My dell latitude e6410 won't turn on When I press the power button it stays on for 3 sec them turns back off the battery charge light is on when plugged up Need help please
    New Friend:
    Problem Solver:
  • 9 Answers
This usually indicates an overheating problem. Try cleaning out the fan with a can of compressed air, if that doesn't work you will need to bring it to a technician who can test the motherboard as the graphics processor may need to have solder reballing done.
Posted on Dec 29, 2013
zzedly
  • 300 Answers
SOURCE: Dell Latitude C510/610 wont turn on
I have more of a suspicion of the CPU fan than the hard drive, right now. If a hard drive goes bad, the system will wake up, go through it's POST (Power On Self Test), and then tell you there's an issue with the hard drive. If the CPU fan goes bad, the system turns on, sees an RPM of 0 on the fan, then turns back off. That hypothesis also fits in with the slowness you were seeing. If a CPU starts to overheat (because the fan isn't running well), it will start to throttle the clock speed down in an attempt to produce less heat.
Unfortunately, it sounds like your laptop may be in need of a professional repair facility.
Posted on Mar 07, 2008
itszspot
  • 4 Answers
SOURCE: dell latitude d600 doesn't turn on
The test Dell advises to narrow down this issue is to remove the battery, hard drive, ram, and optical drive.  Next plug in the a/c power cord and you should get some LED's coming on. If not it points to the motherboard.
Posted on Aug 16, 2008
SOURCE: Dell Latitude C610 Laptop won't turn on
i've been bummed with this laptop.
same thing happens to me - except all my lights come on for a split second then only the power light stays on underneath the monitor - which is black - and nothing else shows any sign of being turned on.
also..
the f, z, n, and some other key are broken.
well - they work, but only after several hard hits.
Posted on Nov 08, 2008
byteguy
  • 2229 Answers
SOURCE: Dell laptop battery has 3 lights flashing when hit battery tester
You can't get the modern batteries to come back to life. Time to get a new one.
A suggestion: When using a laptop battery, run it on battery and discharge it until it shows about 2 to 3% charge left at least once a month. Do not keep charging it without letting it run down periodically. Most important--do not run always plugged in to line current.
Posted on Sep 09, 2009
Testimonial: "Thanks, that is a good tip. After a full charge to battery, I did a full discharge, started in command prompt mode, to drain battery with DOS. Now OK"
benwabnick
  • 2404 Answers
SOURCE: dell inspiron 1545 won't boot turn on start up
Unseat and reseat the memory in the laptop one stick at a time in each slot one at a time. Turn on the laptop after each reseat of memory.
If that doesn't work then take out the hard drive and then the dvd drive.
Turn the laptop on again and if you still can't get video on the screen then the motherboard is defective and would need to be replaced.
Posted on Nov 30, 2009
My laptop is not starting it is blank After start up,and a cursur Mark is showing
http://www.tenforums.com/tutorials/2304-safe-mode-start-windows-10-a.html
Sep 16, 2015 | Dell Latitude E6410 Laptop
My battery light is staying on what does that indicate?
Battery light on indicates that your battery is charging. If charger if not connected and battery light is on, mean that something is not functoning correctly.
If your charge is ok and battery keep charge level, leave it alone - just my opinon
If you want to spend some good money, take it to a computer repair sevice
Aug 10, 2015 | Dell Latitude E6410 Laptop
Dell latitude 10 st2 e wont boot
Hi voyagerbooks,
Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30 sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    (6)Try turning on the computer.
    If the computer doesn't turn on then check if the computer gives any series of beeps or if there are any diagnostics LEDs shown on it.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Apr 07, 2015 | Dell Computers & Internet
New battery not charging
the old power supply must not be putting out enough power to charge
Jan 31, 2013 | Dell Latitude E6410 Laptop Computer (Intel...
The batteries won't recharge for my dell latitude
try to perform power drain first. take out the battery and unplug the power adapter. press and hold the power button for 30 secs. put the battery back in and plug in the power adapter. turn on the computer and monitor if theres is any changes. if same issue happened then you need to replace your battery.
May 03, 2010 | Dell Latitude C640 Notebook
3 Lights on display panel Dell D505
YOU HAVE A FAULTY BIOS.I HAD THE SAME PROBLEM WITH MY DELL INSPIRON 5150.REFLASHING THE BIOS SOLVED THE PROBLEM.GOOD LUCK.
Sep 11, 2009 | Dell Latitude D600 Notebook
Dell latitude d600 will not turn on / power on
it means not charging the battery pack, did you check the dc jack connector, or the.
charger check it if working properly, if the same problem open the laptop then check the baord
thanks
Jul 12, 2009 | Dell Latitude D600 Notebook
If the light comes on for three seconds and then go out ,generally means a power distrubution problem . remove the optical drive and memory from the system and try powering it on. If u get the same result , its time to take it to service tech , as your motherboard needs to be checked
Apr 07, 2008 | Dell Latitude C610 Notebook
could it be your hard drive...... and have you tried getting into the bios at all.... if you can get into your bios, change your boot order to cd drive first, install your os disk and try doing a repair . if that dont work try a new hard drive.
Mar 14, 2008 | Dell Latitude D600 Notebook
Open Questions:
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
