Question about Thomson WHP3001BK WIRELESS HEADPHONES
No sound at all other head phones work on tv laptop ?
No sound from tv when connected to sherwood 7505
try pressing the aux button on the front of the reciever while the reciever is linked up to the tv ,if that dont work connect a red and black banana plugs into your aux on the back of the reciever and on the other end of the lead must be a head phone pin check size of headphone socket. to plug in to your tv head phone volune then u can control the recievers volume through the tv using the remote.go to menu then tv set up then scroll to the sound note icon press enter scroll down click on head phone and turn it up then you should have sound through the speakers from the tv.
Jan 27, 2013 | Sherwood Rd-7505 Home Theater Receivers
Plug in head phones to tv/no sound
If no sound from speakers or headphone likely audio circuit issue but check to make sure main speakers not switched to off or external.
Nov 04, 2012 | Toshiba 19AV505DB 19-Inch Screen Hd Ready...
Hi plz help me i am using IBM r51 laptop which has all drivers but not able to get sound of it. but when i connect a headphone i can get sound of it. but my laptops speakers r working as i tested mt...
ibm sound card is not faulty, because you are getting sound with your head phone. The head phone jack have two functions 1. to give output to head phone 2. to disconnect internal speakers when you plug in head phone.
The jack for headphone in normal position not give connectivity to internal speakers.
SOLUTION : REPLACE THE HEADPHONE JACK.
I think it will help you.
Sep 15, 2011 | IBM ThinkPad Soundcard
Trying to get sound on the tv but dont know how as the sound is only coming from the laptop.
Check and see if your laptop has HDMI hookup if so you can use that if your TV has HDMI as well if neither has and it only has VGA it it may not be able to get the sound and the only way to fix that is to get an adapter that converts the head phone connector 3.5 mm more than likely to what ever input your tv has for sound like rca then connect the wire from the laptop headphone output on the front into the tv input to get the sound.
Aug 22, 2011 | Computers & Internet
Have picture and "NO" sound....
Check whether the mute switch is activated by mistake. Check speakers. If there is a head-phone jack check the jack. Try with head phones. If it's ok check the head phone jack contacts inside.
Finally the audio circuit board and its components.
Jul 07, 2010 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
No sound on the TV whether playing through satellite, DVD player, or through antenna. Happend once today and when I turned the TV off and then back on, the sound came back. Just turned the TV on, and the...
Hi
Can you hear sound if a set of head phones are connected to head phone socket if so the head phone socket might need cleaning or replacing
Regards windyhouse
Mar 09, 2010 | Toshiba 32A33 32" TV
Hello. My Head phone jack is not working. I have a Sony Vaio Laptop and the speakers on it are working fine. When I put the head phones in it I don't hear a thing. I've up dated the drivers and it seems to...
Sounds like your headphones may need to be replaced. I'm assuming they don't work with anything else.
Try cleaning the plug with a lightly dampened paper towel and use a can of compressed air to clean out the jack on the laptop. If that doesn't work, try another set of headphones.
Nov 25, 2009 | Sony VAIO VGN-NR310E/S Laptop
The head phones doesn't stop loud speakers sound
most likely the switch at the back of the headphone plug is not working properly, this requires the laptop to be dismantled and have the jack repaired/replaced. Very expensive at most places. was it working previously?
Apr 26, 2009 | IBM ThinkPad T20 2647 Notebook
Thomson WHP3001BK WIRELESS HEADPHONES Logo
Top Thomson Audio Players & Recorders Experts
shaun taylor
Shehu Pro
Shehu Pro
 Mikey
Mikey
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
