Question about HP PSC 1210 All-In-One InkJet Printer
Printer wil print when scanning but not from computer
My HP Deskjet 1210 will scan and print but it won't print from the computer. The printer will will say the document has been sent to the printer but then the printer will say "check print cartridge". The cartridges have been checked and they're full of ink. Any ideas?
Thanks
  • 184 Answers
There are a few steps you will need to follow to resolve this problem. Follow these steps one after the other. start with the first step. after each step, try to print and see what happens. if your problem is resolved, ignore the other steps.
Step one: Clear any paper or carriage path obstructions
1.
With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
2.
Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
3.
Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
4.
Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
You may have to reach through the output paper tray to access the print carriage.
5.
Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
6.
Press the On button to turn on the product.
Step two: Ensure correct installation of the front panel overlay
If the front panel overlay, or bezel, is incorrectly installed, the product may indicate a false carriage stall error condition. If the product has not been set up before, ensure correct installation of the front panel overlay by following the instructions below.
If the front panel overlay is already installed, and your printer has been working for some time, do not attempt to re-install the overlay. Press firmly on the overlay to ensure proper installation of the overlay adhesive or pins.
NOTE: If you have already installed the front panel overlay, proceed to the next step.
1.
Disconnect the power cord.
2.
Locate the front panel cover and peel off the paper backing to expose the adhesive as shown in the graphic below.
3.
Lift the scanner lid and carefully line up and install the front panel overlay.
4.
Plug the power cord in.
5.
Try the print job again to see if this step resolved the issue.
If the issue is resolved , you do not need to continue with the rest of the instructions on this page.
If the issue is not resolved , continue to the next step.
Step three: Plug the product directly into a wall outlet
Verify that the product is properly connected to a suitable power source by following the instructions below.
1.
Verify that the computer and the all-in-one product have a three-prong power plug.
2.
Unplug the power cable from the back of the all-in-one.
3.
Unplug the product cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
4.
Plug the power cable into the back of the all-in-one.
5.
NOTE: If the product prints when plugged directly into a wall outlet while unplugged from any power strips or surge suppressors, the power strip or surge suppressor may not be allowing sufficient voltage to reach the product.
Step four: Perform a partial reset
A partial reset will return user settings to factory defaults. you may have, language and country/region settings also resetted. Perform a partial reset of the product by following the instructions below.
1.
Unplug the power cord from the unit.
2.
Reconnect the power cord into the unit.
3.
When the lights begin to flash, press and hold the On/Resume and Paper Size buttons.
4.
When only the On/Resume light is flashing, release the buttons.
When the On/Resume light is steady, the reset is complete.
5.
Step five: Remove and re-install the print cartridges
Improper placement or installation of the product's print cartridges can cause the product to indicate a carriage stall error condition. Ensure correct installation of the print cartridges by following the instructions below.
1.
With the printer plugged in and turned on, open the cartridge access door (see the illustration). After a moment, the print carriage should come to the center.
The print cartridge carriage is the plastic part that holds the print cartridges.
NOTE: If the carriage does not come to the center, try turning the printer off and on.
2.
When the carriage is at the center of the access area, unplug the printer.
3.
Remove the cartridges from the carriage and check them for damage. Check for obstructions under and around the carriage. Replace any damaged cartridges.
NOTE: Try to inspect and reinstall the cartridges as quickly as possible, so that they do not dry out. Avoid touching the copper-colored parts of the cartridge.
4.
Reinstall the print cartridges.
The black or photo cartridge goes on the right.
The tri-color cartridge goes on the left.
5.
Close the cartridge access door, plug the printer back in and turn it on.
6.
Step six: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Posted on May 19, 2009
My printer scans, copy but won't print from computer?
Did you set this printer as the default printer? To do this go to Start - Printer and Faxes, right click on HP printer, select Set As Default Printer. If you are not see your HP Deskject F340 there, that mean your printer driver is not installed. Please install your printer driver.
If you already set it as the default and it is still not printing. Restart your computer to try solve problem.
You said that printer scans so the connection between your computer and printer is fine. Problem is your computer doesn't take the printer as it's printer device yet.
Hope this will help. Thanks for reading
Jul 19, 2011 | HP Deskjet F340 All-In-One Printer
I HAVE AN HP PSC 1210 ALL IN ONE PRINTER SCANNER AND COPIER, I WANT TO SCAN A PICTURE BUT WHENEVER I PUT A PICTURE IN MY COMPUTER IT TELLS ME THERE IS A PROBLEM WITH MY SCANING DEVICE. I KNOW EVERYTHINGS'S...
Try to re-install the printer...from software..
1210 is very reliable printer and....have not seen those kind of problem..
Otherwise, check your cartridge...and how much amount of ink you have.
Sometime, if you are out of ink, the printer won't let you scan,, copy....
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 02, 2011 | HP PSC 1210 All-In-One InkJet Printer
My hp deskjet f380 printer will not scan a document!
hello daz... these printers are not wireless when it comes to scanning. connect your computer to the printer with the usb cable. if it still won't scan, download the driver [or find it at hp.com/drivers and download it there. Joe
Apr 20, 2011 | HP DeskJet F380 All-In-One Printer
I am trying to scan a printed document using my HP PSC 1210xi all-in-one, and when I press the scan button, the On/Resume light will flash for a few seconds, then go solid. Nothing else happens. How do I...
First load the software tha tcome with you all in one in the laptop.
then scan from the laptop instead of from the printer.
Use the all in one icon on the laptop instead.
. then it wil lgive you the optiont o send it toE/mail or where.
Nov 05, 2009 | HP PSC 1210 All-In-One InkJet Printer
Hp deskjet f2210 doesnt scan photos. help
Please click on start/all programs/accessories and click on paint”.
When it open click on file and then click on “scanner and camera wizard”, if printer detected then it will show the option after that you will get the option for scan, please click on the scan tab without do anything and once when scan get complete save the file on your computer. This is the easiest way to scan the document.
Oct 26, 2009 | HP PSC 1210 All-In-One InkJet Printer
Scanner hp psc 1210 all in one printer
Hi there.
As there is no full featured software available of PSC 1210 All-In-One for Windows Vista, we cannot scan from the All-In-One itself.
However, we may utilize the scanning functionality with the Microsoft Paint and Windows Photo Gallery on the computer.
I am providing you a weblink which would help in scanning with above mentioned programs.
Here is the weblink:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00808543&lc=en&cc=us&lang=en&os=2093&product=90764&dlc=en
Hope this information would be helpful.
With regards,
Ashesburn..
Apr 22, 2008 | HP PSC 1210 All-In-One InkJet Printer
Unresponsive printer
First off, I will try an uninstallation of the printer
Then reinstall all the drivers and software for the printer.
Jan 20, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1315 Scanning problems
download software for hp psc 1210 printer
Oct 09, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1210 Xi won't scan after installing HP Deskjet D4160. Scan.msi can't be found
try to locate this file from drive software disk or re-install the setup. bye
Aug 25, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
170 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
