Question about Canon Ir 3300 Black & White Copier
When i command it to make copies it shows e000315-00d
When i command it it shows e000135-000d
Tip
Recreate the Show Desktop icon on the Quick Launch toolbar
To re-create the Show Desktop icon on the Quick Launch
toolbar, follow these steps....
1. Use any text editor (such as Notepad) to create a
file with the following lines:
[Shell]
Command=2
IconFile=explorer.exe,3
[Taskbar]
Command=ToggleDesktop
2. Save the new file as a file named Show Desktop.scf
in the WindowsSystem or WinntSystem32 folder. Note
that Notepad may automatically append a .txt extension
to the file name. Remove this extension if Notepad
adds it. These steps do not work if the file is named
Show Desktop.scf.txt.
3. Quit Notepad.
4. Using Windows Explorer or My Computer, right-click
the Show Desktop .scf file, and then click Create
Shortcut.
5. Copy the new shortcut to the appropriate folder. In
Microsoft Windows 95 or Windows 98, copy the shortcut
to this folder: WindowsApplication DataMicrosoftInternet
ExplorerQuick Launch
In Microsoft Windows NT or Microsoft Windows 2000,
copy the shortcut to this folder: WinNTSystem32
In Microsoft Windows XP, copy the shortcut to the
following folder: WINDOWSSystem32ConfigSystemprofileApplication
DataMicrosoftInternet ExplorerQuick Launch
6. Rename the shortcut to Desktop.
The Show Desktop icon automatically appears on the
Quick Launch toolbar.
Reference:
http://support.microsoft.com/kb/190355/EN-US/
on Jun 24, 2010 | Microsoft Windows XP Professional SP2
NTLDR is missing
Try copying this same file from another working computer (same OS version, same folder). Search the root directory for hidden files (on command prompt, use commands DIR /A to list files, ATTRIB -H to show hidden files, and COPY.
Dec 22, 2013 | Computers & Internet
Icons are missing from computer screen
A.
  1. Right-click the desktop.
  2. Point to Arrange Icons By.
  3. Click Show Desktop Icons.
B. To re-create the Show desktop icon yourself, follow these steps:
  1. Click Start, click Run, type notepad in the Open box, and then click OK.
  2. Carefully copy and then paste the following text into the Notepad window:[Shell]
    Command=2
    [Taskbar]
  3. On the File menu, click Save As, and then save the file to your desktop as "Show desktop.scf". TheShow desktop icon is created on your desktop.
  4. Click and then drag the Show desktop icon to your Quick Launch toolbar.
Feb 05, 2012 | Microsoft Windows XP Home Edition
Hello, I am using cyberlink power producer slide show & i would like to add multiple background music. How can I do that? I am able to add one song.
Use the DOS copy command to append a bunch of MP3 files together, and then use the one combined file. It works best if the MP3 files all have the same characteristics (volume, bit rate, etc.)
In the command prompt, go "copy /b one.mp3+two.mp3+three.mp3 combined.mp3"
Dec 01, 2008 | CyberLink PowerProducer 2 for PC
Dos Problem
If you are only trying to move your data file, then create the new directory using the cd command e.g.  cd test.  Then move the file to the new directory either using the move command or the copy command eg. copy test.file c:\test\test.file
Alternatively you should try using the old text editor program in dos to load your file and then save to the directory of  your choice.   good luck
shane67
Mar 03, 2008 | Computers & Internet
How to Find the Ethernet Adapter's MAC Address
Follow these instructions to find your adapter's Media Access Control address (MAC address). This is not the same as a Macintosh computer, it is a fixed string built in to the hardware, that uniquely identifies a computer device. Windows 2003 1. Click Start > Run. A command prompt window appears. 2. Type cmd. 3. Type ipconfig/all. (no spaces around the /) 4. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows XP 1. Click Start > Run. A command prompt window appears. 2. Type cmd. 3. Type ipconfig/all. 4. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows 2000 1. Click Start > Programs > Accessories > Command Prompt. A command prompt window appears. 2. Type ipconfig /all. 3. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 4. You may close the command prompt window. Windows 95 and Windows 98 1. Click Start > Run. A command prompt window appears. 2. Type winipcfg. 3. Click OK. 4. Copy down the "Adapter Address" (the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows NT 1. Click Start > Programs > MS-DOS Prompt. A command prompt window appears. 2. Type ipconfig /all. 3. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 4. You may close the command prompt window. Macintosh OS (10.3.5) These instructions also work for some earlier OS. 1. Click Apple Menu at top left > System Preferences > Network icon. 2. Select Show: Built-in Ethernet in the pull down menu. 3. Click Ethernet. 4. Your adapter's MAC address is the characters in Ethernet ID.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
Canon Ir 3300 Black & White Copier Logo
old marine
old marine
