Question about Kitchen Ranges
Rangetop works, Broiler works, oven does not.Electrics seem fine; Should I check the solenoid valve first?
  • 5,911 Answers
For future reference, you need to explain whether this is a GAS or ELECTRIC range. It does make a difference in diagnosing the problem you have.
If this is a GAS range, the problem is more than likely a faulty igniter on the bake manifold. Since the bake feature gets used more often, it is common for the igniter to wear out faster. The following link explains how the igniters work and instructions on replacing one:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
If this is an ELECTRIC range, the problem is more than likely a defective heating element for the bake feature. The same reason applies. Since the bake feature gets used more frequently, the elements wear out much quicker. The next link explains how to replace a heating element:
http://www.fixya.com/support/r469407-replacing_bake_or_broil_element_in
I don't know what solenoid you are asking about, but if this is in reference to a gas safety valve or regulator, you would have similar problems with the broil functions if the there was a gas flow problem. Since MOST ranges are fed from a common regulator, gas flow to all the features would be impacted.
Replacement parts can be purchased on line at appliancepartspros.com, pcappliancerepair.com, searspartsdirect.com or repairclinic.com. All these sites offer great service with competitive pricing, so shop around for the best price. If you have any questions, please let me know. I hope this helps you.
Posted on May 19, 2009
My tappan oven won't work. stove and broiler work fine. ignighter glows but it seems like there is no gas.
I would check with your manufacturer and see if a professional can diagnose the regulator and even the gas valve itself.
Jul 17, 2012 | Tappan Ovens
Flow plug
even though the ignitor seems to glow bright orange,it still maybe weak,as in not enough current to open the gas valve,an easy test is to just swap out or interchange the broiler ignitor and bake ignitors and see if this takes care of your issue on the lower bake side as most units use the identical ignitor for each upper and lower manifolds and the gas valve supplies both the bake and broiler manifolds depending on which you choose to use bake or broil
May 28, 2012 | Jenn-Air Chef Gas Oven Range Ignitor Flat...
Gas Oven - no flame at Bake Baffle - Glow Bar glows fine
If the glow bar is working (glowing) it is the gas valve. BUT, the glow bar can also actually glow and still not be working 100% and letting enough current through to the valve. You could swap an identical valve out to check it, if you don't have a meter. It's more than likely the valve though.
Jul 23, 2009 | Kitchen Ranges
Oven not working. Top, broiler, and warmer are working.
Have you checked for proper gas flow into the over or broiler? This is a gas valve back there that will sometimes go bad. Also there is a sensor near your knobs, it is a timer that will go bad, the valve is about 85 dollars and the timer is about 65 dollars
Feb 08, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Hotpoint Gas oven doesn't light
Is the gas valve easy to replace on a gas oven?
Nov 14, 2008 | Hotpoint RGB745 Gas Kitchen Range
Sf195lehz5 free standing gas oven,
Check both gas valve solonoids for 216 ohms [blue broiler wire to the orange common and red oven wire to orange common] both must be ok.
Check oven temp sensor for 1080 ohms.
If above are ok then the problem is either the spark module or the control board.
Since the gas valve was not opening and there was not ignitor sound I replaced the spark module for about $90. You have a 50-50 chance of being right.
My range is relitively new and I'm haveing an oven light problem which I traced to the control board so I may replaced this board to for about $200.
HS
Oct 05, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Oven will not work,burners and broiler all work fine
under the floor of the oven, possibly can be see by removing the bottom drawer. the ignitor is hte most common aprt to go bad in any gas oven, visually it might not even look broken though and some even appear to glow(just not strong enough to open gas valve
Mar 01, 2008 | Kenmore 78570 / 78571 / 78572 / 78574 /...
Kitchen Ranges Logo
143 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
