Question about HP 2.0 Compact Speakers BR387AA Unit Only
2.0 Compact Speakers BR387AA Unit Only - HP 2.0 Compact Speakers BR387AA Unit Only
How do I get access to repair loose wires?
Some compact speakers are accessible internally only by removing the the grilles but caution is advised as some grilles are glued on to prevent rattles.
Aug 05, 2015 | HP 2.0 Compact Speakers Br387aa
Popping sound
Check for any external shorting of the speaker wires. Check for kinks or cuts in the cable that feeds the speakers. Also check the posts or socket at the back of the speakers for damage or wiring shorting out. Proactive IT Support PC Repairs Laptop Repairs Custom Built PC Leading IT...
Sep 22, 2017 | JVC Mx-kc38 220w Compact Component Audio...
I have "Coby CS-MP37 compact
You can find answers here and here on FixYa...
Aug 10, 2011 | Coby CS-MP37 Computer Speakers
My nakamichi compact receiver1 powers up when i hook speakers up to it there is no volume. digital display is on shows station and power on
This unit is in protect mode which means that a problem was detected in the final amplification stage and the speakers are not turned on. This is to prevent damage to the speakers. Depending up on the cause of this, the part cost should be in the $5-$40 range.
Please confiorm the model number and I will try to get more specifics in regards to probable parts and costs.
Thanks,
Dan
Mar 02, 2010 | Nakamichi Audio Players & Recorders
Unit cuts off after 1-2 minutes of playback; does not recharge ip
http://logitech-en-amr.custhelp.com/app/answers/detail/a_id/7207/session/L2F2LzEvc2lkL2VvbmE0eGdr
Nov 17, 2009 | Logitech Pure-Fi Anywhere Portable...
Speakers
You should be aware of the power output of the shelf system and at what ohms. Ex.--100watts @ 8 ohms. Which I think that is the rating of this unit. This means you will get 100 watts of power on the front left side and the front right side, if you hook up one 8 ohm speaker per side.
Apr 09, 2009 | Sony MHC-RX100AV Shelf System
I have 2 10inch spekers in a box that just stopped playing the bass! can anyone help? ive checked the fuzes!
If the fuses are good , this could still be a prob with amp, check spkrs with a ohmeter(cheap one from the Shack or anyplace) by touching both leads to spkr terminals, disconnect spkrs first.Have ohmeter set to ohms Rx1 and you Test amp out put by connecting two spkrs that you know are good. Good luck and please rate this answer,thanks.
Apr 06, 2009 | Mac-Audio Compact 220 Car Subwoofer
Radio on IP player comes up with mute on
The problem is solved. We changed the unit for one that works.
Jan 02, 2009 | Logitech 984-000005 Pure-Fi Anywhere...
HP 2.0 Compact Speakers BR387AA Unit Only Logo
18 people viewed this question
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
