Question about Apple 24" iMac Desktop
2006 Intel iMac will not turn on
2006 iMac will not turn on at all
  • 48 Answers
Try the genius bar at your closest Apple Store.
Posted on Dec 31, 2013
IMac Intel 2006 will not turn on
To you get a white power light when you press the power button? If so, does the power light flash in a repeating pattern?
Dec 29, 2013 | Televison & Video
MA878LL iMac 24" core 2 duo 2.4 do not turn on,
Checking the power supply isn't the easiest thing to do, it involves pulling apart the entire machine.
You can try resetting the SMC, unplugging all power, hold the power button for 5 seconds, replace power, then attempt to turn on.
if it still won't turn on, and assuming you didn't get AppleCare or it is expired (past 3 years) it might be worth taking in to an Authorized Apple Repair Facility and see if they will check it out for free. If it is under warranty, most definitely take it in or call 1-800-APL-CARE
If neither of those are an option, Power Supply http://www.ifixit.com/Apple-Parts/iMac-Intel-24-Inch-2-4-2-8-GHz-or-3-06-EMC-No-2211-GHz-Power-Supply/IF169-002
a tear down from iFixit for the 20" model, it is most likely very similar for your model as well http://www.ifixit.com/Guide/Repair/Installing-iMac-Intel-20-Inch-EMC-2133-and-2210-Power-Supply/1006/1
Hopefully that helps. Good Luck
Feb 23, 2011 | Apple MA878LL iMac with 24" Screen Desktop...
Locks frequently and restarts sometimes all by itself. Parts of the screen regularly skews in triangular shapes.
  • Verify that the power outlet you're using is good and your power cable is firmly connected to the wall outlet-if using a surge protector, be sure that it's firmly plugged into the wall outlet. Also, try temporarily plugging directly into the wall outlet to eliminate any issue with the surge protector; plug a different electronic device into the same wall socket to make sure the socket works, and also try the iMac's power cable in a different wall outlet.
  • Make sure the computer's power cable is firmly connected to the computer.
  • If any external devices are connected to your iMac, disconnect them and try to turn the computer on again. If the iMac will power up when those devices are removed, but not when they are connected, contact the manufacturer of those devices for assistance.
  • Try resetting the iMac's SMC
  • Remove and reinstall the SO-DIMM memory modules, located in the bottom of the computer.
  • Resetting the SMC for Mac Pro, Intel-based iMac, Intel-based Mac mini, or Intel-based Xserve
    1. Shut down the computer.
    2. Unplug the computer's power cord.
    3. Press and hold the power button for 5 seconds.
    4. Release the power button.
    5. Attach the computers power cable.
    6. Press the power button to turn on the computer.
Nov 12, 2010 | Apple 2.16GHz iMac Intel Core 2 Duo...
Want to change my 250 Gb Hard drve for 1 tb. Intel 2006 g5
You probably will have to partition it as your system may not recognize 1TB
Mar 13, 2010 | Apple iMac Z0CY Desktop
The startup window on my iMac 2006 Intel dual core stays on. The spinning circle just keeps going. I can't get past this point.
this seems to be a issue with the internal hard drive if it does not pass the logo screen, You might need to have this repaired, call you local apple store make a appointment to bring in your imac. sounds like a hard drive corash correct me if i am wroung I been working on macs for 5 years not to long huh? But I am knowledgeable is why you see the apple icon next to my name. Have the hard drive checked you be glad you did.
Dec 02, 2009 | Apple iMac 24" Desktop
IMac 24 intel no startup sound_black screen_but light is on
Try inserting the master (system) disc that came with it and hold down the "C" key while booting. If it comes on with the OS X installer, try disk utility to reset permissions, if that fails to solve it, start again and this time when you get the install disc up get to options and do archive and install. If that has no effect, get out your Apple Care ( you do have it don't you?) and take /send it to Apple.
Aug 19, 2009 | Apple iMac All-in-one - 2.66GHz Intel Core...
Will Virtual PC for mac v7 work with an new iMac (Mac OS X, Version 10.5.7)?
Basically, if your new iMac has the new Intel processor (or any Intel based processor Macs) your Virtual PC v7 will not work on it. It is designed for iMacs/Macs that are not Intel Based machines (that run on the Motorola processors like the G3, G4 lines, etc).
All Intel based iMacs/Macs are capable of running Windows using a Dual boot startup that is available at the Mac Store or online. Check the Apple website for instructions, they are always updating the software. :)
Jul 19, 2009 | Microsoft Virtual PC 7 with Windows XP...
Is imac g5 17" lcd compatible with imac intel core duo
Possibly, the newer G5 Imacs feature Intel 2 Core Duo Processers. While older generations, do not support Intel Core Duo or Intel 2 Core Duo Processers.
Jul 09, 2009 | Apple iMac 17" MA199LLA Desktop
Vertical line in imac 17" core 2 duo intel 2006 model
Attach an external monitor (you may need to buy an adapter to try this) and turn on Display Mirroring in the Display preferences.
If the same symptom shows on the external monitor, then you've got a video card problem. If not, I'd say you're screen has some kind of damage of failure.
Sorry, but either one is likely going to require a trip to the Apple Hospital.
At least with the display problem, you could use the external monitor until repaired.
Mar 16, 2009 | Apple iMac G5 Desktop
Apple 24" iMac Desktop Logo
53 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
