Problems of complrting installing windows - Computers & Internet
  • 1,511 Answers
I the installation is interrupted, you must Reformat the drive. Data has been compromised and part of the operating system is on the drive and stuck in limbo. Refresh everything and star all over again. Be patient, at times you may think nothing is happening and you tend to get upset and turn off the computer. Let ti GO and if it takes time...give it time.
Posted on Jan 08, 2014
I have update my nokia n73 but all later update not to complrt ?
use ovi sute
select tools
select soft update of device
update
Jun 05, 2011 | Nokia N73 Cellular Phone
Tip
How to Fix Windows Installer problems...
Do you experience this kind of problem whenever you attempt to install an application in windows box (2K, XP, etc.)?
"The Windows Installer service could not be accessed. This can occur if you are running Windows in Safe Mode, or if the Windows Installer is not correctly installed. Contact your support personnel for assistance."
The ms website knowledge article 324516 gives 2 methods as a way of fixing this problem, but you might be very lucky if any of the 2 fixes the problem, a lot of guys end up formatting their systems and doing fresh windows installations or try wired ways of fixing it.
Well, the solution is very easy:
1) Right click your root windows installation drive i.e. drive where you installed windows
2) Click properties at the bottom
3) Select Security tab
4) Click Add and scroll down to SYSTEM account click add and click OK.
5) Allow Full control permission and click Apply and then OK.
This should solve your problem with windows installer.
on Feb 02, 2010 | Computers & Internet
Am getting 1721 errors on my computer, can you tell me how i can fix it ?
Here you go. This is long winded but should fix you up.
Error 1721 is a common problem for many different Windows systems, shown when the installation you're trying to perform develops a problem and needs to be fixed. If you have this error, it's recommended that you're able to first fix any problems that could be inside your Windows system, and then cure the specific issues that the Windows Installer program has on your PC. This tutorial is going to show you exactly how to do that...
This error will typically show like this:
  • Error 1721. There is a problem with this Windows Installer package. A program required for this install to complete could not be run. Contact your support personal or package vendor.
The problem with this error is actually caused by a very simple issue - the Windows Installer program that is used to install the various files & software onto your PC is actually damaged or corrupted & preventing your system from installing the program you want. This can be caused by a number of problems, including everything from having corrupt registry settings to the Installer program on your system being damaged. To fix this, you first need to make sure that Windows Installer is okay, and then get rid of any further system errors on your computer.
The first step to resolving this error is to "register" and "unregister" the Windows Installer on your system. This is a program which installs all the programs that you want onto your PC, and is constant on every Windows installation. The problem that often causes error 1721 is the way in which Windows often cannot read the Windows Installer program, because it's not "registered". Registering a program basically tells Windows where to look for it on your system, and it's often the case that this stored reference is either damaged or deleted by accident. To ensure this is not a problem, you need to be able to type the following into your system:
  • Load up "CMD" (click "Start" > Run > type cmd)
  • Type msiexec u/unregister
  • Type msiexec /register
  • Try reinstaling the program you wanted to
If you try this and find it does not work, then it's recommended you then use a program by Microsoft called the "Windows Installer Cleanup Utility". This is a new program which basically cleans up all the settings and options associated with the Windows Installer program; meaning that if you have any problems with the Windows Installer on your PC, they should be fixed. You may also wish to install Windows Installer 4.5, which will basically upgrade the Windows Installer program on your system, which should resolve many cases of the 1721 error.
It's also highly recommended that you use a "registry cleaner" to fix any of the errors that are on your Windows system. A registry cleaner is a type of software tool that basically scans through the registry database of your PC and fixes any of the problems that are inside it. The registry database contains all the settings, files and options for Windows, and is where everything from your most recent emails to your desktop wallpaper are kept. It's basically like a library for your system which is continually being used to help your software run correctly. Unfortunately, the registry is continually being damaged & corrupted, leading it to become highly ineffective and erroneous. To ensure this problem is not causing the 1721 error, you should clean through your system with a registry cleaner tool.
Sep 11, 2010 | Dell Computers & Internet
Problem with instaling windows xp
I got your problem hunny, for properly installation u have to first format the windows and shut down the computer take a new cd of windows check your CD ROM is OK or Not then Install the windows if any new hardware u attached before pull out that and install the windows may God your problem will be solved if got your solution plz reply me .
Mar 07, 2009 | Microsoft Windows Vista Ultimate Edition
My C4180 All-in-one was working but now it will not switch on. The red attention light came on and then it went complrtely dead
Hi Flemingjudy -
Sorry to hear about your defective printer. I am afraid that your printer will need to be serviced or replaced to get it working again. I am hoping that your printer is still under warranty so that it won't cost you anything to get it fixed (a lot of times they have a 1 year warranty)
Here is the web address with information on various ways to contact HP to get the ball rolling
http://h10025.www1.hp.com/ewfrf/wc/contacthp?lc=en&dlc=en&cc=us&product=1141647&lang=en
Hope that helps,
Take care,
Michael
Nov 11, 2008 | HP Office Equipment & Supplies
Do you experience this kind of problem whenever you attemp to install an application in windows box (2k, xp)?
"The Windows Installer service could not be accessed. This can occur if you are running Windows in safe mode, or if the Windows Installer is not correctly installed. Contact your support personnel for assistance."
The ms website knowledge article 324516 gives 2 methods as a way of fixing this problem, but you might be very lucky if any of the 2 fixes the problem, alot of guys end up formating their systems and doing fresh windows installations or try wired ways of fixing it.
1. right click your root windows installation drive i.e drive where you installed windows 2. click properties at the bottom 3. select security tab 4. click Add and scroll down to SYSTEM account click add and click OK. 5. allow Full control permission and click Apply and then Ok.
Oct 19, 2008 | Computers & Internet
Tries to print, but then ink cartridge moves to left and it all stops
the printer gears assembly is brokem or gor cracked so it is giving this message that ---cannot complrte print task--- just get that assembly replaced to make it proper. it will cost u near $20 for the assembly.
Mar 18, 2008 | Lexmark Color JetPrinter Z23 InkJet
IBM ThinkPad T23 Can't install Windows XP
Download THIS program and burn it to cd.Start pc with cd-rom and look for ARAONIC program.With that program you can repair your hdd couse the problem is HDD!
Jan 05, 2008 | Computers & Internet
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
