Question about Yamaha RXV667 Receiver
No video out of yamaha RX-V667 receiver
I do not get any video out of my RX-V667 receiver. I try connecting HDMI in 1 thru 5, to HDMI out. No video. HDMI in to AV out, no video. AV in to AV out, no video. It will still play audio. So, I can run video direct to TV and then optical from TV to receiver for audio to get surround. The problem is that my on screen display does not work from the reciever so I can adjust center speaker levels, etc. I suspect that something to do with video is burnt out in the receiver. Any suggestions?
  • 1894 Answers
SOURCE: Connecting a YAMAHA RX-V2700 receiver to my TV and cable box
why not you use a normal AV cable
instead of hdmi cable
Posted on May 22, 2008
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
SOURCE: I have a Yamaha Rx-v363
this sounds strange, but is true. you need to run your digital audio optical cable from your tv to your receiver (after, of course, connecting tv/receiver via hdmi). so, hdmi from blue ray to rec - hdmi from rec to tv - then optical from tv back to rec. it's round about, but that is how yamaha says (and the only way it works) to do it.
Posted on Jan 04, 2009
SOURCE: Hi, I have a yamaha rx-v465 av receiver and have
I need a connection Diagram for the RX-V465 Yamaha receiver
Posted on Dec 30, 2009
  • 8546 Answers
SOURCE: Yamaha RX-V365 unable to receive 5.1 audio from TV with HDMI
If you're expecting multichannel sound FROM THE TV instead of from the source you're watching, it's not gonna happen. TV's are notoriously poor sound sources. This one is no different.
Multichannel TV-related audio is best found at its source - cable / sat / dvd / bd....
I run video-related audio from my video sources directly to my TV and their audio directly to my receiver. Specialization yields best results.
I'd recommend skipping the Receiver for video, too, as it adds a lot of opportunity for HDMI-related incompatibilities and sound syncing problems. The more interconnects in the path, the more distorted it will become and the more opportunities for problems. Plus you can bypass the receiver and listen to lo-fi programming like news and weather through the TV's speakers if you like. Save a buck on electricity.
Just curious, which HDMI on the receiver is connected to your TV? Input or Output?
This note is on Page 11 of the manual:
Audio signals input at the HDMI jack are not output from any speaker terminals but output from the connected video monitor. To enjoy the sound from speakers connected to this unit,
-- make an analog or digital connection besides the HDMI connection (see page 13).
-- mute the volume on the connected video monitor
"Check SP cable." -- The unit is perceiving a short circuit. Are your speaker impedances sufficiently high? Disconnect the Front Right speaker and try raising the volume again. The speaker may be blown or the cable shorting.
Posted on Apr 30, 2010
I Have an Yamaha RX-V1300. Is there anything I can to allow it to pass thru 3D video signal?
No. You'll have to connect the video to your TV and then pass the audio to the receiver. 3-D pass-thru was only added to some audio receivers with HDMI outputs in about 2010. The Yamaha RX-V1300 was released at least 7 years earlier. Video monitors/TVs with 3D display were virtually unknown when this model was released. You can find the specifications for this receiver here: (click on the Specs tab).
I wish that I had better news for you.
Dec 01, 2014 | Yamaha RX-V1900 Receiver
Need help for connection setup: We have a comcast dvr box using a HDMI cable to hook up to a Yamaha receiver RX-V667. To run thru the receiver & hook up to a DVD/Video unit Sony C600D to connected to a...
chances are your receiver cant take the signals from the component cabling and transfer it for the hdmi output if i understand your issue correctly try using the component out on your receiver it should work just not what u wanted there is probably no sound in your hdmi out on the receiver either options like these are often cheaped out on to **** people into just seeing the hdmi on the label if you take the time to look for a unit that has all the precise options you require i'm sure that you will be a happy man i hope this helps you and feel free to keep me updated as to your conclusion and also feel free to ask anything else in regards to your set-up ok : )
Nov 17, 2010 | Audio Players & Recorders
How to connect the PS3 to RX-V365 to get best sound qualitity in films. I have sony BRAVIO LCD wiht PS3 and I recently bought RX-V365 Yamaha home theater system. Please advice on connecting all three to...
You can connect PS3 video via HDMI to receiver and from receiver via HDMI to TV. But RX-V365 doesn't support HDMI audio, so you have to connect audio separately via SPDIF digital cable. I think PS3 uses optical SPDIF, so you will need optical cable. If you can't find cheaps optical cables in your shop, you can try byuing from ebay ($1-5 max.)
Feb 13, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
I have yamaha rx-v465 receiver and yds-11 docking station. how can i get tv{through hdmi 1}to display what's on ipod.i have nano w/video camera{newest one]. is this possible
I think it is not possible, because RX-V465 does not have HDMI-video processing. It can only pass-thru the HDMI video to HDMI-out, but not alter the signal in any way.
If it should support TV output with YDS-11, it will work only via analog video out (s-video / composite / component).
Dec 30, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
I have a Yamaha RX-V863 receiver connected to a
Do you have all 5+1 speakers connected? You need to go to the Setup menu of yamaha and set which speakers you have and which you don't. For example if you don't have the Center speaker connected, receiver will redirect and mix the sound to the other speakers.
Blue-ray film over HDMI should automatically output via all your configured speakers (nothing to be configured).
Nov 26, 2009 | Yamaha RX-V863 Receiver
Yamaha RX-V2700 skipping when playing a DVD on Toshiba D-R400
Sounds like a poor grounding issue between the units OR maybe they're not as compatible as the Mfg's say.
Could be a bad HDMI cable also. Most are made in the land of Nanking
Jan 18, 2008 | Yamaha RX-V2700 Receiver
Yamaha RXV667 Receiver Logo
42 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
