Asus memory padfactory reset
How do i do it
  • 36 Answers
This page http://en.kioskea.net/faq/4162-restore-an-asus-netbook-to-factory-settings should help you do your Asus Factory Reset. Hope this helps.
- Nathan
Posted on Apr 19, 2014
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Dec 31, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
Asus 1015cx will not boot at all
I would open it up, remove the hard drive and memory. Then see if you can get into the BIOS. Then put back the memory and try again.. Do you hear any beeps at startup?
Mar 08, 2014 | ASUS Eee PC 1015Cx
Just powering on my new ASUS M4A88T-V EVO Motherboard to check if I have my connections done right, Receiving two short beeps then no beeps, Trying to find out what that means
2 Beeps? maybe Parity circuit failure
it is responsible for generating and checking the parity bit on the system memory when parity checking is used. This circuitry is not working properly.
This code usually means a problem with either the system memory or the motherboard.
Try to reset the cmos remove the battery. if not check the memory,try clean the gold surface of the memory using pencil eraser.
Sep 23, 2011 | ASUS M4A88TV EVOUSB3 Motherboard
I have a ASUS M4a77TD - tried to install new memory. BIOS recognize it, but computer won't boot, and does not even activate screen. Tried to reset BIOS (jumper), did'nt help. Any suggestions?
The issue most likely lies within the new memory.
Try to get to a bios boot screen without memory installed.
If that works, the new memory is defective.
Report back if you have any issues.
May 05, 2011 | ASUS Computers & Internet
PC Not Displaying anything on Powerup
check the cpu and try other memory modules or if you have more then one try them one at a time. try also reset the motherboard
May 28, 2010 | ASUS P5S800-VM Motherboard
Not recognizing memory.
The Asus P4S800-X MB can use Dual channel DDR memory and single channel memory. The dual channel memory which comes in matching packs. (Normally 2 DIMMS per pack) is the faster memory.
In other words if you are installing, 4- 512MB DIMMS of PC3200 all memory should be matched,
or you're MB may not see all connected DIMM'S.
See page vii in you're manual. If you're running windows XP, Home or Pro edition the bios will show up to 4GB of memory installed but windows XP 32bit will only show 3GB of memory. As mentioned above all 4 of you're 512MB of memory should be dual channel and run at the same speed. You can run both single channel and dual channel but you must follow Table 1 in you're manual. (1-9).
Example; PC3200 400MHz.
Or 4-512MB PC2700 333MHz. See page 1-9 for memory configurations and the QVL list supported.
Check out Asus FAQ's; http://support.asus.com/faq/faq.aspx?SLanguage=en-us&model=P4S800D-X&product=6&os=17
This should help you configure the memory.
Mike
May 09, 2010 | ASUS P4S800D-X Motherboard
Mouse and keyboard not working on it(asus a8n-e)
1)Make sure the jumper that resets the board, is on the right position based on manual.
2)Reset memory stick(s)
If this does not work, try using USB keyboard and mouse.
N Sabre
Good Luck
Nov 07, 2009 | ASUS A8N-E Motherboard
My ASUS P5SD2-VM Is Having A No Display Problem
If you are using the motherboards built in VGA graphic display, check your bios settings. Open your manual to page 2-22. Read the page.
Make sure you have the bios set to, Primary Graphics Adapter [PCI-E] set to, [IntVGA].
Set the internal VGA to, [Enable]. You will also need to set an amount of your system memory for the VGA to use. It is recommended if you are using Windows Vista that you increase your 1GB of system memory to, 2GB. Or instead you can buy a decent PCI-E video card that will use its own memory instead of your system memory. If you do this you'll need to change the bios settings to, Primary Graphics Adapter [PCI-E].
Also change, Share Memory Size to [Disabled].
If you need the manual for the Asus P5SD2-VM. Click on the link below;
http://support.asus.com/download/download.aspx?modelname=P5SD2-VM&SLanguage=en-us
Click the dropdown menu & click on your operating system. Than click Search. Asus list all drivers, manuals, FAQ's ect.
To view the manual you'll need Adobe Reader. You can download Adobe for free at this link;
http://www.adobe.com/products/reader/
Again, if you do not have any display & your using the built in VGA graphics card try resetting the bios. Doing this will reset the bios back to normal default settings. The bios will auto use the built in VGA. To clear the bios see page 1-22.
Mike
Apr 26, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Asus a7v333 motherboard
try and update your bios, hopefully your timings, were just messed up by the new memory, or you could try a cmos jumper reset.
Mar 03, 2008 | ASUS A7V333-X (A7V333-X/L) Motherboard
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
