Question about Canon ImageCLASS D1120 All-In-One Laser Printer
ADF will not feed
ADF doesn't even try to feed.
    Top Expert:
  • Canon Master
  • 11,573 Answers
Canon Image class does not feed.
Posted on Aug 09, 2016
    Filmmaker:
    Uploaded 5 video answers.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 108 Answers
Im not much of a printer guy,but if i were you i would look it up on the internet.sorry im not much help.
Posted on Dec 29, 2013
2 Suggested Answers
canontech
  • 1219 Answers
SOURCE: C3220 ADF feeds document through but then shows as
Yes that can be the sensor problem... BUT, if the paper gose trough, the sensor can report jam if it is the delay problem, so, first clean with cloath and alcohol or acetone the pick up and feed rollers in dadf. When you open the upper cover of dadf you will see the two rollers that are feeding the document, clean them!!! when you start to clean them rotate them manually.
Hope that helps!
Posted on Aug 08, 2011
MFC 8820D ADF Will Not Feed Document
The ADF in my Brother MFC 8820D will not feed a page through
Feb 23, 2013 | Brother MFC 8820D All-In-One Laser Printer
Lexmark 705 adf jam
If your adf is jamming while it is feeding it might be due to a broken hinge. Check out this video.https://www.youtube.com/watch?v=GaS0oKcreBo
Jan 29, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
ADF wont feed the paper through the printer
You can load up to 30 sheets of plain paper in the Artisan 800 ADF. If the ADF doesn't feed the paper, check the following.
1. Make sure that you are loading plain paper only without a holes. 3-hole punched paper is not supported by this printer.
2. Load paper not exceed 30 sheets.
3. Open the ADF and check for any jammed paper or foreign object that is blocking the paper feeding path.
4. Check if the BIG GREEN ADF indicator is lit when you load paper in the ADF.
If the issue persists, your printer will require service. You can contact the Epson for warranty if your printer still under warranty. If your warranty expires, look for an a service center that can repair your printer.
Oct 29, 2011 | Epson Artisan 800 All-In-One InkJet...
ImageRunner 1023iF auto-feeder stops mid-way through document. Pick-up and feed Wheel continues to spin for a moment, then stops and gives "Check Document" error. I have fed a card through the...
It can be the problem in sensor flapper on ADF tray ( small nose that is pointing out ). Maybe it doesn't works fine or in the middle of the copy from adf the paper is too far away from the sensor.
Also can be the problem of ADF pickup clutch or You are using unappropriate paper type- try with normal A4 80g/m as original to copy from adf.
Hope that something of this helps You!
Jun 02, 2011 | Canon imageRUNNER 1023iF Black and White...
We can receive but won't take the paper to send a fax out
You have an ADF paper feed problem, try taking some rubbing alchoial and clean the ADF paper feed tires, This helps the paper to feed into the scanner unit so the fax can be sent. I have also seen part of the ADF feed unit broken.
Does the paper feed in but not transmitt out?
Aug 28, 2008 | Sharp Office Equipment & Supplies
Ep1083 copier
If the machine sees the ADF ( auto document feeder) but does not feed the paper? Does it try to feed the paper? Does it pull the paper is a little and jam? If the machine sees the ADF and it starts to feed the paper but jams --- clean the feed rollers/ tires with rubber restorer or a high alcohol base cleaner. Also a mylar could be pulled into the paper path blocking the feeding of the paper. Take a thin piece of cardboard ( like the devider in a case of pop) and slide the cardboard about 3- 6 inches into the feed just past the feed roller. Gently pull back out and try to feed paper again. If those do not work and the machine does see the ADF, you may need switch, sensor, actuator or feed motor.
Aug 27, 2008 | Minolta EP1083 CS/PRO Copier
ADF Paper Feed on Ricoh Aficio 1013
1-clean rubber belts with lint free clothes immersed in pure alkohl
2-remove adf covers and confirm that nothing broken inside(gears-belts)3-every clutch and selonid are in good condition.
4-solonid lever engaged firmly to gear slevee 5-apply light grease to gears and slevee6-confirm that nothing object the actuation of adf microswitches no dust and dirt in optical switches.
Mar 05, 2008 | Office Equipment & Supplies
ADF jam
Turn off printer and unplug it from power supply.
Check ADF if it appears to be damaged ( open the top portion so that you can check the mechanisms ) unplug the ADF cable from back of scanner and replug it, replug power cable, turn it on and try scanning using adf again.
Feb 29, 2008 | Epson ACULASER CX11NF All-In-One Printer
ADF won't feed the paper. The feeder wheels are heard turning but the paper won't feed.Replaced the "pad" and cleaned the rollers & glass and checked the feed guide and feed sensor.
If those rollers are turning, and not feeding even after cleaning they simply need replaced. they can get so slick that no ammount of cleaning will help.
Thats what is sounds like.
Like trying to drive a car on ice. No traction.
Jan 25, 2008 | Xerox DocuMate 272 Path-Through Scanner
Canon ImageCLASS D1120 All-In-One Laser Printer Logo
66 people viewed this question
old marine
old marine
