Question about Canon Office Equipment & Supplies
E000315-00d canon3300 if i command it to make copies it shows that error code.
    Filmmaker:
    Uploaded 5 video answers.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 108 Answers
Make sure you have ink and the paper is fed properly.
Posted on Dec 29, 2013
2 Suggested Answers
  • 118 Answers
SOURCE: MACHINE REFUSES TO SCAN SHOWING ERROR EA3229 ON BIZHUB 200 COPIER
As with most communications errors the first thing to always try first is shutting off the copier, unplugging it from the power source for at least 30 seconds, then plugging it back in, powering up and trying the scan-to-email functions again (once network synchronization has been completed by the copier).
EAXXXX is a communication's failure code generated by the copier to state that 1. The LAN cable is not physically connected, 2. Communication with the SMTP server has been lost, or 3. One or more of the e-mail addresses that someone attempted to send mail to doesn't exist or is invalid.
If the scan-to-email functions worked before this and have suddenly stopped, you may want to have your IT department reset the mail server.
It's also possible to have had some changes made to internal network address that has affected the copier's ability to communicate with the servers. Check with your IT to see if they've added any security software, changed network address structures, etc., around the time that the scan functions failed.
Posted on Aug 28, 2009
How to fix 0xc000007b problem
This Microsoft Office error code occurs when you are updating installing and copying etc. This error occurs due to router and modem configuration and ISP restriction.
This error can be solved in 4 ways
1. By cleaning temp folder
2. By cleaning the %temp% folder
3. By cleaning the system file
4. By cleaning the Internet Explorer junk
Guide to solve your issue
Open the Run by pressing the window + R keys
Then open the temporary file system location by searching the temp in command prompt
If you have files means then select all the files and clear them by pressing Shift + Delete
This is also similar to clear the temp folder. By this method, we clear the user junk files.
Instead of temp search as %temp% in command prompt and follow the above steps.
Open the Run command prompt
Enter the cleanmgr command
Then select the drive which one want to clean
Then scan for junk data after that choose the entire item from the list except the recycle bin to clean.
Open the run window and enter the inetcpl.cpl command
Then go to advanced tab and select the reset button to clean the junk data
Then you will get pop up to delete the personal settings click ok to delete.
By following the above steps you can resolve your windows error code issues. For further more guidance regarding windows, you may visit the Microsoft Support Number.
Aug 30, 2015 | Computers & Internet
We've a problem with our TEC printer B-SX55. Sending a job via parallel interface only results in an error message showing up: XS;I,0001,0012C5 Can anyone tell me what to do to get it up and running...
This type of error message usually means a command error has been found in a command received by the printer. 16 bytes of the command error, hence the XS;I,0001,0012C5 message. It starts from the command code, XS.
I am not sure of all the command codes but I would suggest starting by re-installing the printer driver.
Dec 17, 2010 | Toshiba B-SX5T Printer
E0000051-0000
The horizontal registration motor is faulty.
Nov 01, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Control Center 2.0 problem
my mfc210c will not obey command to print multiple copies anymore. I don't know why. It never happened previously. If I ask for 2 or 3 copies, I only get 1 copy.Also, I don't know why the Contro Center no longer shows on my DeskTop and why I can't instanll it in my task bard below. It used to work just fine.
Apr 08, 2010 | Brother MFC 210C All-In-One InkJet Printer
Sharp Al-800 H4 Error Code
Press : CLEAR key - INTERRUPT key - O - INTERRUPT key.
The copy quantity display goes off and the machine is ready to receive input of test command number.Enter the two digit number to select the test commands.The test command number entered will be displayed in the copy quantity display.Press the PRINT switch.The operation corresponding to the entered test command number will be performed.For the test command 13 and 14 since test commands 13,14 are used to clear the contents of the diagnostic status (U1,H3,H4)stored in the LSI,the diagnostic mode will be automatically canceled after completion of the test commands.
Jul 30, 2009 | Toshiba e-Studio120 Copier
H400 error
it is problem heater unite
reset code is
C photo C photo press 14 by copy quantity key press printkey then show 01 or other code press up & down key 00 press print key
Jul 27, 2009 | Sharp AR-168S Copier
Error code when copying... C6103 on Bizhub C451
C6103 - Scanner overrun failure
The Scanner Home Sensor detects the Scanner at its home position during a period of time that begins with the time when a prescan command
and a scan preparation command are executed and ends when a home return command is executed.
Apr 14, 2009 | Konica Minolta bizhub C450P Laser Printer
Hp 4p printer related problem
Error 51 (beam detect error) Trouble shooting suggestions: Check seating on laser/scanner assembly Replace scanner assembly
Aug 30, 2007 | HP LaserJet 4p Printer
59 people viewed this question
old marine
old marine
