Question about Birds
Can you frerzr pumpkin - Birds
Tip
Homemade pumpkin pie spice mix
Have you ever wanted to make a recipe that calls for "pumpkin pie spice" but don't have it in your pantry? It turns out, pumpkin pie spice in made from things that most people already have so there's no need to go out and spend the money on another spice that's just going to sit on the shelf. Instead, you can make your own with stuff you probably already have lying around your spice rack.
Here is all you need to make your own pumpkin pie spice:
  • 4 tablespoons ground cinnamon
  • 2 tablespoons ground ginger
  • 3 teaspoons ground allspice
  • 3 teaspoons ground cloves
  • 1 1/2 teaspoons ground nutmeg
Take these ingredients and put them in a small mason jar or some tupperware and shake them up good.
You don't need to use exact measurements and can alter to your own taste. My kids hate the taste of ginger so I usually cut it by about half.
On a side note, pumpkin pie spice tastes great sprinkled on your morning coffee or over your late night scoop of vanilla ice cream!
on Oct 07, 2013 | Cooking
How to freeze pumpkin
yes you should cook any veg before freezing. you will know by the smell and slimy texture of the flesh inside if it has gone bad.
Jan 12, 2014 | Birds
Can birds eat pumpkin seeds?
Yes, they can. You can feed your pet bird pumpkin seeds that you bought from the store, or you can take them out of a pumpkin yourself, clean them, dry them, and lightly cook them in the oven on tin foil. it is healthy and birds do find it tasty, too.
Dec 25, 2012 | Birds
97 ford explorer/bad front differential..can I remove it completly with the cv joints and let front wheels freewheel?
Yes is the short answer. Did you blow the gears in your front differential or you going to put a whole new pumpkin in? If you are replacing the entire pumpkin drain it first. Then make sure to support it with a transmission jack first. Remove the tires. Then remover the CV axles and lower the pumpkin. Your vehicle requires a 75w90 synthetic axle lube for a refill. Good luck.
Mar 06, 2011 | 1997 Ford Explorer AWD
Its a 2003 cts and there is a leak by the rear differential? its underneath the car towards the back end.
More then likely, it's the gasket that seals the pumpkin, or at worst, if you hit something you could have split, or cracked the pumpkin.
Your dealer is the best place to find out what it is, unless you have the apptitude to crawl under it and check to see whee the elak is from, or do a visual on the pumpkin.
You DO NOT want the rear end going dry ever..big bucks repair if that happens.
I hope this solves your question.
Thanks for leting FixYa.com...fix ya
Terry
Sep 14, 2009 | 2003 Cadillac CTS
Power coming from transfer case to the front pumpkin, nothing coming out of the pumpkin
I had a similar problem. I had to replace the actuator switch located on the right rear of the transfer case.
Mar 01, 2009 | 2002 Kia Sportage
Looking for after market pumpkin cover
jcwhitney.com should have what your looking for and they have good prices too
Feb 24, 2009 | 1999 Chevrolet Silverado 1500
Birds Logo
64 people viewed this question
Top Birds Experts
Tom Chichester
DaveMc3
DaveMc3
Are you a Bird Expert? Answer questions, earn points and help others
