Question about Sewing Machines
When I turn on my Singer H74 sewing machine and lower the needle to start sewing it makes a horrible noise then the needle moves in really slow motion, then jumps backwards.
H74 Singer Sewing Machine about 1 year old
SOURCE: need manual for Singer sewing machine model#100, about 12 years old
I have a manual for this machine..is there something specific you needed to know from the manual?
Posted on Mar 27, 2008
SOURCE: singer stylist sewing machine 534 is not stitching
Feed dog drive gear(2) are plastic and are probably stripped. Always replace them in pairs. While you are at it replace both hook drive gears as well. It will run as good as new.
Posted on Mar 28, 2009
SOURCE: singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
Posted on Apr 08, 2009
  • 52 Answers
SOURCE: Brother 270D Jams when sewing anything
You might have thread caught in the take-up lever linkage and it has soaked up all the oil my recommendation would be take it to your local dealer
Posted on Jun 25, 2009
  • 139 Answers
SOURCE: how to thread & what needles for singer 660 A2 sewing machine
You can download a manual here:
http://parts.singerco.com/IPsvcManuals/
Posted on Apr 07, 2010
Why does it make a knocking noise as it sews?
the needle position is up tight in the holder and no where else
the cut away bit of the needle faces the bobbin case hook and the groove in the needle faces the end of the machine and gives clearance for the thread to pass through the material
from your description and what you did, the needle /hook timing needs adjusting as it is out
turn the machine over by hand as in sewing and watch the position of the eye of the needle and the bobbin case hook
just as the needle starts to move up, the hook should be just above the eye of the needle at the edge of the needle
The adjustment is by loosing off the screw on the vertical shaft at the end of the machine that is attached to an arm that moves the needle up and down and move that bit up or down until the needle is positioned correctly to the hook
tighten up the screw
next is to check the needle tension is not too tight
workshop manuals are available on line in pdf version or take it to a sewing machine repair shop for a proper diagnosis
May 12, 2016 | Singer Stylist 7258 Electric Sewing...
I have a Singer Futura XL 400 and broke a needle sewing flannel. The machine made a horrible noise, did the flashing lights, and then turned off. When I could turn it on again, It would not sew. I h
If I was you, I would ask Darlene Cahill. She sells and works for singer. You can contact her at darlene@darlenecahill.com. She has answered many of my questions.
Feb 16, 2015 | Singer Futura Xl-400 All-In-One Sewing And...
Singer Touch-tronic 2000 makes loud humming/buzzing noise, stitch selector lights quit working, needle bar stopped moving.
Sounds like you've got a thread jam going on in the bobbin case area. Good cleaning and a new needle will probably fix it. See: https://answers.yahoo.com/question/index?qid=20091202121550AAHxN8y
Apr 20, 2014 | Sewing Machines
Singer curvy 8770 needle wont move
possibly has a broken belt a repair shop might be your best bet
Sep 27, 2017 | Singer Curvy 8770 Electronic Sewing...
My Husky Mega Quilter is making a loud noise in the bobbin area. The noise increases in volume and intensity the faster I sew. At very slow speeds the sound is absent. I thoroughly cleaned and oiled the...
Perhaps Husky could help you, online. They Really want satisfied customers, and Huskys a Great machines!
A quick fix might be to change your needle. Even a slightly bent needle could cause havoc in the bobbin area. Hope it helps. Needles cost more that they did back in the day, but that sound is bad for your machine!
Jan 27, 2018 | Singer 14SH654
My Singer Futura sewing/embroidery CE-200 machine is malfunctioning. It will sew a few stitches and then make this horrible sound and doesn't move. Once stopped, the needle feels like it is boun
try changing the needle--make sure the needle is correct for the fabric
clean under the needle plate & in the bobbin area for lint or loose threads
if it keeps jamming up & making noises I suggest to have the machine
serviced
Apr 12, 2012 | Singer CE-200 Quantum Futura Computerized...
Brand new machine. Heavy Duty Singer 4423 I sew ripstop tarps including a double layer of grosgrain edging. After one tarp the machine has begun to squeak horribly with each stitch. Why? What can I do as...
I would suggest that the words "heavy duty" applied to a machine sold for less than $150 is probably taking a little bit of artistic licence.
Grosgrain edging is very stiff so you will probably need at least a 100 size needle for this and they may well go blunt pretty quickly. This could be the squeaking noise, needles will "pop" and squeak if they are blunt. Change the needle and see if it stops.
I would suggest that if you are doing straight stitching in large volumes for commercial purposes, this is not the right machine, you need something like a Singer 20U industrial machine, a good workhorse which will do straight and zig zag stitches.
I have one of these with a 3/4 hp motor in a table and it is so strong, great for sewing tents, horse blankets etc. We used it for attaching vinyl to 1/2" foam for ride-on tractor seats, something it did really well. Different needle system to domestic machines and can sew heavier gauge thread too.
Sorry, this probably isn't what you wanted to hear about your new machine. Try changing the needle and see if it stops the squeaks. But you may need to reconsider your choice of machine.
Aug 30, 2011 | Singer 4423 Sewing Machine
When the needles go down the lower looper move on the back of the needles goin up the lower looper moves in front of the needles and causes the thread brake and makes a craking sound when the lower looper...
I have a Singer 14SH654 Serger, trouble started when I broke a needle. I replaced needle now it does not sew properly with two needles. Can anyone help me
Jul 03, 2010 | Singer 14SH654
Singer Model 5050 Timing Problem
Actually,timing of needle vs, shuttle is not very easy job several factor you should check on.There is belt ot sometime a shafting with worm gear and helical gear under machine w/c drive the shuttle with the bobbins in timing order,Any one of them is present on the timing adjustment can be done by releasing the belt or the helical gear,besure machine is unplug then set all mechanism on low dead center meaning the needle move to utmost lower position catching this by the shuttle and bobbins at center position.No motion applied if this was set up,engage the belt with pulley and the bobbins link holder tigh allenscrew besure the needle is lower dead center at the center of shullle bobbins catching needle without motion when setting back at original position.If this was made manually move it on handwheel going up and side down the needle gradually if the needle move freely several time and it was catching this by the shuttle hook bobbins.if ok put thread bobbins and upper thread dial tension with the needle.Move machine on handwheel try to catch the bobbins thread,If this so your machine is ready to sew again if problem occurs on alignment repeat adjustment on perpect alignment,besure all parts on upper casing of machine specially two drive gear are in normal alignment.
Mar 15, 2009 | Singer 5050 Mechanical Sewing Machine
Wheel won't turn
The same thing happend to me with an older model (Singer XL 10). I have been sewing a decorating stitch and the machine stopped suddenly. Now I am not able to turn the hand wheel anymore like I should (I can move it a little bit, but the needle does not move up and down and the wheel is getting stuck). When I try to use the pedal the motor makes a horrible noise and stops. The needle is not moving up and down.
Is there a solution for that problem? I moved from Europe to Australia and have not used my machine since. Today is the first day, I was cleaning and oiling it and it first sewed perfectly. In case that there would be thread stuck somewhere, how could I possibly clean that? I already took off the plastic from the head, but I can not see where the problem is.
Any help is appreciated. Thank you!
Best regards,
Nelly
Jan 12, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
