The picture is either distorted, fuzzy, or goes off, and on. The sound also goes off, and on.
This problem makes it very annoying, and impossible to get much out of my Roqu. Please help me.
  • 27,725 Answers
Which operating system ?
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd and floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
Check your RAM.
The RAM is located in the middle of the motherboard.
There are tabs that you can push to release the RAM.
Remove it and put it back in place until the tabs pop out.
Loose RAM can cause your computer not to start properly where you want to see a video signal.
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots, lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes.
If reseating the memory did not resolve the issue try swapping the location of the memory.
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red Xright click select reinstall drivers
If your computer came with a motherboard disc the drivers could be on it
if you dont have a motherboard disk you will need to download the drivers
Make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
Restart your computer then reinstall it this should activate found new hardware wizard
Check the vga lead for secure dust free connection or try another vga lead.
Posted on Dec 30, 2013
Picture fuzzy, lines, distortion
Get some glasses. It is your eyes.
Apr 04, 2014 | Panasonic Televison & Video
The picture is fuzzy and the color is distorted. the sound works, but the picture is messed up
It sounds as if it may be the convergence if the picture looks out of alignment or 3D appearance.
May 05, 2011 | Sony KP-51WS520 51" Rear Projection...
Doubled colors, fuzzy
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 01, 2010 | Philips 60PP9202 60" Rear Projection...
Logitech quickcam gi ves me fuzzy picture when i
A bit of fuzziness is expected especially when you move. How fuzzy depends on speed of your computer and the capture ability of the camera. I have quickcam that is 1.3 megapixel. Stationary objects are pretty clear, but all motion is fuzzy and distorted. Move slowly to help minimize the distortion. When using instant messaging or Skype, set camera to a smaller image size for faster compression and transfer.
Bret
www.1-2-1computerservices.com
Oct 06, 2009 | Logitech QuickCam Messenger Web Camera
Recorded acoustic guitar is fuzzy and distorted
Try anouther Microphone sounds like the frequence sprecturm is to low.
Jul 09, 2009 | Samson C01U USB Condenser Microphone...
PICTURE IS FUZZY AND DISTORTED
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
May 26, 2009 | RCA HD52W59 HDTV Projection Television
Fuzzy/ distorted tv pic
*Screen Looks 3-D
*Colors wont align
Dec 22, 2008 | Toshiba 57H81 57" Rear Projection...
Fuzzy and flickering picture
try bending the connectores slightly up and down and check if the problem will be fixed, if that seems to solve the problem purchase anothe AV cord for your PS2 also try testing your PS2 on another tv and then let's see if it will solve the problem
Jul 05, 2008 | Sony PlayStation 2 (PS2) Console
My Mithsubishi HD-1080 rear projection tv 65 picture warps and distorted when first turned on.
sounds like your convergence ICs are getting weak, or the solder may need to be touched up.
Apr 06, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Hitachi screen goes snowy and sound is totally distorted
Sounds like bad solder connect in tv tuner....can usually be
repaired or replaced.......................T.
Nov 30, 2007 | Hitachi 43FDX01B TV
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
