you will have to download and install an audio driver for it to work..if yocan tell me the name and model number of your compu i can help you further..regards!or if you have the drivers cd that came with your compu you will have to install the audio driver..
U need to check and see if u have any fuses inside the chassis, it sounds like one may be blown, if it is the problem is most likely a defective /shorted equalizer and will require a repair shop to fix it, if u can't find any fuses then it most likely has a defective fuse link on the circuit board and once again will need to go a repair shop to have that repaired as well unless u have a circuit diagram for the player, the fuse symbol is a squiggly line with a dot at easch end.
Most experts are based in the USA so no can't help u with any locations for repair in Kangaroo land.
Hi have discovered the graphic equaliser is actually working but the display isn't so will check the fuses, how do I get my record player to run properly, it wont run when you lift it off its stand but if you put it on the record at the end and manualy turn the record it returns to its stand? bloody kangaroos are everywhere here and think nothing of bouncing in front of your vehicle, even when you hoot,shout slam on the brakes makes no difference,blinkered they then bounce unceremoniously off your roo bar(a must out here) to rest on the side of the road and turn into an exploding maggot bomb. Poke with a very long stick if you dare!!! cheers Paul
