Question about Canon ImageCLASS D1120 All-In-One Laser Printer
Canon Imageclass D1120 ADF does not feed.
ADF does not even try to feed. After a few seconds it times out and gives a paper jam error. The feed motor never starts. I can hear the scanner warming up in anticipation of the paper feeding through.
    Top Expert:
  • Canon Master
  • 11,573 Answers
Posted on Aug 09, 2016
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 90 Answers
Check feeding sensor not operate well
Posted on Dec 30, 2013
4 Suggested Answers
SOURCE: Canon Imageclass D320 supply rec. paper malfunction
My problem was that I was trying to print from a PDF file. I found out that the file was legal size and that the setting for the printer to "choose paper source by PDF size" was checked. I unchecked it so that it would print on letter size paper. Hope this helps
Posted on May 06, 2009
SOURCE: canon pc 420 paper feeds only part way
I had the same problem. I found a parts diagram here http://techno-parts.org/canon/220/320_220.php which showed that the springs hold the bar down. On mine, on each side, one of the spring tabs was broken.
I made a metal pin for one side and insert a screw on the other. Be sure and wrap the spring over the nylon bushing.
Posted on Apr 04, 2010
SOURCE: Paper wont feed into printer no paper jam
In the comments section Blumm suggests pushing a piece of cardboard (like the back of a legal pad) through the feeder as far as you can. Turn the printer off and then on again with it in there. Pull the cardboard out and check for any foreign objects that have been pushed through.
It worked for many people including myself - I got a piece of plastic and it works wonderfully again!
Posted on Jul 31, 2010
ADF will not feed
Canon Image class does not feed.
Dec 29, 2013 | Canon ImageCLASS D1120 All-In-One Laser...
Canon 1180 error code E005 200
Nov 26, 2012 | Canon CLC 1180 Copier
I have a Canon D1120 and it says Check Document. There is no document in the feeder, no paper jams I can see... Any help? I tried turning it off and on, but got nothing
try to disconnect the feeder form the main unit and if still there is check document error then brother it is related to firmware(software)as i have encountered such in 3 machine before also but they were without feeder. so first disconnect the feeder connector from main unit .
Aug 18, 2011 | Canon imageCLASS D1120 Copier
Canon imageCLASS MF4350d paper jams
can you be specific, where does paper jams occures?
If in adf, try to clean the adf pickup rollers, if in cassette, open the printer and remove the toner cartridge, now you are able to see the pick up roller from the cassette and clean him with alcohol or water.
Hope that helps!
Jun 14, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
Canon imageclass D1120 printer says: feeder paper jam,
Hi Try this method
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
  1. Press b_in_add.gif(Settings/Registration) ? [Function Settings] ? [Common] ? [Scan Settings] ? [Feeder Jam Recovery Method].
  1. Select [From 1st Page] or [From Stopped Original] ? press [OK].
Details of each item are shown below.
[From 1st Page]: If a paper jam occurs in the feeder, scanning starts again from the first page of the document. [From Stopped Original]: If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
Jun 10, 2011 | Canon ImageCLASS D1120 All-In-One Laser...
D1120 IMAGE CLASS CONTINUOUS PAPER JAMS ALTHOUGH NO PAER ACTUALLY JAMMED. APPEARS THAT PAPPER IN PAPER TRAY IS NOT FEEDING OR CATCHING UP TO BE COPIED.
first of all try to clean trays picked up rollers and also look for a piece op paper or something else in internal paper path
pifonski
Feb 20, 2011 | Canon imageCLASS D1120 Copier
Canon Imageclass D880 automatic document feeder problems
Clean the ADF rollers and pad with alcohol.
Check to see if your ADF has done over 90 000 copies and if it has, change the ADF pick up assembly only.
Good Luck
Oct 19, 2009 | Canon imageCLASS D880 All-In-One Laser...
Canon image class 6550 adf area document to long error
You orginal feed rollers may be worn out. when this happens, the paper slips and the machine thinks the paper is too long.
You need to have the ADF rollers replaced.
Jul 06, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
Canon ImageCLASS D1120 All-In-One Laser Printer Logo
264 people viewed this question
old marine
old marine
