Question about Westinghouse Dryers
3066708 ceiling fan
Replace dome
I need to change the receiver and transmitter of Casablanca Scandia Ceiling Fan 88u33m. How to open the fan / dome and is there a newer replacement for the receiver and transmitter.
remove fan from ceiling [ safer way to work on it ] and receiver is in wire cover and any place that sells fan usually have a remote system
Jul 14, 2017 | Dryers
Pulls air in (clockwise) only, have tried reversing, won't pull air out (counter-clockwise)
fan blades are designed to move air in one direction only
if you want a unit to reverse the air flow then reverse the installation of the whole unit or get the correct unit for the job
May 02, 2015 | FAN-TASTIC VENT Fantastic 6000rbta 12 volt...
I have a Hampton Bay ceiling fan/lamp where the lamp dome is apparently very tight into the housing. I pressed up and turned in the direction noted to remove the dome. The dome houseing came down and is...
Most light domes twist on or off or have thumb screws to loosen and lower the dome.It sounds like you removed the light kit assembly instead of the dome.Try to put back by twisting in place the light kit assembly and look for screws,or hold back on trim and turn just glass dome do not use too much force .I checked web site but can't find your model.It is unusual to not be able to just remove glass dome.Look closely at how the glass dome is positioned. If no screws are visible either the glass part unscrews or the ring unscrews allowing glass dome to be removed.Good Luck.I have installed many ceiling fans the problem is if you didn't install it your at a disadvantage.GOOD LUCK.
Jan 04, 2011 | Heating & Cooling
How do i remove the glass in order to replace the bulb
Place hand firmly over the glass dome and apply firm pressure and turn the glass dome in a counter clockwise direction.
Jun 20, 2010 | Monte Carlo 5DI52WHD Discus White Ceiling...
Closet ceiling light, simple dome and metal ring,
Hello. There is always a way to remove the dome. If there is a metal nipple in the center of the dome, it will unscrew. Otherwise, the entire glass dome will unscrew. Regards, Joe
Jan 09, 2010 | Dryers
I need a replacement glass dome for my Hampton Bay fan/light. Where can I buy one?
YOU CAN SEARCH AT ANY HOME DEPOT , since they sell this particular brand , or go to : http://www.ceiling-fans-n-more.com/hampton-bay-ceiling-fans.php , hope it helps , AJ
Jul 14, 2009 | Dryers
Electrical box not working
unfortunately it sounds like the main electic wire is shorted out. Not the one to your fan, but the one that provides the power supply FOR the fan. The only way i know to fix this is to get an electrician. I am certain the wire needs replacing.
Nov 29, 2008 | Hunter 52" Ceiling Fan With Light And...
Dryers Logo
134 people viewed this question
Top Westinghouse Dryers Experts
Pranavendra Pranav
Pranavendra Pranav
Level 1 Expert
Paul Bade
john h
Are you a Westinghouse Dryer Expert? Answer questions, earn points and help others
