Question about Dishwashers
This used dishwasher was hardwired. Can it be changed and an electrical cord attached for a wall plug-in? Kenmore Dish Washer 206C1513P007
  • moonsister8 May 19, 2009
    "justaskjoe" THANK YOU so much for your quick reply. Your information was precise and I know now that I can do it myself and have a working appliance:) You did GREAT! thank you:) 100%
  • 10,865 Answers
Yes absolutely. Just go to any hardware store and tell the clerk what u want to do. They will sell you the appliance cord which you can then install by pairing up the colors on each set. black to black, white to white, green to green. Turn off the breaker before you proceed.
Posted on May 19, 2009
  • Joe Hogan May 19, 2009
    and thank you for the nice compliment.
Can I put a plug on a Kenmore dishwasher rather than hardwire it back in?
Of course you can! But do try to get the hot wire connected to the black wire of the dishwasher, and the neutral to the white wire; and of course, the green wire is your ground wire, which gets attached to the grounding screw inside the junction box.
Sep 12, 2014 | Kenmore Dishwashers
How to repair my kenmore dish washer not powering on but shocked me before it shut down for good ?
it sounds to me as though you may have a bare wire giving a direct short to the system.therefore by having a hot wire grounding out on the dishwasher body, it is running that current to the dishwasher body where if you touch the dishwasher you will recieve a shock.this also doesnt allow the electricity to go to where it is needed to power your appliance.
May 20, 2014 | Kenmore Dishwashers
S5443
there should be screws inside the door at the top and sometimes even on the sides depending on the quality of the person who installed it. after removing all the screws turn off electrical breaker in power box. unplug cord if visible under sink. also unhook drain hose and the pull washer out while feeding cord and hose through wall of cabinet.
May 08, 2014 | Neff 24 in. S5456 Built-in Dishwasher
I have a kenmore dishwasher quitewash1 it will not get power or come on
Make sure the circuit breakers to the dish washer are on. Cycle them off then on to make sure. This will reset the GFI breaker. Plug the machine into the wall plug and make sure the wall plug in not a GFI also. If it is reset the wall plug and you should have power.
Oct 17, 2013 | Dishwashers
What does it mean when a gas cooker needs hardwiring
It means that it does not have a cord and a plug to just plug it into a wall socket...
It needs to be "hardwired" into the electrical circuit with a regular piece of wire...
heatman101
Dec 13, 2010 | New World G60m Gas Single Oven
I have a Kenmore Diswasher model. 587.15103801 - My question is - can I wire a 3 prong power cord to it? If so, what do I need to purchase? Thanks
The dishwasher SHOULD have a three prong cord, or be hardwired using using a 3 conductor electrical wire capable of handing 15 to 20 amps (12 or 10 gauge wire). If you desire to use a cord with a plug on the end, you can purchase a power tool replacment cord rated at 15 amps or higher from the hardware store (I have found power tool replacement cords to be very durable). Make sure you purchase one that is long enough the accomodate pulling the dishwasher out from under the counter, if required. The power cord is installed in a junction box behind the lower toe panel that's located directly below the door. The wire color coding is as follows:
BLACK - HOT (120 VAC)
WHITE - NEUTRAL (0 VAC)
GREEN - GROUND
Match the color wires with the wires inside the dishwasher junction box and twist together using wire lugs. Attach the ground wire to the appropriate ground lug.
If you have questions, please let me know. I hope this helps you.
Aug 27, 2009 | Dishwashers
Kenmore dishwasher 206c1513p007 wont drain
take the cover off the bottom of the dishwasher inside and remover the built up food and turn the wire by hand and even use your hand as a plunger
Jun 29, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Need hoses and electric cord
Water inlet hoses can be had at your local hardware store same with drain hoses, electric cords? If this is a built in unit then you have it hardwired into your homes electrical system. Plug in cords would be a no no.
Feb 21, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwashers Logo
144 people viewed this question
Top Dishwashers Experts
