Question about Zenith Televison & Video
Head alignment Top of picture in both VHS or DVD playback is distorted. Adjusting the tracking has no effect on problem but does as it should in fuzzing the picture.
  • Zenith Master
  • 5,449 Answers
Tracking controls for VHS should have no effect on the DVD player. If a pre-recorded DVD is distorting the picture, along with the VHS, then there's either something wrong with the TV it's played on, or the connection, between the two. Or there is a fault in the electronics of the VHS/DVD combi that deals with the picture.
Posted on Dec 30, 2013
  • 275 Answers
SOURCE: playback is poor quality, tracking wont fix it and have cleaned head
Dear Iain, Do you route your Cable / Antenna through your VCR's Inputs (at rear) ? If yes, Do you find that the video of these cable /antenna channels is good? If the answer is yes again,then, in all likelihood, you are having a machine with dirty Video Heads.Did you use a 'Wet' Type Head cleaning cassette? If no, then I suggest you get one and use it. Again it is entirely possible that the Video Heads are worn out. How old is the VCR? How many tapes have you played back on it? Do you observe some black streaking along the edges of the images on the screen, which increase or decrease when u change the tracking? If yes, then it is time to get the Video Heads replaced.In India they would cost an equivalent of US$ 10-15. I do not know how much they would cost in your country, but it cannot be much more.
Posted on Jul 28, 2006
  • 158 Answers
SOURCE: Everything's in black & white
are you using the s video socket if so you will get black & white picture you need to use rca phono to rca phono or rca phono to scart lead to record to dvd burner. as I do alot of copying over myself i never use s-video socket due to cable wrongly wired for colour just black video signal. hope this works for you
Posted on Aug 15, 2007
SOURCE: rolling static pattern
Solved! (I hope??).
The cable from the Keyspan to the AG-DS555 deck had an extension cable - when this was removed, the rolling specks disappeared!!! I tested the same set-up on a JVC DV deck and didn't see any problem?? But I suppose that S-VHS is much older technology - I hope that this was it!
Guess the moral of the story is - check every cable!
Posted on Mar 28, 2008
  • 458 Answers
SOURCE: vr / 712 / hifi / picture scrammble / fuzz /
From your description it appears you may have dirty heads. Either try a video head cleaner tape or better still , remove the casing & using either a proper head cleaning tool & an appropriate head cleaner fluid (isopropal alcohol) very gently wipe the heads, Do Not put too much pressure or rub too hard as this will damage the heads. If this does not cure the problem then new heads will be required.
Your VR 354 is possibly the whole of the tape path needing cleaned especially the pinch roller (black round roller on the right hand side) this might be worn & again needing replaced
Posted on Jul 22, 2009
  • 16 Answers
SOURCE: Toshiba DVD video recorder/video cassette
need to adjust the arms that hold the tape around the main cylinder use a small screwdriver and adjust each one slightly until stable
Posted on Jan 05, 2010
Testimonial: "This worked OK thanks. Needed a special screwdriver but I made it work with regular one. Thanks"
Tape playback on Magnavox MWR20V6
When was the last time you ran the "head cleaning" tape in the machine? As tape collects dust and dirt - it gets deposited on the recording and playback heads. This ruins playback and recording quality. Also, since tape is magnetic - they tend to magnetize the heads, too (just like reel to reel, 8 track & cassette player / recorders). Demagnetizing them will help too. Here are links to both products:
head cleaner
head demagetizer
Feb 26, 2015 | Magnavox Televison & Video
Image distorted on panasonic nv-fj620
I can't say for certain but it sounds like the video head might have gone. The good news is that you can get the parts from Curry's Partmaster website. Perhaps cheaper elsewhere? The bad news is that video heads are not cheap!
I don't know how you cleaned the head. So I would advise trying again to make certain. I would recommend cleaning with Servisol Video 40 several times. If that still doesn't work I would assume the head to have gone.
Dec 16, 2012 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Buzz during playback, but only on SOME tapes!! When i adjust tracking manually, pictures quality suffers.
Bad recording VHS or old VHS tapes,will sometimes causes this problems,because of degrading magnatic tapes.Sorry this problems,u did the fixed adjusting manual tracking,that it not fixing the problems,sorry that all u will getting that kind of quality of picture.
Mar 21, 2011 | GoVideo Go Video DVD/VCR Combo
Sony pvw2800p-when done with the recording & then playback at different machine,there seem some picture distorted(at the top frame)like recording in a low head quality,but already changed a new...
distortions are present on the same machine?
Need to check the squareness of recorded frequency mod packages, using a test tape CR2-1B. Distortion at the top of the frame it misses the heads on track while entering. Adjust S-reel achieve squareness packages.
Feb 23, 2011 | Sony PVW-2800 VCR
WILL NOT TRACK. +/- BUTTONS ON FROM OF VCR ARE FUNCTIONAL, BUT IMAGE OF IMAGE IS DISTORTED AND NOT IN COLOR.
I will assume you have tried to clean the video head, if you have not use a wet or dry cleaning tape "dry better choice" and see if that will work, the other option is use a brand new store bought blank tape T120 and set the vcr speed at sp and let it run all the way through. If all this fails it means either the video head is bad or you need alignment done inside the vcr.
Jan 10, 2011 | Sony SLV-N750 VHS/S-VHS playback VCR
LG RC195 dvd/vhs combo
Do you just get a snowy screen when you playback? I think the first thing to try is to clean the video heads. Either try a head cleaning tape, but these are not always the best thing, better still is to remove the lid & carefully using a head cleaning fluid (isopropal alcohol) & a thin piece of card or head cleaning stick (NOT a cloth), carefully & gently wipe the heads which are on the round silver drum. Do not use too much pressure or you will damage the heads, give it time to dry (couple of minutes) & then try playback.
Jul 20, 2009 | LG Televison & Video
After recording a program using the Toshiba W522, the picture rolls and jumps up and down, while in playback mode. I have no problem with recording, its just when its time to actually watch the program,...
If the tapes are old or cheap, they may simply be no good. However, I found that the automatic tracking is the best thing to ensure perfect quality picture and sound.
Jun 22, 2009 | Toshiba W522 VHS VCR
Picture bounces up and down
All new VCR's are auto tracking however, you should be able to manually track it using your remote, or there are a few reasons that the auto track can fail, the tape may have worn or ragged edges which means that the control head cannot get a clean reading, the control head may itself need cleaning or the tape path requires adjustments, adjusting the guides really needs to be done by a technician as a reference tape is used, or that the heads are low and a good video signal cannot be obtained to gain a reference point....Phil
Dec 15, 2008 | Sylvania 6240VE VHS/S-VHS playback VCR
Vhs playback problem
either extremely dirty heads or there is a tv/vcr button that needs to be toggled. Most have auto tracking, old ones have a knob or 2 buttons under a panel somewhere for tracking.
Dec 02, 2007 | Panasonic DMR-ES30VS DVD Recorder/VCR
VHS Picture on new recorded tape shows horizontal bars.
clean the head of your vcr that will help also connections of the wires good luck.
Mar 29, 2007 | Sony SLV-D550P DVD Player/VCR
Televison & Video Logo
76 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
