Original SONY Remote Control RM-GD019 - Televison & Video
  • 17 Answers
SOURCE: sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
Posted on Oct 30, 2008
SOURCE: sony rm-v310 universal remote code
Try this link from Sony
http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMV310
Posted on Jul 23, 2009
SOURCE: How to open remote control Sony RM-Y181
I had open a Sony RM-GA010 because the transmitting bulb was stucked inside after a fall. The two screws inside the battery compartment was not really holding the case together. I used two flat screwdrivers working on the side of the remote control; one levered open a bit and the other slipped in further and levered more to split it open. I think a blunt knife may also do the job; but never a sharp one because it will be too dangerous. You need to accept some permanent depression at the edge of the control (better than a useless remote). Once you open some part, it become much more easy. After opening the outer case, you can access the buttons, but not he transmitting bulb in my case. I need to loosen two additional screws (i.e. totally four, including the two inside the battery compartment) to loosen the electronic board a bit and I could correct the bended transmitting bulb. Then put everything back, clicked up the case and the remote worked again!
Ben
Posted on Aug 29, 2009
SOURCE: TV remote RM-ED002 for main TV works fine except volume
I had the same problem with sony remot control RM-ED002, take remot control apart and clean inside with damp cloth and dry with kitchen towel, thats it now use it! ;-)
When i opened mine it was some kind of moisture under volume and channel buttons, cleaning and drying it helped.
Posted on Nov 03, 2009
SOURCE: how can i open my sony rm-ed009 remote control
insert wide flat blade (such as a wide flat bladed screw driver) into seam along one side. Twist carefully until seam starts to prise apart - carry on until you hear the "crack" of the press-tabs coming apart and repeat along the the length of the seam until you can carefully pull it apart.
Posted on Jan 02, 2011
How do I turn on cc without remote control?
Unfortunately, you can't reach the CC (Caption Vision) sub menu without a remote control. You need to find another RM-Y121 remote or a Universal remote that supports the Menu feature of the original remote. (Some universal remotes do not include a Menu button. Avoid those cheaper models. You may have to search all Sony TV codes to get the needed button to work.)
A replacement original remote is available from EMT Company at http://www.emtcompany.com/sony-rm-y121-remote-control/101317789.html . The remote costs ~$12. Amazon has a vendor with a used version of the remote.
I wish that I had better news for you.
Sep 19, 2015 | Sony KV-32V16 TV
Sony rm ss251
As all other buttons works properly except Volum Dn, the problem is with the remote control itself. Clean the remote control and check. To clean it, you have to open the remote control. If it too doesn't help you, buy one original remote control from the authorized service center for Sony. No universal remote control will go properly with Sony TVs. If you wish to get some details, check the site linked here. Pull up older posts.
Dec 07, 2013 | Sony Televison & Video
Need instruction manual for sony rm 841 remote control
How can i tune chanells. How can i open the menu for tuning with RM-841
Nov 07, 2012 | Sony Original Tv Vcr Remote Control Rm-841...
Sony trinitron number is kv20fv12 what is the number for a remote controller for this tv
The original remote control number to this set is {RM - Y198}. If you buy its original one, contact the nearest authorized service center for Sony. The universal remote control codes for Sony Brand Tvs are: 0128 0013 0002 0071 0380
If you wish to buy a universal remote control, check whether there is these codes with its code list. The code list will be attached with every universal remote control pack. Make sure there are these codes with it.
In my opinion, it will be best to buy its original one. Original is Original, and Universal is Universal!!
Oct 27, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Hi i'm trying to programme my sharp stereo with a sony rm vz220 remote control. But can't get the correct code. The only code that i got was 60048. But it does not work.. Help plz..
According to the Sony Support site for this remote, receivers are NOT supported at all. Additionally, only a handful of codes are available for Sharp electronics. They are for the following devices:
Blu Ray, CD, DVD, DVD Recorder, TV and VCR.
All the codes used for the devices above are:
12250, 70034, 70037, 70180, 10630, 10675, 12250, 10675, 00818, 60048 and 60848.
You could try these codes one at a time and possibly gain some remote control capability - but that would only happen by chance. The codes above are the ONLY ones built into the RM-VZ320 remote for Sharp brand products, and if none work for your equipment, Sony says you should use your original equipment remote to control it. Not very helpful.
You can either do as they recommend, buy a pre-programmed remote that supports your device, or buy a pre-programmed remote that supports "learning". Learning remotes are universal in that the products not built in to the remote can be learned by holding the original so it points at the learning remote and pressing function buttons so that the learning remote "records" the buttons pressed on the original. It can take some time to do this, but you are assured that the remote will work with you device. Of course, you must have the original remote to do this though.
I hope this helps and good luck! Please rate my reply. Thank you.
Mar 25, 2011 | Sony RM-VZ320 Remote Control
Alright, so is there any way I can get the Sony RM-V310 remote to work with a dish network reciever
probably not. you need the original dish network receiver remote. call your Dish provider for a replacement.
Jul 22, 2010 | Sony RM-V310 Remote Control
TV remote RM-ED002 for main TV works fine except volume control which has no effect. Another Sony remote, RM-ED007 for second TV works fine on main TV including volume control.
Aug 24, 2009 | Televison & Video
Sony universal remote will not operate sony dream system
Solution is to buy Sony original remote for DAV-FR10W system from Sony Accessories Store under following part number..
147869811 RM-SP350 REMOTE CONTROL
Feb 05, 2009 | Sony DAV-FR10W System
Sony RM-Y168 remote needs VCR codes for Zenith brand
code for zenith vcr is 331 if your remote is rm y168.
Nov 23, 2008 | Sony RM-Y168 Remote Control
Trying to find code for my gateway T.V
If you have the original remote, you have the Sony "learn" the signal from it. It's not too difficult and the manual will walk you through it.
Sep 14, 2007 | Sony RM-AV2100 LCD Touchscreen Remote...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
