Question about Air Purifiers
How do I clean a theropure air cleaner - Air Purifiers
Fan on air cleaner blows out top but does not suck
If air is blowing out - it most assuredly is getting in. The area of the intake make be large enough for you to perceive air being sucked in.
Make sure ALL filters are clean. Remove and replace disposable filters or wash and replace permanent filters. Do this for pre-filters too. Then, try again.
Oct 23, 2015 | Hunter 30200 Air Cleaner Purifier Filter...
Honeywell Air Cleaner
Is the filter clean?
Are the ionizing wires clean? gently wiping them with 600 grit finishing paper should clean them up and restore perfomrance.
Is unit bent? If so it may be shorting out.
is unit fully seated and making contact?
Jan 31, 2012 | Honeywell FC37A1064 Air Purifier
I just found out we have an enviracaire elite system in the attic which was switched off. how do we clean it? does it have a removable filter? Model: 2084175 120 vacd 60HZ dim: 18 x 25 -- thanks -- ...
CLEANING PREFILTER(S), CELL(S) AND POSTFILTER(S) CAUTION Sharp edges. Can cause personal injury. Carefully handle cell(s) or wear protective gloves to avoid cuts from sharp metal edges. Setting a regular cleaning schedule To ensure optimum performance from the air cleaner, the prefilter(s) and cell(s) must be cleaned regularly- twice a year with normal use or more frequently with heavy use. Use the wash reminder schedule below to help establish and maintain a regular cleaning schedule. Mount the wash reminder schedule in a convenient location. NOTE: You may let the heating or air conditioning system operate normally while the cell(s) are being washed. Simply turn off the air cleaner switch. Cleaning your Prefilter 1. The quickest and easiest way to clean your prefilter is to use the brush attachment of your vacuum cleaner to vacuum the lint off the dirty side of the prefilter. Greasy dirt may require soaking the prefilter in a tub or rinsing with the garden hose. Do not wash the prefilter in the dishwasher or car wash 2. The prefilter should be cleaned every 6 months or more frequently with heavy use. This will keep the prefilter clean of air choking lint that can make your system work harder. Vacuum the prefilter with a brush attachment, rinse it with a hose, or soak it in a tub. Do not wash the prefilter(s) in the dishwasher or car wash. Cleaning your Cells 1. A quick cleaning of the cells can be done by simply wiping down the ionizer wires with a damp cloth. This will help boost the efficiency of the air cleaner between full cleaning cycles. Ths quick clean can be done every time the prefilters are cleaned. 2. A full cleaning of the cells will return the air cleaner to its peak efficiency. An easy way to wash the cells is in a tub of hot, soapy water. Just soak the cells until the water cools, agitate and rinse. For details on cleaning cells, see below for Washing the cell(s) in a tub or Washing the cell(s) in your automatic dishwasher. 3. Because the efficiency of the air cleaner remains high even as it loads up with dirt, a full cleaning of the cells can be put off for yearly maintenance and a quick cleaning can be done more often. Those wishing to renew to peak efficiency or with heavier use may want to wash more frequently. Replacing your Postfilter 1. The postfilter is an optional filter that boosts the efficiency of the air cleaner. Do not wash the postfilter because that will neutralize the factory applied charge. 2. The postfilter should be replaced every six months to ensure peak performance.
Mar 03, 2011 | Honeywell Enviracaire Elite F300E-1019 Air...
Makes buzzing sound after cleaning blades
I keep the blades clean. Really clean. I'm a smoker, and you would not believe the crud that accumulates on those "blades"... <g>
First, I spray the blades with "PurplePower" cleaner/degreaser (from AutoZone), then I wipe them down with a sponge, then rinse with hot water. then dry them with compressed air (I have a compressor...).
FWIW, "Windex" works pretty good too, but... the degreaser really works well on the cigarette "residue"..
Second, there are two long wires inside that also have to be cleaned, periodically.
If your unit has the "pull-tab" cleaner, use it. One of my units has it. The other two don't.
On the ones that don't have the built-in cleaner, I stick a chopstick in through the rear vents, and CAREFULLY rub it against the sides of those wires, which "scrapes" the "white crud" off of the wires. Take your time. You will likely have to "change locations" several times in order to access the full length of both wires.
NOTE: those wires are fairly durable, but BE CAREFUL with them.
Either way, after cleaning the wires, I then "blow" the unit clean with compressed air.
Voila! No more buzzing. Until the next time the wires get "crudded up".
Mar 12, 2010 | Ionic Pro CA500 Air Purifier
The Honeywell electronic air cleaner constantly "snaps" even though it is clean. I have inspected the wires and fins, clean and spaced properly. Any suggestions?
It is normal to hear occasional snapping from your Electronic Air Cleaner. This occurs when larger particles are caught by the ionizer wires. Continuous snapping is not normal .Remove both the cell and check clean the bottom portion by using a vacuum cleaner attachment. If the snapping continues with the cells remove contact your contractor.
Mar 05, 2010 | Honeywell (F50F1032) Air Purifier
After cleaning my electronic filter, it runs well for about a day. Then, it begins to continuously arc until I wipe the wires clean. Again, no arc for awhile, then, continuous arcing. Is there something I...
It is normal to hear occasional snapping from your Electronic Air Cleaner. This occurs when larger particles are caught by the ionizer wires. Continuous snapping is not normal however, and should be investigated as outlined below: Please note that the metal electronic cells may have some sharp edges; use care when handling the cells. Wear gloves to protect your hands from being cut if needed. Remove both electronic cells. Make sure that there is no hair, dirt, sand or any debris on the bottom inside the Electronic air cleaner. If there is, remove what you can by hand. If a lot of debris is left in bottom of the Air Cleaner, you may want to use a vacuum attachment to see if you can vacuum up what you can. Do not vacuum the Pre-filter or Post filter this may damage it. Close the access door, and then turn on the Electronic Air Cleaner and the system fan. If the snapping continues with the cells removed, contact your heating and cooling contractor for service on the unit and turn off the Electronic Air Cleaner’s power. If snapping does not continue, make sure the electronic cells are clean, dry and properly installed. Inspect the electronic cells for bent collector plates, broken wires between the plates, dirt on the insulators, and damaged collector contact tabs located on the top of the cells. Make sure the pre-filters are in good condition and are in the cabinet slot farthest from the furnace (The order of the Electronic Air Cleaner Filters are from the return duct to the furnace is: Pre-Filter, electronic cell, and then Post filter, if your Electronic Air Cleaner has one). If the snapping persists and you are unable to locate any physical cause, please contact your heating and cooling contractor for service on the unit and turn off power to the Electronic Air Cleaner.
Jan 25, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
I cleaned the cells on my Honeywell electronic air cleaner and now it won't run. The CHECK led is lit. Got any ideas?
Make sure the furnace or air conditioner blower is running.
Make sure the access door is firmly closed and latched. If door is not closed properly, an interlock keeps the air cleaner off.
Jan 13, 2010 | Honeywell (F50F1032) Air Purifier
Blades will not go back into the air cleaner
lean the machine at an angle so the plastic flipper lock inside falls back in place
Sep 06, 2009 | Ionic Pro TURBO Air Purifier
Electronic Air Cleaner problem
The presence of “white dust” is actually an indicator that your Electronic Air Cleaner is working properly. The Electronic Air Cleaner can only filter the particles that are passing through your system’s duct work. The staining particulate is generally lighter, and more able to be drawn through the return registers in your home, leaving the heavier, non-staining particulate behind. This heavier, non-staining particulate settles out of the air and is left behind on your furniture: because it is more visible, it may appear as though there is actually more dust in your home than there was prior to installing the air cleaner. To ensure that more particulate is able to reach the Electronic Air Cleaner to be filtered, you should make sure that the return registers are clean and not blocked by furniture.
Apr 29, 2009 | Honeywell (F50F1073) Air Purifier
Sharper Image air cleaner housing
depending on its value, we are happy to take a look and give an estimate, contact me at wbwill@sbcglobal.net or on allexperts.com I volunteer there too
Oct 21, 2008 | Air Purifiers
Air Purifiers Logo
57 people viewed this question
Top Air Purifiers Experts
Are you an Air Purifier Expert? Answer questions, earn points and help others
