring out of the door.
  3. Support the door and remove the hinge-to-body attaching bolts. Lift the door from the truck.
  4. Install the door.
  5. Perform the alignment procedures indicated below.
Fig. 2: Door hinge components-C/K Series
Fig. 3: Removing the hinge spring
C/K Series
  1. On trucks with power components in the door, disconnect the battery ground cable.
  2. On trucks with power components in the door, remove the cowl side vent cover.
  3. On trucks with power components in the door, disconnect the wiring going to the door, under the dash panel. Feed the wiring through the door pillar.
  4. Cover the door hinge spring with a heavy towel. Using tool J-36604 or its equivalent, insert the blades of the tool between the spring coils and turn the barrel nut to compress and hold the spring. Remove the spring using the tool.
  5. Remove the lower hinge pin retainer.
  6. Using a plastic or rubber mallet and locking pliers, remove the lower hinge pin.
  7. Install a bolt through the lower hinges to hold the door while removing the upper hinge pin.
  8. Remove the upper hinge pin retainer.
  9. Remove the upper hinge pin.
  10. Support the door and remove the bolt from the lower hinge.
To install:
  1. Position the door and install the bolt in the lower hinge.
  2. Install the upper hinge pin. with the pointed end up.
  3. Install a new upper hinge pin retainer.
  4. Remove the bolt from the lower hinges.
  5. Install the lower hinge pin with the pointed end down.
  6. Install a new lower hinge pin retainer.
  7. Using tool J-36604, install the hinge spring.
  8. On trucks with power components in the door, connect the wiring going to the door, under the dash panel. Feed the wiring through the door pillar.
  9. On trucks with power components in the door, install the cowl side vent cover.
  10. On trucks with power components in the door, connect the battery ground cable.
ADJUSTMENTSee Figure 4 The holes for the hinges are oversized to provide for latitude in alignment. Align the door hinges first, then the striker.
C/K series utilize hinges that are welded to the door and frame. No adjustment is possible except when replacement hinges have been installed.
Fig. 4: Door adjustment check points
  1. If a door is being installed, first mount the door and tighten the hinge bolts lightly.
If the door has not been removed, determine which hinge bolts must be loosed to effect alignment.
  1. Loosen the necessary bolts just enough to allow the door to be moved with a padded prybar.
  2. Move the door in small movements and check the fit after each movement.
Be sure that there is no binding or interference with adjacent panels.
  1. Repeat this procedure until the door is properly aligned.
R/V Series:
Door edge-to-rocker panel: 6mm Door edge-to-roof panel: 5mm Door edge-to-rear pillar: 5mm Door edge-to-front pillar: 2mm
C/K Series:
Door edge-to-rocker panel: 6mm Door edge-to-roof panel: 6mm Door edge-to-rear pillar: 4mm Door edge-to-front pillar: 7mm Door front edge-to-fender: 5mm
  1. Tighten all the bolts to 26 ft. lbs. (35 Nm).
Shims may be either fabricated or purchased to install behind the hinges as an aid in alignment.
Hope this help, TY for using Fixya (remember comment and rated this). Good luck.
Apr 01, 2010 | 1994 Chevrolet Silverado 2500
Where is the cabin filter located
The cabin air filter is located directly underneath the cowling at the base of the windshield on the passenger side of the car.
To access the cabin air filter, you will need to remove the cowling. First, open and lift the hood. Second, locate two plastic pins securing the plastic cowling at the base of the front windshield, on the passenger side. One is located under the wiper blade, near its base. Use a small screwdriver or similar tool to carefully lift/pop up two plastic pins securing the cowling, taking care not to damage the plastic pins. (You want to lift the pins, and not the anchors that look like washers beneath the heads of the pins. Carefully pull the plastic pins and their plastic anchors (once you pull the pin up, you can safely remove the anchor). Take caution not to damage the pins and anchors as you will need them to rescure the cowling when you are finished replacing the cabin air filter.
Before you remove the cowling, carefully pull back the rubber gasket and windshield washer fluid tubing at the base of the cowling. You can now safely remove the cowling, and you will see the cabin air filter below.
Remove the old cabin air filter and replace it with a new filter.
Reverse this process to reinstall the cowling, gasket, and pins once you have replaced the filter.
Oct 16, 2009 | 2005 Pontiac Grand Prix
Ford Taurus 1999SE-Windshield wiper motor just hums.How to fix ?
Removal & Installation To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Disconnect the battery ground cable.
  3. Remove the wiper arms.
  4. Remove the 8 plastic retainers and the 6 clips holding the cowl vent screens to the inner panels. Turn the retainers 1⁄4 turn counterclockwise to remove.
  5. Remove the cowl vent screens.
  6. Disconnect the electrical connector from the wiper motor and remove the 4 bolts that mount the module assembly to the cowl.
  7. Remove the windshield wiper module from the vehicle.
  8. Rotate the wiper operating arm in a clockwise direction to gain access to the bolt retaining the arm to the motor. WARNING
    Always rotate the wiper operating arm in a clockwise motion or damage to the motor could occur.
  9. Remove the nut retaining the wiper operating arm to the wiper motor.
  10. Remove the three wiper motor-to-wiper module assembly retaining bolts and remove the motor from the vehicle.
To Install:
  1. Position the wiper motor on to the module assembly. Install the three wiper motor-to-wiper module assembly retaining bolts. Tighten the bolts to 115-151 in lbs (13-17 Nm).
  2. Position the wiper operating arm on the wiper motor output shaft. Install the mounting nut and tighten to 22-29 ft-lbs (30-40 Nm).
  3. Position the windshield wiper module onto the cowl. Install the mounting bolts and tighten to 106 in-lbs (12 Nm).
  4. Connect the wiper motor electrical connector.
  5. Position the cowl vent screens onto the inner panels. Install the 8 plastic retainers and the 6 clips holding the cowl vent screens to the inner panels. Turn the retainers 1⁄4 turn counterclockwise to install.
  6. Install the wiper arms.
  7. Connect the battery ground cable.
  8. Adjust wiper arms if necessary.
Here is the picture of the motor....it is the round object in the middle of the picture that looks like a can and has a square block on the end of it.
You have to remove the cowl vent panel....just under the windshield. $64.00 for a new motor.
Oct 01, 2009 | Ford Taurus Cars & Trucks
Dometic rm2804 door hinges are worn and plastic strip retainer is broken off. On the lower door the hinge pins fit into round metal guides. In turn, the metal guides are held in place on the door corners...
I had this problem. I reversed the decorative plastic strips, both ends of the strip have hinge pin holes, so the doors can open left or right. I put the TOP decorative plastic strip on the bottom and BOTTOM on top.
Jun 25, 2009 | Dometic Refrigerators
Leak at bottom of water expansion tank on 2001 s-type se
SECTION 303-03: Engine Cooling 2001 Lincoln LS Workshop Manual REMOVAL AND INSTALLATION Degas Bottle Removal and Installation
  1. Drain the engine cooling system. For additional information, refer to Cooling System Draining, Filling And Bleeding in this section.
  1. Remove the cowl vent screen. For additional information, refer to Section 501-02 .
Cowl Vent Screen Removal
NOTE: To remove the left side cowl vent screen, the right cowl vent screen must be removed first. Follow the entire cowl vent screen procedure.
Right Side Only
  1. NOTE: The fasteners are reuseable.
    Remove the right side of the cowl vent screen.
    1. Remove the two-part pin-type retainers and separate the Velcro ® attachment of the rubber hinge cover to the rear outboard corner of the cowl vent screen.
    1. Pull up on the cowl vent screen to release the lower clips.
Entire Cowl Vent Screen
  1. Remove the two wiper pivot arms.
    1. Remove the two pivot arm nut covers.
    1. Remove the two nuts.
  1. NOTE: Remove the right side first when removing the entire cowl vent screen.
    1. Remove the two-part pin-type retainers and separate the Velcro® attachment of the rubber hinge cover to the rear outboard corner of the cowl vent screen.
    1. Lift up on the cowl vent screen to release the clips.
  1. Disconnect the engine vent hose, and separate the air bleed hose from the degas bottle.
  1. Remove the seven bolts and reposition the cross vehicle support.
  1. Disconnect the degas return hose from the degas return tube.
  1. Remove the two bolts.
  1. Remove the degas bottle from the vehicle.
Apr 12, 2009 | 2001 Jaguar S-Type
Producing distorted images when zoomed
Barrel ether missing guiding pin(s) or broken plastic guides. Parts are available only as a whole Zoom Block Assembly.
Mar 18, 2009 | Kodak EasyShare P850 Digital Camera
Cabin air filter
it;s under the cowl vent panel.
Cowl Top Vent Panel Removal
  1. Remove the windshield wiper pivot arm (17526) . Refer to Section 01-16 for the removal procedure.
  1. Remove the front door weatherstrip (20530) to access the windshield outside side moulding screws.
  1. Remove the five windshield outside side moulding screws and the windshield outside side moulding (03136) .
  1. Pull the windshield outside moulding (03144) from the windshield glass (03100) .
  1. Remove the three Phillips-head screws from the cowl top vent panel (022A68) .
  1. Remove the three plastic screws by turning them 90 degrees to unlock.
  1. Remove the six pushpins from the front edge of the cowl top vent panel .
  1. Lift up on the cowl top vent panel and disconnect the windshield washer hose (17A605) at the Y-connector.
  1. Remove the cowl top vent panel .
Mar 15, 2009 | 1998 Mercury Villager
ROVER MGF.REMOVING WIPER MECHANISM.
Pivot Shafts and Linkage
The windshield wiper assembly is mounted below cowl top extension (021A36) . Linkages are connected with non-removable plastic ball joints. Windshield wiper mounting arm and pivot shafts are an integral part of the windshield wiper and are serviced as one unit. Removal
  1. Disconnect the battery ground cable (14301). Refer to Section 14-01 .
  1. Remove antenna mast from the antenna base.
  1. Remove cap on LH and RH windshield wiper pivot arms to expose nuts retaining the arms to pivot shafts.
  1. Remove two nuts, one from each of windshield wiper pivot arms . Lift wiper arms to service position, carefully rocking them back and forth to loosen them from the pivot shaft. Lift off windshield wiper pivot arms .
  1. Remove seven screws retaining the cowl top vent panel.
  1. Disconnect windshield washer hose (17A605) at LH side of vehicle just ahead of where it enters cowl top.
  1. Remove hood cowl seal.
  1. Carefully remove cowl top vent panel from vehicle.
  1. Remove three retaining screws to cowl drain tube that is connected to top cowl.
  1. Disconnect wiring harness leading to windshield wiper motor.
  1. Remove five screws retaining cowl top to vehicle and remove cowl top and windshield wiper from vehicle.
  1. Remove two screws and two nuts retaining windshield wiper to cowl top and separate the two parts.
  1. Remove drive linkage from motor shaft linkage.
  1. Remove remaining screws attaching windshield wiper and separate the two parts.
Item Part Number Description 1 02010 Cowl Top Panel 2 N621906-S2 Nut (2 Req'd) 3 17508 Windshield Wiper Motor 4 N805605-S36 Screw (2 Req'd) 5 17500 Windshield Wiper Assembly A — Tighten to 9-12 Nm (80-106 Lb-In)
Feb 23, 2009 | 1998 Ford Windstar
CRL 1986 Honda Accord Headliner and Cowl Fastener Logo
56 people viewed this question
Top Cr Laurence Vehicle Parts & Accessories Experts
bobalix
baire
Are you a Cr Laurence Vehicle Part and Accessory Expert? Answer questions, earn points and help others
