Question about EuroTech EWC177 Front Load Washer / Dryer
It dosen't dryer
It don't dry
Clothes aren't drying...
First check and clean the lint trap. Next turn on the dryer and go outside to the dryer vent and make sure you have good airflow coming out. If you don't have good airflow then there is a blockage in the vent system somewhere.
Jul 26, 2012 | LG DLE7177 Dryer
Chirping while drying...why? what is causing this in a new gas dryer?
That is normal for a new dryer. It just means the parts are breaking in. In after awhile if it's still doing it, it should be serviced. But I don't think you'll have a problem down the road.
May 24, 2012 | Speed Queen ADG3LR Dryer
Dryer dosen't blow air
replace the blower belt and it will blow air from the dryer
Apr 20, 2012 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
Dryer takes too long to dry. GETS HOT...but not drying. Ran two cycles, frame work was hot, but clothes were not compelety dry. Note: not any lint either.??
make sure all the venting is clear of build up and debris,, clogged venting will not allow the moisture to escape the dryer resulting in damp and undry clothes ,, don't forget to check the outdorr vent and clear anything built up inside of that too
Jul 12, 2011 | Dryers
Does not dry clouse completly have to restart dry FDG648GFSO
Jul 12, 2011 | Frigidaire AGQ6000ES Gas Dryer
My magic chef dryer dosen;t always heat up. sometimes drys just fine other times when you put on auto dry it will go for hours and not dry.
it sounds like you will need to change the coils on the gas valve. They are working intermittenly.
Oct 11, 2009 | Magic Chef Dryers
FRIDGIDAIRE GAS DRYER MODEL # GLGR642AS2 IS NOT DRYING CLOTHES BUT GAS IS IGNITING. THANK YOU. DON
Hi Don,
So let me get this straight, you are getting heat from the gas burner and the drum rotates but your clothes remain wet? You can check a few basic things to identify where the problem lies.. First off, have you checked the lint trap and cleaned it? Secondly, have you checked your vent system ( meaning : are you sure it is not clogged anywhere in the duct or at the end where it exits outside? If that's OK.. when your system is drying clothes.. do you get hot air flow at the end of that duct? If not, your blower may not be working ..You need to move that hot air out of the tub for the system to dry. Heat, Motion to move clothes, air flow from the blower and an unimpeded path via the vent duct to outside.. Hope one of these things to check gets you going. Regards...
Sep 03, 2008 | Dryers
NOT GETTING HOT ENOUGH TO DRY TOWELS IN AN HOUR
It takes the dryer forever to dry a load of clothing, no matter how many pieces or thickness. Yes, I have already checked the vents out of the dryer, there not clogged. Any other suggestions?
Jul 09, 2008 | Whirlpool GEW9200L Electric Dryer
EuroTech EWC177 Front Load Washer / Dryer Logo
Top EuroTech Washing Machines Experts
shaun taylor
Are you an EuroTech Washing Machine Expert? Answer questions, earn points and help others
