Question about Oreck Vacuums
2013 Oreck Vacuum . How can I check to see if it is stopped up?
It has started sounding really loud and when on low it seems to scatter whatever i am trying to pick up.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 22 Answers
If it scatters the dirt then it's definitely clogged up at the nozzle just behind the roller brush. Turn the sweeper upside down and stand it on the handle. Then look under the roller brush. I have two Oreck's in my house. You can take a screwdriver to loosen the clog and dump out the dirt. Don't try to pick up pine needles as these are sticky and will quickly clog up any vacuum sweeper.
Posted on Dec 30, 2013
chrispurs1
  • 372 Answers
SOURCE: Oreck Vacuum troubleshooting
Hi. If the motor is on its way out the motor noise will be eratic eg slowing down speeding up popping noise & a smell of electrical burning. If you have none of these symptoms then chances are its not the motor. Does the bag inflate or is it easy to collapse when you push the bag ? If bag inflates ok check belt. If bag not fully inflating check for blockages along length of the handle pipe its designed to pull apart by lifting up rubber sleeve at machine end of pipe, push ball latch in & pull pipe out remove any debris stuck in the pipe. Remove bbottom of machine as if replacing belt check to see if there is any debris stuck in the oppening that goes to motor fan, then check the fan blades you can see them through the port is there any missing or snapped off. If blades are missing or have big chunks missing you will need to replace. If fan only has minor bits missing then reassemble it should now worl well.
Posted on Sep 09, 2007
reddevil6
  • 1673 Answers
That the bottom plate off, check for a clog in the inlet. If clear, then you probably have a clog in the handle tube. You will have to take the handle loose to clean it out. It may also need a new belt if you haven't changed it for a while, they stretch.
Posted on Feb 05, 2008
SOURCE: Oreck Vacuum Cleaner problem (upright)
the belt has stetched and needs changing.
Posted on Apr 21, 2009
  • 231 Answers
SOURCE: Vacuum sounds like an airplane after 1 year of use.
the motor bearings are starting to fail most likely. You can diagnose the source of the noise by removing the brushroll and belt, could possibly be the brushroll bearings but if you still get the noise when the belt is off its the motor.
Posted on Jan 07, 2010
SOURCE: My Oreck Vacuum cleaner keeps burning up belts. I
I am having the same trouble. I bought the vacuum new in October 2007 when my wife and I purchased a newly constructed home. Since it is only two of us, she only has to vacuum once a month. I have taken it in three different times and get the same story. It needed a new belt. Mine has white smoke coming out of it and smells like burning rubber. I contacted Oreck and got no results. They refused to let me discuss this with Dave Oreck, stating that he nevers talks with customers! Gary Neeble
Posted on Jun 05, 2010
How to fix oreck xl vacuum
Really depends on what you need to repair.
We offer many of the parts needed here:
Oreck vacuum parts
800-775-6586
GoodVac com
Jul 04, 2014 | Oreck XL Ultra Bagged Upright Vacuum
My vacuum is making a loud whirring sound and is hotter than normal.
Hi Kelsey! I understand how frustrating this must be. Dirty filters or a clog can cause the vacuum to change sound and be hotter than normal.
Here is a quick link to troubleshooting the excessive noise:
http://www.bissell.com/FAQDetail.aspx?id=1362&cid=ccsocial
Mar 28, 2013 | Bissell Cleanview Helix Bagless Upright...
How can you do a height adjustment on Oreck XL Series vacuum
Oreck makes two different attachments for putting on the bottom of your vacuum to raise it up. They have one for the older Classic styles and one for the newer XL models. This is the only way you can raise the brush on an Oreck.
Jul 18, 2012 | Oreck Vacuums
Oreck xl won't start
This could be for various reasons. Check the power cord and try a different outlet first. See if the power cord is loose or damaged. Next check the brushroll and belt that those are in working order. If you smelt burning or electrical fire or your vacuum made an odd noise before stopping it may be the motor going bad. If your power cord is good and the brushroll and belt good, it is probably your motor going bad.
Replacement Oreck Vacuum Cleaner Motor
GoodVac
800-775-6586
Jun 20, 2012 | Oreck Vacuums
My oreck halo starts and stops when vacuuming. you get two or three motions and it stops. my hand tingles when i vacuum. can you tell me what is wrong. it was bought in March of 2009
sound like you have a loose wire inside the unit, " DO NO USE TILL ITS FIXED ". Carefully start taking apart in the locations where the wire runs through. Pay attention to all the wiring, any little nick could be the problem. Somewhere in there a wire is touching the inside of the unit. You might want to get intouch with Oreck, that is a manufacturing defect, and not worth a law suit if you get electricuted from it. Thats what the tingleing is, your getting juiced by it.
Mar 06, 2011 | Oreck HALO100 Bagged Upright Vacuum
When the vacuum is turned on it is a lot louder
The fan in this machine can become out of balance. The fan needs to be replaced even if the blades are all there.
Dec 01, 2009 | Oreck XL2000 Bagged Upright Vacuum
Oreck Celoc Hypo Allergenic Vac tearing up rug
Most parts and service are covered on those machines for a year. (the 5 year part is just the motor and some "fluff" for advertising purposes) I would call oreck and find the nearest warranty service center. You should find they will fix it at no charge as long as its not deemed "abuse".
If you call them and they will not help, repost and we'll get you fix'd up!
Best of Luck!
Jun 08, 2009 | Oreck XL2000 Bagged Upright Vacuum
Oreck vacuum cleaner stop working; earlier it was off-on while in
Check that the main plug socket isn't coming off from under the handle.
Jan 10, 2009 | Oreck XL2600 Vacuum
Vacuum stopped working
Hi Melisa
Because it has a dirty fan system where dirt is picked up and put through the fan impeller before it goes up the back spine and into the bag, it sounds like stones or hard dust has entered the fan and bounced off into the motor. Sadly this is one of the most common factors like Orecks that have a dirty fan system. It would have to be repaired unless you know how to take it apart and clear it. The green light certainly sounds like something you picked up with the Oreck and it has affected the motor.
Aug 14, 2008 | Oreck XL2600 Vacuum
Oreck XL9100 Brush clogged with hair
The pulley will turn off, then the end will pull off. Some of the replacement brush rolls, the pulley may be pressed on and may or may not come off with out ruining the end.
Apr 22, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Vacuums Logo
122 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
